P&G still eludes me.....
Discussion in 'Newbie Forum' started by BrennanShilohRescue, Jan 30, 2009.
  1. BrennanShilohRescue
    BrennanShilohRescue New Member
    bradenton, fl
    hi everybody,
    i've read up on Pulse & Glide.
    but i've only achieved it briefly for a couple seconds at a time, and totally by accident at that!
    i don't want to make myself crazy over the arrows, so i'm wondering.....
    if i'm driving 30-40 mph and the MFD say 99.9 MPG - ie, not just when i'm stopped or coasting - does that mean i'm P&G'ing?
    i've only seen that black screen (no arrows) while driving very briefly, but i've seen 99.9 MPG with green arrows....(i think).
    so, even if it isn't truly P&G, am i really getting 99.9 MPG during these times???
    'cause if that's the case, who cares!!!....(i think).
  2. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    from what i've read, pulse and glide is as follows- say you want to travel along at 60 MPH.
    the pulse is where you smoothly accelerate to 70 MPH.
    the glide is where you take your fool off of the accelerator, and glide all the way down to 50 MPH.
    net speed traveled= 60 MPH roughly, while your MPG will be better than maintaining a constant 60 MPH.
    the veterans can correct me if i'm wrong.
  3. richard schumacher
    7,664
    1,047
    United States
    99.9 MPG means "I'm moving but not using any gasoline to do so", and it will display that both while gliding and coasting. Coasting sends energy to the battery; gliding does not. Gliding is the no arrows condition achieved by pressing the gas pedal just the right amount. Keep practicing :_>
  4. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Anytime you are not showing the ICE = efficient driving, whether the MFD shows 99.9 or 60. In order to achieve either no arrows or only battery use you must first attain a good SOC, ie: 4-8 bars. so the first 5 minutes, don't worry about mileage, let the car accelerate briskly and then give a long no go pedal coast. You may even end up with a green SOC which lends itself very well to no energy glides with a tiny touch to the gopedal, now: sustain that! 99.9 only shows because of limited digits, you could be getting infinite mileage.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Well I don't consider myself a veteran but I'll correct.
    If your foot is off the accelerator you will be in a regen state which sounds good but it will reduce your speed rather quickly. It also wastes energy in conversion from kinetic to electric to chemical and then back the other way.
    Pulse and glide if very hard over 63km/h.
    Try to do glides down hill, that is assess the terrain ahead.
    Accelerate on flat ground before a rise to above you cruise speed, so if you want to do 37mph accelerate on flat ground to 42mph. Edit: I accelerate at 5.5 to 6L/100km and hold that to the top of the hill ulimately aiming to,
    Allow your speed to drop by holding your foot steady on the uphill to hit the top of the hill at 35mph.
    Accelerate a little to 42mph then lift your foot
    Now apply foot slowly to accelerator until the green line to the battery disappears from the MFD, you are now in a no lines glide, hold the foot position steady unless speed goes outside the 35 - 42mph window in which case adjust foot.
    This is a very brief explanation of what I do, it is not comprehensive by any means. Drive at all times within local speed limits. Pay attention to traffic around you. Leave big gaps, if someone pushes in, re-open the gap. Big gaps give better mileage.
    I found on a recent trip I could follow a van at 2.5 seconds gap at 130km/h and my fuel consumption was the same as at 120km/h with nothing in front. The van was a late model Hiace. You can feel when you move into the turbulent air behind a van, the car wanders a little, stay at that distance but no closer than 2 seconds.
    Another tip, pick a route with steeper uphills than down, you pulse up the hill and glide long down. I come home on a different road than I drive to work to avoid a long up short down hill. Also the steep part is 70km/h so glide is very hard, but due to steepness I can't glide without going too fast on the steep part.
    Sorry for mixing mph and km/h, I used mph where I could do the conversion metally and there is some flexability.
  6. andyprius
    2,212
    188
    Looks perfect to me Pat.
  7. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    Yes, Pat has provided a good summary. In addition, see this for perhaps the most complete discussion on the subject.
