being stuck in a cast sucks
Discussion in 'Fred's House of Pancakes' started by playhavoc, Feb 5, 2009.
  1. playhavoc
    playhavoc Junior Member
    SoCal
    but it doesn't mean i still can't have my fun.
    the letters proved to hard to cut out, so mr marker was called in to finish.
  2. moxiequz
    moxiequz Weirdo Social Outcast
    2,781
    Bay Area, CA
    Sweeeet! Too bad about the cast in the first place though. If you don't mind me asking - what happened?
  3. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
    I've read that you can speed up the bone healing process quite a bit (like 3 weeks instead of 6) by taking about 12 grams of arginine a day. Add another gram of citrulline to keep the arginine active a full 24 hours.
    Maybe start at 4 grams, and work up to the 12 as you confirm that there are no bad effects.
    Bodybuilders and old folks with arterial calcification use this sort of supplement all the time. It increases nitric oxide, and may increase release of growth hormone. At these quantities, you really want to use bulk powders. The markup on the same stuff in capsules is obscene.
  4. darelldd
    6,059
    389
    Northern CA
    Nice work! I can't draw on mine... and don't even have a cast. But here's what I had installed last week. :)
  5. patsparks
    10,664
    567
    Adelaide South Australia
    Darell,
    Did you put away what you tripped on?
  6. Freedom
    Freedom Active Member
    540
    73
    Northeastern MA
    Play Havoc, you did all that with your left hand? I take it you are left handed to begin with??? Love the first art work!
    Darrell, what's with the pin? Is that permanent or just for healing?
    OUCH!
  7. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Darrel... ouch. That looks scary. Bit of arthritis damage to your big toe by the looks of the xray. Both my tinky toes have that same slant to them from RA... Joint spacing look pretty good though, no?
  8. playhavoc
    SoCal
    yes i am left handed. i had surgery on my right wrist cause i tore the cartilage holding the bones together. they opened me up, sewed the cartilage together again and tada! cast for 7 weeks of which i've already done three. i can't even play ps3, now thats a heart breaker when you have time to kill.
  9. thepolarcrew
    thepolarcrew Senior Member
    4,426
    271
    North Dakota
    Nice art work. Hope your feeling better, I feel your pain. Sorta.
    Just had my Ulna / Ulnar (depending on which doctor you see) transported from my left elbow to inside my arm. Was in a cast for 10 days and won't let me do any strength training for 4 wks.
    The pin looks painful. That's what happens when you kick your nail Gun.
  10. patsparks
    10,664
    567
    Ouch, hope it heals quick and painless and may all your itches be accessible with a knitting needle.
  11. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    There are a bunch of us with new temporary handicaps. I just had shoulder surgery yesterday and now have the pleasure of a sling & swathe for the next 6 weeks...great.
  12. thepolarcrew
    4,426
    271
    North Dakota
    This must be the gimp thread.:eek:
  13. playhavoc
    SoCal
    you got me, i think a sling sucks way more than just the cast alone cause i had to wear one for the first few weeks and it was very uncomfortable. i hope you a speedy recovery efusco and darell. for what it's worth i am using one of those soft rounded plastic hangers to itch with, the girl that put my cast on told me that if i did scrape myself and open up the skin it could get infected. man thats alot to type with one hand, thanks everybody.
  14. thepolarcrew
    4,426
    271
    North Dakota
    Wasn't suppose to, but I would work at twisting my wrist and hand inside the cast. Fricken stitches.
  15. Dave_PH
    Dave_PH New Member
    2,416
    78
    Florida & DC
    What? What kind of shoulder surgery? Oh have I got horror stories for you.
  16. efusco
    19,891
    1,196
    Nixa, MO
    I was recurrently dislocating my shoulder. Had to have the labrum repaired and the capsule tightened. All arthroscopic.
    I'd previously had surgery, 17 years ago, on the same shoulder for the same problem...but that was an open, now archaic, technique.
    I'm not having pain, but the sling for 2-6 weeks is gonna suck.
  17. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Welcome to middle age. Not trying to scare you, but it doesn't exactly get better either
  18. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Speaking of '...sucks', I've heard using a vacuum with a crevice nozzle helps with those cast itches you can't scratch.
  19. jayman
    13,439
    641
    Winnipeg Manitoba
    Knitting needle? Can't hurt I guess.
