My 2004 Prius Just Died
Discussion in 'Gen 2 Prius Main Forum' started by hbark, Feb 12, 2009.
  1. hbark
    hbark Junior Member
    56
    Bucks County, PA
    Went out on what was supposed to be a quick errand at lunch. On the way back, lights started coming on, gas engine wasn't coming on (tank was 3/4 full), finally wouldn't go at all and I coasted to a stop (luckily in a safe place).
    Got towed to the dealer, waiting there now. We had bought an extended warranty which is still in effect so hopefully whatever it is will be covered.
    Here's a description of the lights that came on in case anyone knows anything about this:
    On the instrument cluster above the dash - the triangle with the exclamation point in it, the picture of something that I guess is an engine with "CHECK" under it, and a circle with things that look like parenthesis around it, with an exclamation point in it too. On the LCD display where the Nav etc. is, on the upper left a picture of a car battery with the word MAIN in it.
    I got it 5 years ago next month, has around 78K miles on it.
    Sigh.... :(
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Do you still have the original 12V battery in the car? If so, it probably needs replacement. A weak 12V can cause many strange things to happen with the warning lights.
  3. Patrick Wong
    18,200
    6,493
    Please keep us updated on your car's status, seeing the MAIN battery warning icon is quite unusual.
    Did you have the engine and hybrid vehicle ECU firmware updated when the SSCs (recall notices) came out back in 2005-2006? If yes, then my guess is that you are one of the few 2G owners with a bad traction battery (not the 12V battery).
  4. jtlytle
    jtlytle Caution: Prius owner
    89
    I have a 2004 Prius and I would like you to update the status so I can learn something from you!
  5. cephas
    cephas Junior Member
    Prius
    any update?
  6. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    The "main" battery icon probably came on after you ran it way
    kdown by continuing to go after the engine hadn't started to
    help push the car. The original symptom is probably the perennial
    throttle-body problem but nobody can be sure until you get the
    codes pulled and some testing done. Warmer weather may fix
    everything up temporarily [if applicable, don't know where you
    are] but it sounds like some basic maintenance is in order.
    _H*
  7. gail1946
    gail1946 Junior Member
    wa
    Just happened to me. The same thing you described when your car died...but I was test driving a 2007 from a dealer (not a Toyota one). Did you ever get a resolution to your problem? What was it? Thanks
  8. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    Original post 11 days ago,I hate when people post a problem and then don't give updates even just to say it's still at the dealer or whatever,
    PLEASE REPLY!!!:mad:
  9. jtlytle
    89
    <tap> <tap> Still waiting...
  10. halpos4
    halpos4 "Taxi"!
    377
    25
    Ireland
    I hope you're not holding your breath or it won't be just that 2004 Prius that just died and you'll be unable to give us an update on your health:D
