88C thermostats
Discussion in 'Gen 2 Prius Accessories & Modifications' started by bwilson4web, Feb 7, 2009.
  1. bwilson4web
    16,124
    I picked up a bunch of 88C thermostats from Ken@Japan last month and have started offering them on Ebay (item 120375070708). The standard thermostat only goes to 82C.
    Sad to say but Ebay requires a seller to make certain amount of sales before they can offer a "Buy it now" option. Regardless, let me know and we can coordinate a 'quick sale' (short duration listing) on Ebay and achieve the same effect.
    Eventually, after I get the Ebay sale count high enough, I'll be able to offer goods and services in other forums including PriusChat. But for now, I need to increment my Ebay completed sales count.
    Thanks,
  2. brick
    brick Active Member
    1,083
    79
    Upstate NY
    That must be a new thing for Ebay. I don't have that many sales (maybe 10?) and the last time I sold something (last summer) I was able to set a "Buy it now" price. Strange.
  3. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Sounds messy - especially after refilling the coolant and bleeding all the air out.
  4. hill
    8,726
    Messy turns on what the payoff is, IMO. It was messy getting under the Prius to install the EBH with my 6'-5" framed hands, but my mpg's went up. I bought (what was refered to as) the 90C thermostat from Yoshi at PCD and have yet to install it. But I hope the mpg return over months & months of driving will compensate for the one day of hassle. BTW, you have to bleed brakes, not coolant.
  5. Patrick Wong
    18,200
    6,499
    Well, it is also necessary to get air out of the engine and inverter coolant loops if you drain and refill coolant.
    However the thermostat change shouldn't be too bad if you just open the engine block drain cock, drain out a quart or two into a clean container (like a plastic water bottle), replace the thermostat, then pour the drained coolant back into the radiator overflow container.
    The hard part about purging air from the engine coolant loop is when you drain the coolant heat recovery canister and then try to refill it.
  6. hill
    8,726
    uh oh . . . thanks for the heads up on coolant bleeding, I haven't read up on it yet, but that does sound like a tad more than I'd anticipated ... which is usually on par with what I end up experiencing.
  7. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    511
    63
    Does the thermostat come with the o-ring (pictured?) or do I have to buy the o-ring somewhere else?
  8. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    Bob Wilson stocks the thermostats and the gaskets in pairs.
    Ken@Japan
