Plugin but without adding batteries??
Discussion in 'Prius PHEV Plug-In Modifications' started by kiwibruce, Feb 8, 2009.
  1. kiwibruce
    kiwibruce Junior Member
    46
    Katikati, New Zealand
    Stupid question time...
    I am a newbie here but I have searched the forums but never seen anything about this.
    Has anyone ever done ( ot thought of doing) a PHEV conversion but just adding a plugin ability for the existing battery.
    The reason I ask is I live in New Zealand so we are fortunate to have the EV button factory installed (Never seen a clear answer why they are not in NA)
    My Scenario.
    I live very close to town, (less than a mile or so) I can easily drive there on EV mode. But If I do that half way home the battery is down to 2 bars and the ICE kicks in and EV mode is disabled until the battery is charged up again.
    Which takes quite a bit of ICE driving or quite a few hills. Which I don't normally do for a few days.
    My wish is to be able to simply charge the battery up to 8 bars to start with.
    Of course I would love a Hymotion style conversion but with the New Zealand Dollar currently worth 50c to the USD it is never going to be affordable down here. So... I look for other ways to get the most 'EV' out of my Prius.
    Am I crazy? or has anyone ever thought about this... Tell me they have
    Yes I know, like any PHEV conversion Toyota would dis-own me.
    Any feedback would be greatly appreciated.
    Thanks
    Bruce
  2. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    It would have limited appeal because of the short range. It sounds like it would work for you, but I think the market isn't big enough for a 3rd party to introduce the charging hardware & whatever other changes they need to make.
    I believe Hymotion and other plug-in companies only recharge their own battery, they don't charge the existing traction (HV) battery, that one functions as Toyota set it up, and they fake out the system so the electric power first comes from the new battery pack. Once that's depleted, it's back to the normal system. I'm not sure anybody's looked into how easy or hard it is to recharge only the Toyota traction battery. There has been some solar panel conversions that charge up the small 12V battery, but there's debate on how effective that is.
  3. kiwibruce
    46
    Thanks for the reply You made a really good point it would involve touching Toyota's battery which as you point out the other PHEV solutions avoid for very good reasons. Just thought it was worth a discussion
    I agree it would have very limited market. But... then wouldn't everyone get a MPG boost if they started the day on 8 bars?
    Maybe it is just me... but it seems to be a rare event for my car to get to 8 bars, It take a really big set of hills to do it. and them it seems to not take that long to be back to 6 again (seems to be the norm)
    But I am still learning the car as I just brought it 3 weeks ago, 2nd hand.
  4. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    No, it's not just you; it's everyone. It's unusual to see 8 bars because the car is programmed to aim for 6 bars as an optimal level. This allows headroom for upcoming opportunities for regeneration -- such as hills. Otherwise, that energy would be wasted. Then when it hits 8 bars it uses that energy at its first opportunity -- again to make room for more -- until SOC (state of charge) settles in again at 6 or so.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    I ofen park my car with 7 bars so a plug in charger would have little value.
  6. kiwibruce
    46
    Thanks Jim for the explanation on why I so rarely see 8 bars, Makes sense now that you explain it.
    But it makes me want to be able to charge up to 8 bars even more!
  7. patsparks
    10,664
    567
    You know a Prius with 8 bars charge uses more gas don't you?
  8. kiwibruce
    46
    Hi patsparks,
    No, I didin't know that, How come is there a thread that explains that
  9. JimboK
    2,817
    188
    49
    Chesterfield, VA
    It is addressed in many threads, but it boils down to this: For maximum fuel economy, avoid using the battery. (I know, it seems counterintuitive.) All energy ultimately comes from the ICE, whether to move the vehicle or recharge the battery. Best from a fuel economy standpoint is to use as much of that energy as possible to move the vehicle. That avoids the inevitable losses as energy is converted from one form to another -- i.e., kinetic energy from the moving vehicle converted to electrical energy converted to stored chemical energy in the battery, then reversal of the process to use that energy.
    Now, on the other hand, if a plug-in was practical without adding batteries, that would change the picture. But as Nerfer suggests, range would be too short and the battery control algorithm likely too complex to make that viable.
  10. aminorjourney
    aminorjourney Mum to two prius!
    335
    27
    Bristol, UK
    Jimbo,
    For what it's worth you probably wouldn't want to spend the money on a charger (mine cost me £600GBP) specifically designed for the Prius battery pack without having another battery to put the power into.
    I'm doing a three battery setup - this should give me about 10 miles EV range. The cost should be about £2,000 GBP in total. I'd advise saving up and getting more than one battery!
    Nikki.
  11. Mjolinor
    Mjolinor New Member
    229
    Greece
    2002 Prius
    What charger is it? A genuine Toyota one, a modified one from a gen 1 Prius or a custom made delta V charger?
