Denso Sensors, ECUs & other Parts
Discussion in 'Gen 3 Prius Main Forum' started by ggood, Feb 15, 2009.
  1. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    This Denso website has descriptions of many of the parts, sensors and ECUs used in the Prius (though Toyota is only mentioned by name a couple of times), including descriptions of lane keep assist, collision avoidance, etc.
  2. p626808
    p626808 New Member
    292
    Great find..
    thanks.
    Scott
  3. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    Re: Denso electric A/C
    I read the description of the electric A/C for hybrids. The description of the A/c mentions that it runs at 7500 RPM regardless of the engine RPM and since it runs so fast, only a small refrigerant charge goes thru the compressor on each revolution.
    Does anyone understand show the electric A/C is powered on the Prius? Is this unit ran in an ON and OFF mode or is the RPM of the A/C compressor varied from low to high RPM in proportion to the amount of cooling required? The old engine powered A/C systems are typically the ON/OFF control.
  4. Patrick Wong
    18,210
    6,513
    2G Prius A/C compressor speed is variable, and controlled by the A/C ECU. The ECU takes into account interior humidity, the amount of sunlight, interior temperature, which vents are selected, and whether the wipers are operating.
  5. patsparks
    10,664
    567
    Adelaide South Australia
    But the Honda Insight is better because it has rear vents!
    Well according to a reviewer.
  6. dick_larimore
    162
    70
    Central Indiana
    Thanks Patrick on the explanation on the control of the A/C. A variable speed control of the compressor insures that only a minimum amount of fuel is used to cool the interior of the car. This is way better than mixing hot outside ambient air with the cooled air to control the interior temperature of the vehicle. It will be interesting to understand the "improvements" to the A/C efficiency of the Gen III Prius compared to Gen II.
