Is there a tachometer...
Discussion in 'Gen 3 Prius Main Forum' started by zenMachine, Feb 21, 2009.
  1. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    in the G3?
  2. bwilson4web
    16,370
    I didn't see one.
  3. zenMachine
    3,355
    300
    How truly disappointing.
    But hey, you can get Bluetooth streaming music instead!!!
    :smash:
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    You get an efficiency meter in the info display, probably more to the point of what some use the tach for anyway, but yes, a geek mode to include RPM would have been nice for hypermilers. Then again, we'd have to figure out all over again the efficiency ranges of the new ICE for it to make much sense.
    BTW, new max RPM is 5200rpm now.
  5. kabin
    kabin Member
    167
    Scottsdale, AZ
    Just purchase a ScanGauge. It provides all sort of diagnostic info including rpm. It connects to the OBD port.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    No, there is no useful instrumentation in the 2010 and the hole I used to thread the ScanGauge cable through is gone. When I complained, Natay didn't understand why anyone would want such info as inverter temp, coolant temp, RPM, and GPH.
  7. zenMachine
    3,355
    300
    I have a Scangauge. It does NOT provide inverter temp, among other things...
  8. zenMachine
    3,355
    300
    Who's Natay? Engineer or Sales or Product Management?
  9. hntr467
    hntr467 New Member
    22
    Rockford, IL
    I'm not sure why you'd need a tach? Especially with an electronically controlled CVT? It's not like you'll be deciding which gear to use going up or down a hill...lol. If it's because you want to determine the best highway mpg using the engine's rpm, you could simply do a little experimenting by checking highway mpg at different speeds (within the speed limit of course :p). Help me out? Is there a good reason other than curiosity?
  10. JimboK
    JimboK One owner, low mileage
    2,817
    189
    49
    Chesterfield, VA
    There are many of us who pay close attention to RPM (and other operating parameters) in order to drive efficiently and maximize fuel economy. With a little bit of pedal control, there is a surprising amount of control the operator can have over the engine speed.
  11. patsparks
    10,664
    567
    Adelaide South Australia
    SOme hypermilers use the RPM to set an economical speed, you can fit a scan guage for about $160 which gives you a tacho and temperature gauges and if your clever you can get lots of other information from it like inverter temperature. Search Xgauge.
  12. JimN
    7,028
    1,117
    South Jersey
    Natay was the one stationed by the Platinum package. I was told she was from Engineering.
  13. sl7vk
    sl7vk Member
    518
    Salt Lake City
    I complain about a lot of things... Lack of a Tach, I will not. Aside from a couple, who really gives a crap? Give me something useful like a backup camera instead.
  14. greenbirder
    greenbirder Junior Member
    Padre Island off TX coast
    Natae Rayner is Toyota Product Education Manager