    I am sure that the internal battery would satisfy 90% of my car needs and I will get round to doing this when time permits.
    I don't understand why Toyota only run the battery between 40 and 80 % (or whatever the % are). Nothing I read about NiMH seems to suggest much gain from doing so except to say that over charging kills them and leaving them flat seriously affects capacity. From what I read the reduction in life doesn't seem to justify not using more of the battery's capacity.
    A 3 hour charge and 2 miles from that would keep me happy as long as I didn't sacrifice the hybrid capability.
    It's just an NiMH anyway so trickle charging at 1/10 C should be good for ever without damage so no need for an expensive charger if you have the time to wait. If you don't have the time to wait then provided you monitor it yourself and are careful you only have yourself to blame if you fry it, make a high current charger and buy a good alarm clock.
  12. kiwibruce
    46
    Hi Nikki,
    Can you give me some details on your charger you got, I know it probably is not worth the money but I would like to find out more about it, Thanks
  13. qbee42
    3,079
    Several studies, including one at a prestigious federal lab, have shown that battery capacity has very little effect on mpg in the Prius, once you get over a threshold. This is because the battery is used only to deliver short bursts of power, and to absorb small amounts of power during regenerative braking.
    To use more battery, as in a plug-in conversion, requires that the battery be cycled more severely. NiMH batteries can run though large numbers of small cycles, but only a limited number of large cycles. Using more of the battery's capacity would result in marginal mileage gains while greatly reducing the life of the battery.
  14. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    I think it is all about longevity of the battery. Extending the usable capacity to range from 10% to 90% would probably shorten the life significantly.
    Please note that average NiMH battery life span is quite low, only around 500 to 1000 full charge/discharge cycles. Panasonic probably improved on this, but smart battery management, which allows only capacity range of 40-80% to be used, has extended battery life for several times to quite some thousands of partial charge/discharge cycles. We are probably talking about tens of thousands of partial charge/discharge cycles.
    So it was all about life versus capacity.
    The ideal battery would be a capacitor. They have almost limitless life span measured in cycles, they can charge and discharge very quickly and they have efficiency second to none. The only problem is, they have almost no capacity compared to its size and weight. :(
    Ogo
  15. magicboy2
    magicboy2 New Member
    Other people's explanations of why the traction battery is kept in its given limited range of charge are spot-on.
    However, the bigger issue is that as mentioned, the computer is going to try and keep the traction battery in its "sweet spot" where it can contribute a good amount of charge, but also absorb some charge in the event of a large hill. You would, at some point towards the end of your journey, want to intentionally deplete down to three bars, and then be left alone after that. Because as someone already pointed out, there's no point in plugging the battery in if there's not much room left to charge it.
    Has any company ever successfully modified the hybrid power system logic? My understanding was that current plug-in retrofits merely lie to it about how much charge is remaining, rather than actually manipulating the logic.
  16. Mjolinor
    Mjolinor New Member
    229
    Greece
    2002 Prius
    So even without messing with the 40 - 80 % thing you could get 2 miles from it without ICU. If you could easily charge it then it is enough for an awful lot of journeys.
    Apparently the battery seems good for 100k miles or more. I usually buy cars at a few years old and run them until they decompose and I have never done over probably 70k miles so personally I could stand some loss of battery life.
    It certainly seems to make sense to me, though probably isn't that useful for a lot of drivers, it all depends how you use the car.
  17. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    This no doubt explains why the 2010 car continues to use the same battery, with the same capacity, as the 2004-2009 car.
  18. kiwibruce
    46
    This is my point. I don't want to push the battery past the 80% I just want to top it off to that (8 bars) then I could EV mode it for the first few KM's and I would be a very happy camper.
  19. toxicity
    toxicity A/C Hog
    146
    Houston, Texas
    In my experience, when you start the Prius on a green battery; the acceleration is MUCH better; in addition to obviously being able to enter into EV mode more often and for longer. That alone makes me want to do the whole plugin thing so I can start off the day with a green battery.
    But I have always wanted to do a plugin simply because, most of the year where I live, its hot; and whenever it gets above 75, I have the A/C on full at the coldest setting. In city driving, this destroys my mpg because the battery runs down fast what with all the gliding I do. I would like to plug in my Prius so that I can start it up with a green battery; then leave the A/C on for a few minutes, then get in a nice cool car and still have battery power to drive normally. I think thats reasonable, isn't it?
    In addition, there are supermarkets and restaurants much less than a mile from where I live, if I could do this I would probably seriously reduce my fuel usage at least 40%.
  20. kiwibruce
    46
    Nikki.
    Please please tell us about this Charger " specifically designed for the Prius"