    P&G generally is done at <40 MPH, for at least two reasons. First, it is much easier to get into a no-arrows glide at those speeds; it is extremely difficult at highway speeds. Second, the goal during ICE-on conditions is to keep the ICE within an efficient RPM range where, at lower speeds, acceleration (i.e., a pulse) results. At higher speeds, that same RPM range will not accelerate the car due to increased aero drag. I generally just aim to keep the RPM relatively constant at highway speeds on level terrain. On hills, I climb as efficiently as I can, while remaining safe and courteous, and "warp-stealth" (described in the link I provided) downhill.
    Splitting hairs here, but with CAN-View I occasionally see fuel consumption with 99.9+ MPG. The CV instantaneous MPG reading might show, for example, 110 MPG. For the benefit of the OP, the factory display is simply designed to show no more than two digits left of the decimal, so in that case iMPG could be anywhere from 99.9 to infinite (i.e., true zero-consumption).
  8. BrennanShilohRescue
    bradenton, fl
    thanks to all for the additional info.
    but i'm beginning to think i may never be able to achieve really high MPG or much P/G because all my driving is stop-and-go city driving, with most of it being a 30-mile a day commute on a road with a hundred traffic lights along the way...and there is no alternate route without traffic lights in every block....
    so, am i right? am i striving for the unattainable here? is 53 MPG the best i can expect considering my driving scenario?
    don't get me wrong, 53 is GREAT compared to what i was getting before. but i can't help it, you guys have motivated me :)
  9. richard schumacher
    7,664
    1,047
    United States
    If you are getting 53 MPG under those conditions, be happy: you are already among the elect :_>
  10. patsparks
    10,664
    567
    53mpg (US tiny gallons) in heavy stop start traffic is excellent!
    To improve try opening the gap in front some, accelerate then anticipate the next stop and try to glide to a stop without using any more brake than necessary to stop the car.
    Better still, try not to have to stop, time your arrival at the lights so they have changed to green and traffic is moving, maintain momentum. If a light well ahead of you is green, you know it will be red when you get there so back off now, glide all the way to that light and it might be green again when you get there.
    I always think, I am going to (name a destination) not the next red light. There is no hurry to the next red light.
  11. BrennanShilohRescue
    bradenton, fl
    hi Richard,
    thank you so much! you just made my day :)
    kinda funny story:
    the reason i already knew how to do the "feathering on the gas-pedal"
    thing is because i was driving a 94 Mercury Sable wagon that had something wrong with it that nobody could find and fix....and if i didn't give it EXACTLY the right amount of itty-bitty pressure on the gas pedal, the fuel would get backed up somewhere, and the car would actually start to go SLOWER the more i gave it the gas, rather than faster!
    and once that happened, i'd have to let up completely off the gas until it got "un-backed-up", and then try it again, easier....
    meanwhile, 20 cars are piling up behind me as my car is slowing down
    to 20 miles an hour in a 50-mph speed zone....needless to say, i was a nervous wreck by the time i got to work 45 minutes later. and this went on for almost a year.
    so, i guess one could say, that old Mercury prepped me for my Prius!
  12. BrennanShilohRescue
    bradenton, fl
    __________________
    hi Pat,
    yep, that is great advice. i used to dread the red lights in my old wagon (see my previous post) because it would mean i'd have to go thru that whole acceleration/slowdown process again...(big sigh).
    Thank God that's all over now!
  13. JimboK
    2,817
    188
    49
    Chesterfield, VA
    I agree with the others that 53 is quite good, though there likely still is opportunity for improvement, especially in your warm climate. To put Pat's excellent advice another way: Drive as though you have no brakes. Every time you hit the brakes you waste energy.
    One of the commute routes to my part time job is a mix of suburban and urban driving and runs right through the middle of Richmond, VA. It has 47 lights and 5 stop signs. I easily hit 80+ MPG in the summer and even 90+ a couple of times last year. This time of year, I still generally manage at least 70. I've done it by learning the timing of the lights, experimenting with alternative route segments, leaving early enough when possible to avoid heaviest traffic, and liberal use of P&G. Though driving technique is the biggie, I'm helped along with some inexpensive modifications: engine block heater, grille blocking, and EV switch.
