2009 EV mod? . always on 12V idea...
Discussion in 'Gen 2 Prius Accessories & Modifications' started by mrbillz, Feb 15, 2009.
  1. mrbillz
    mrbillz Junior Member
    Greetings all,
    after unsuccesful search, I am wondering if the 2009 Prius is amenable to the EV switch mod? Any of you done it or know of "issues" Just got my new (first) 09 touring and find this idea intriguing...
    RE: the always on 12V plug, I have an '01 4runner that had a very easy mod to full time enable all 12 receptacles that involved simply jumping the relay in the engine comp fusebox- Haven't seen a Prius wiring schematic yet, but has anyone looked at this possibility?
    Thanks!
    BS
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    1) Yes, same technique as your extensive searches should have brought up for you for all the other '04+ years.
    2) Power Outlet Mod
  3. mrbillz
    Thanks ef- I found the power mod- WAY more complicated that the 4runner...
    Didn't see the 04+ EV- thanks!
    BS
