Luggage Rack?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by donovanbaldwin, Feb 14, 2009.
  1. donovanbaldwin
    donovanbaldwin Donovan
    Copperas Cove, TX
    Anybody got any suggestions for a luggage rack for a 2006 Prius?
    Thanks
    Don
  2. qbee42
    3,081
    Yes: don't use them. You are going to take a big hit on mileage. The Prius has very good aerodynamics, but not with a luggage rack stuck on top. I would rather pull a small trailer if it comes to that.
  3. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I'd be concerned with the adverse effects on handling. A load up top would raise the centre of gravity, and make the car even more susceptible to side winds. Are you sure you can't fit everything inside?
  4. fernelius
    fernelius Junior Member
    17
    Pennsylvania
    You might check-out evnut's pages:
    Prius Racks
    I had a Yakima rack on my 1997 Saturn SC2 and used the clips. Unfortunately, I had someone back into my 2009 Prius Touring on 1/25. It should be repaired finally this week. I requested they also install the "permanent" Yakima rack. Landing pads remain on the vehicle; however, the rack clips out when not in use. If you don't use the cargo hold on the rack very often, this might be a great option to reduce fuel efficiency impact.
    As noted I wasn't quite brave enough (nor could I find the time) to install it myself. These pages show the rack and installation...
    EV page