  14. BrennanShilohRescue
    bradenton, fl
    hi Jim,
    WOW, that's impressive!! the red lights always seem to get me no matter how much i try to prepare for them. i think it's because the yellow light is too short and the red light is way too long here.
    i live in an area of Florida where some roads are like highways (3 lanes each way, 50 mph), but with lights in every block! it's totally ridiculous. just as you're able to achieve the speed limit, you hit another red light. a lot of Florida roads are like this. up north we had highways with on and off ramps, and then we had regular roads. but this is an abomination. it's like they tried to put highways in the middle of all the cities - but without the on & off ramps. so it's 0 to 50 at every cross-street every 300 feet!
    thank God i've got a Prius now. last summer i was getting 12 mpg with that old Mercury Sable 387 engine and spending $400 a month to commute to work in the next town over.
  15. bestmapman
    1,289
    242
    Kentucky near Cincinnati, OH
    I have been to Bradenton and it is probably the perfect place to get some outstanding fuel economy.
    I think that if you:
    1) Installed an EBH
    2) Installed an EV switch (to use as kill switch only)
    3) master P&G and some other techniques.
    You could be pulling 80+ MPG on every tank.
    The fact that your daily commute is all stop and go and no highway driving is a tremendous plus. Also your flat terrain is a dream.
    Hope it works for you.
  16. gdbelden
    gdbelden Gator Hator
    66
    70
    Virginia
    with gas prices the way they are, it just seems too much trouble to worry about this P&G technique.
    More power to you all. Love the high mileage myself, but just responsively drive it.
    The mileage of the Prius is pretty amazing anyway.
    Just my opinion....
  17. JimboK
    2,817
    188
    49
    Chesterfield, VA
    More power to you too for just driving it, and many conclude it's too much trouble. I respect that. But please don't suggest anyone here is driving irresponsibly. I suggest that hypermilers are driving more responsibly than most -- driving more cautiously and courteously; constantly focused on their driving environment instead of passengers, a cell phone, their job, or Saturday night's date; reducing our dependence on foreign oil (even if only a drop in the proverbial [oil] bucket/barrel at a time); and developing habits that save money regardless of gas prices and will be second nature when gas hits $4/gallon again (you don't think we'll never see that again, do you?).
  18. danl
    danl New Member
    231
    Boston, MA
    I tried a little bit of P&G last night, and it took quite a bit of practice to get all the arrows to disappear. I got a heavy foot I suppose, and any slight movement from my foot and I lose it. Question though, wouldn't it be easier to put the car in neutral when you are initiating the "glide"? According to the manual, N does not engage the regenerative braking, so you should be coasting freely in that mode.
  19. patsparks
    10,664
    567
    It is easier but you will find your glides are not quite as long and if you do need to accelerate it slows your response. Also you must put the car in drive before you touch the brakes to maximise regen, if you do it after you touch the brakes your friction braking.
    In some locations it isn't legal to coast in neutral.
    Press your foot against the side to help stop your foot moving on the gas pedal. Wear light thin soled shoes if you can, I commute in steel capped boots. I rock my foot for fine adjustments.
    Avoid regeneration if you can
    Drive like you have no brakes
    If you have to brake, brake long and soft for max regen
    Avoid stopping, a red light does not mean stop, it means don't cross the thick white line.
    Accelerate without electric assist, use ICE to accelerate.
    Keep the engine off as much as you can.
    I personally believe you are better off driving at under 42mph using electric only if you can. But better to use no power if you can.
    I try to accelerate pretty hard so I can lift off sooner. I hate seeing 10+L/100km for ages while I creep up to speed, I'd rather see 20L/100km for a few seconds then lift off at 63km/h and glide.(speed limit 60km/h) I could be wrong, it my gut feeling.
    It should be noted a lot of people on PC run rings around me for hypermiling. I get there quick and with 60+mpg in town. I have 40 sets of traffic lights in my 37km commute.
  20. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Well, Pat beat me to it again. ;) But of course I have to have the last word, so see this for more. Actually, lots of last words -- it's rather long-winded. :)
