2009 Prius not honking when locked by key fob
Discussion in 'Gen 2 Prius Main Forum' started by mtapu65, Feb 15, 2009.
  1. mtapu65
    mtapu65 New Member
    Vancouver BC
    I've recently bought a 2009 Prius and I've noted that when I lock it using the the remote key fob, it doesn't make any noise/sound/honk.
    At my first service, I asked the technician to restore this function, but I was told basic models like mine come without this feature.
    It's hard to believe.
    Can anyone who owns a 2009 Prius confirm this?
    Thanks.
  2. qbee42
    3,081
    The base model does not beep. Higher models issue a soft beep when locking. None of them honk (thankfully).
  3. Tideland Prius
    16,621
    Seriously?!?! I thought all of them have the soft beep.
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Check the owners manual. I turned that off on mine. Nothing worse than a noisy car!
  5. qbee42
    3,081
    I don't have a base model, so I can't test it personally, but that information has been published more than once.
  6. jtlytle
    jtlytle Caution: Prius owner
    89
    What about your headlight? Does it flash when you lock it? Mine do. I preferred the lights than any beeps or horns because I'm deaf.
