2008 Prius not Starting
Discussion in 'Gen 2 Prius Main Forum' started by libby724, Feb 5, 2009.
  1. libby724
    libby724 New Member
    Massachusetts
    Hi I having a problem with my 2008 Prius. I have owned it a little over 15 months and has about 18,000 miles on it.
    On Jan 12 I had surgery and am unable to drive for about 6 weeks so I had someone start the car for me after it sat for two weeks no luck nothing would not start. So off comes AAA they jump it starts I think I am back in business. 3 days later I have someone that was going to drive the car for me again nothing would not start.....off to the dealership. They said the test showed a defective battery so this past Friday the battery was replaced started the car on Sunday no problem. Went to start it today again will not start so off to the dealer it goes again.
    Now I live in new england and its cold you can't tell me you have to start these cars every day. Plus I owned it last winter and left it in my driveway for more than 2 weeks when I went to Florida. Also I travel for weeks at a time for work and have always left it and never had a problem starting it.
    And idea......Help this car is making me crazy this is the last thing I need after having surgery!! Plus I still can't drive till at least the end of the month.
    Thanks
  2. qbee42
    3,081
    The 12V battery in the Prius needs more than a quick start to recharge. You need to do one of two things: 1) Put it on a charger, or 2) Run the car for several hours.
    The jump got it started, but the charge level was still low. A few days later there isn't enough juice left to boot up.
  3. libby724
    libby724 New Member
    Massachusetts
    Sorry forgot to add when he jumped it the 1st time I had it run for about 45 minutes....then 3 days later it would not start again...
  4. Patrick Wong
    18,210
    6,514
    When the new battery was installed, maybe that battery was not fully charged before installation in your car.
    If the battery is discharged, you may need to leave the car READY for several hours before it will be fully charged. This is because the Prius 12V bus, operating at ~13.8V regulated by the DC to DC converter, runs at a lower voltage compared to traditional vehicles where the alternator may provide 14.4V-15V when the battery is low.
  5. libby724
    libby724 New Member
    Massachusetts
    Ok so lets say I do that turn it on let it run several hours till the battery is fully charged.....now it has to sit 2 1/2 weeks because I can't drive till at least the end of the month,,,,what will happen when I start it. Do I have to start it all the time. I never had too or do you think this is a one time, having it run for several hours because I got a new battery??
  6. Patrick Wong
    18,210
    6,514
    Hi Libby,
    Assuming that the replacement 12V battery is good, that it becomes fully-charged after you leave the car READY for a few hours, and that you make sure all cabin lights are off and the car is locked when not in use - then I would say you can move to a weekly cycle, where you make the car READY for 30 minutes at a time.
  7. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The car runs the '12V' bus at over 14V when it thinks the auxiliary battery needs charging. This can be observed in the 'Vehicle Signal Check' diagnostics screen (see here for how to access this - scroll right down).
    My recollection is that the storage instructions, which I was only reading yesterday, say that the car should be left in READY for half an hour every two weeks.
  8. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Are you sure your not leaving your doors ajar? Perhaps the rear trunk light is on and draining your battery?
  9. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    There are two interior light switches, the overhead one and the one in the hatch area. They each have three positions. OFF, DOOR ACTIVATED, and ON. You have to make sure they are in OFF or DOOR ACTIVATED. The one in the hatch is probably the one in the ON position. It's hard to see the light unless you really look from outside the car.
    This is the most probable thing draining the battery.
    Of course it's also possible the "new" battery the dealer installed is also "bad".
  10. richard schumacher
    7,666
    1,047
    United States
    Yeah, it kinda smells as though someone is not shutting off the car properly. *Always* lock the car; if any common battery-draining things are amiss the car will give a long warning beep. Of course if the 12V battery has been completely drained once it may already be permanently damaged.
  11. qbee42
    3,081
    If you are going to park your car for weeks at a time, I would think seriously about using some sort of trickle charger to keep the battery topped off.
  12. libby724
    libby724 New Member
    Massachusetts
    OK heard back from the dealer and this is what happened, an interior light was left on. When they replaced the battery (because it was originally defective) my brother went to pick the car up for me since I can't drive. He was having trouble taking the FOB out of the holder and I bet that is when he turned on the light. Of when I ran the car two days later in sunlight I didn't notice the light on.....Lesson learned....check everything before I shut the door. Oh and I did ask the battery is now fully charged they had it on a charger all day.
    Tom what is meant by a "trickle charger" I am car challanged!!
  13. qbee42
    3,081
    A trickle charger is a small battery charger. It provides a "trickle" of juice to keep the battery topped up. You plug it into the wall and attach the other cables to the battery or jump points under the hood. After that you can store your car indefinitely without running down the battery. You may have other problems, but it won't be the battery.
  14. richard schumacher
    7,666
    1,047
    United States
    Again, locking the car will warn one of such situations. It's a good habit to get into regardless of where you park. It has twice saved me from killing the battery while in my garage.
  15. libby724
    libby724 New Member
    Massachusetts
    Oh yeah I alway do lock it and now that you mentioned it when I went to start it on Sunday.....the door was unlocked.
    Lesson learned again this was someone who had never driven a Prius and he was my brother and he was doing me a favor.
  16. Patrick Wong
    18,210
    6,514
    Glad that your problem is solved for now.
    If a door or the hatch is ajar, locking the car and hearing an unusual beep will warn you of the problem. However if a cabin light is turned on using the pushbutton switch and left on, then locking the car will not give you a clue about the light being on.
  17. qbee42
    3,081
    Locking the car won't help with the map lights. You have to watch out for those.
  18. richard schumacher
    7,666
    1,047
    United States
    Good points. So modify the advice: if you're going to have someone else start or use the Prius for you, first make certain yourself that all of the light switches are set OFF, and then sternly charge that person to leave all the interior lights OFF. And, to always lock the car :_>
  19. qbee42
    3,081
    Richard's lock-the-car advice is sound. I always lock my Prius. I never routinely lock any other car where we live, it's simply not necessary, but with the Prius it's a great way to make sure everything is shut, powered down, and the fobs removed.
    Okay, let's be honest here, how many of you have walked away or tried to walk away with your Prius still on? I have, on more than one occasion, wondering the whole time why it was beeping at me.
  20. ponchotempest
    ponchotempest Junior Member
    Turn off the smart key when you park for extended periods. There is a button under the steering column. Whenever I park it for a while I do this, and no worries yet.
