Prius HUD
Discussion in 'Gen 3 Prius Main Forum' started by Tideland Prius, Feb 13, 2009.
  1. Tideland Prius
    16,532
    If you want to find out about the HUD, check out the new 2010 RX at Lexus.ca or lexus.com
    It shows the speed, radio and nav instructions (radio and nav share the same real estate and are invisible if nothing is applicable).
    The HUD is height adjustable.
  2. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    What's a HUD?
  3. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    Heads Up Display, projects info on your windshield, actually very similar to what we have for our digital display, which reflects onto screen on dash.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Will Prius have a heads up display?
  5. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    european one will... and i guess japanese one too.... thanks for the tip.
  6. qbee42
    3,079
    In the U.S. we have our heads up something else.
  7. Mjolinor
    Mjolinor New Member
    229
    Greece
    2002 Prius
    That should carry a warning, I nearly choked.
  8. Tideland Prius
    16,532
    Tom?
  9. pjm877
    pjm877 Member
    340
    84
    austin, tx
    I would just love the hud... well really die for for one... This would be SOOO very Cool.. darn lawyers getting in the way of us getting the really neat stuff over here across the pond...
    now I am sad knowing that other countries will have the option of HUD on a Prius...
    OH well I have seen a HUD display .. it was on a Old Oldsmobile Toronado Troféo
  10. Tideland Prius
    16,532
    At least we get IPA now. I hope it's more useful (after going through a few iterations since 2004).
  11. RobH
    RobH Senior Member
    2,385
    991
    70
    Sunnyvale, California
  12. ManualOnly
    ManualOnly New Member
    193
    28
    Is the Lexus/Toyota HUD projected images focused at infinity ? (meaning as if you are reading the figures virtually at a distance)
    Helps reduce eyes fatigue.
  13. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    It should be, otherwise it is not a true HUD, which incidentally has been a standard option in the aerospace industry for at least 30 years. But in aerospace cost tends to be secondary to safety, since the speeds are somewhat higher.
    I happen to think that the current depiction of key travel data on my current 2008 Prius is a great improvement on the old thru-the-steering-wheel displays we used to have. It may not be a true HUD, but the eye movement required is probably less than 5 degrees, with a minimum of re-focus.
    OK with me.
  14. Tideland Prius
    16,532
    Note that the Prius one also shows the Hybrid System Indicator on the HUD!
  15. antiflash
    antiflash New Member
    93
    47
    Port Hueneme, CA
    i looked at a newish corvette several years ago here in cali and it had the HUD. I really wish there were more information out there as to why we do or don't get specific features like this. If nothing else, it would make sense for toyota to offer them as dealer installed accessories or DIY kits, as they already paid for the engineering to make it...
    Anyone heard of attempting a retrofit of the 2010 euro HUD into an american model?
  16. AussieDave
    AussieDave New Member
    Melbourne Australia
    The HUD is available on the Oz Prius. So far only got to use it on a long test drive.
    Controls are
    Shows
    speed
    horizontal bar display for economy but can have the other column graph displays on the main display
    shows turn arrow and distance to turn from sat nav but not continuously but at approx 800 metres and 300 metres and then just at turn. I assume these distance will change as speed increases as even an 800 metre warning at highway speed is leaving things a bit late.
    There are buttons to
    turn on and cycle through the speed/eco display
    move the display up and down to suit drivers height
    set the brightness (did not get a chance to see if the brightness also varied with the brightness of the other instruments)
    If you get sat nav another button controls its display.
    The satnav info, when displayed, cuts out the speed and eco display.
    Still got a month to wait for mine and then I will be able to explore it fully.
    David
  17. patsparks
    10,664
    567
    I loved the HUD when I test drove the Gen III Prius in Sydney. :D
  18. Fujisan
    Fujisan Blizzard Brigade #309
    126
    Warrington UK
    Love the HUD :cheer2:
    No more taking your eyes off the road to look at the instruments or the sat nav directions...a great safety feature. :thumb:
    Never quite understood why if you want to reduce costs you build cars to different specifications for different markets (within the limits of local safety and enviromental legislation). :huh:
  19. Rainingblood
    Rainingblood Junior Member
    35
    Italy
    in italy HUD is standard in all the prius 2010,
    il like it but the H.S.I. bar is too little!
  20. tjp74
    tjp74 New Member
    92
    31
    Bothell, WA
    So who is going to look into to see if it can be retrofitted into US models??? :hail:
