2010 Prius First Drive - What do you want me to cover?
Discussion in 'Gen 2 Prius Main Forum' started by Danny, Feb 24, 2009.
  1. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Later on this week I have been invited by Toyota to attend a special Media preview of the 2010 Prius. The 3 day event will include technical and marketing presentations along with opportunities to drive the 2010 Prius.
    This is the event where the mainstream press will draw their conclusions on the new Prius and offer those conclusions to their readers at the end of March. The mainstream media is going to write about what they always focus on - 0-60 times, braking, etc. What I would like to do is to get your input on what you would like for me to focus on in my driving experience. What do you want me to ask the Toyota representatives, test during driving, check out while no one's looking, etc?
    What do you want to see in the PriusChat 2010 Prius "First Drive" Review?
    Get your feedback in by Wednesday night!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Danny,
    Find out if they'll let you hook up a Scan-Gauge.
    If at all possible you'll get the most helpful information for me if you can drive the car from a true cold start.
    Do you have to do the idle check to get into S4 (requires a cold start)? Are the stages the same?
    How long does S1 last (you'll need to monitor rpm).
    How much regen when coasting (amperage)? How easy to find the glide sweet spot?
    What are the speeds for ICE-off coasting?
    What's the max speed for EV mode?
    Can you feel the transition from regen to friction? Any change in the amount of regen? What speed does regen kick out?
    Traction control...can you spin the wheels at all on wet/slick pavement? Is it as aggressive as the 2G?
    Is sound dampening better than the 2G?
  3. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    The Beep! See if you can disable the Beep!
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Danny you are one lucky guy LOL. Even though it's probably a short drive, you know how your current Prius reacts and what kind of mpg numbers you see in yours for your particulard driving style, I would be interested in your comparasion and opinion if the new Prius would get better mpg's then yours now, the same or worse.
  5. fredthepostman
    422
    boothwyn pa
    Look out the rear window. Is it any better?????
  6. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I'd like to see some video, both from outside the car and inside while in motion. Show us what the new dash looks like, and test out the voice activated nav. Surely you could find a willing co-pilot with some video experience to volunteer? :)
    The other thing I've yet to see is how many people will fit. No, I don't mean five in seatbelts. I mean the old University thing with arms and legs everywhere. That'd make a great clip. ;)
  7. seaside
    seaside New Member
    Greater Boston
    Danny,
    I’m particularly interested in improvements in perceived seat comfort – seat angles, lumbar support, thigh support, leg room, cushioning, steering wheel positioning. There appears to be a lot of attention in this area so I’d like to hear if the hype translates into reality. [This is the only issue that has kept me from purchasing a Prius.] I know it’s totally subjective, but I’d appreciate your perspective.
    I’d also like to hear about noise-deadening improvements. I’m assuming that the evaluation unit will have standard issue [OEM] tires.
    Many thanks for this offer!
  8. Tripod137
    Tripod137 New Member
    145
    Long Island
    Ask them, what possessed them to increase the REAR leg room (and not the front). In my '06, my 6'5" father in law can fit fine in the back seat while the front seats are moved all the way back. As for front legroom, I (6'1") am a little uncomfortable in the front passenger seat because of the encroachment from the glove compartment. Unless I am driving, I would rather ride in the back any day.
  9. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    +1 on Evan's ideas in post #2.
    With a ScanGauge; running on cruise control, on the flat, ICE RPM's
    at 55, 60, 65, and 70 MPH.
    (I understand these numbers could be skewed by wind induced errors.)
  10. efusco
    19,891
    1,196
    Nixa, MO
    I was about to ask the same, but they don't get to take the cars out on the highway, just surface streets.
  11. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    How about RPM at a steady 20, 30, 40 MPH?
    Wayne
  12. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Guess that rules out testing the top speed! :D
    But seriously, no highways? That means linear stability at highway speeds won't be tested, which is one of the most important improvements (hopefully).
  13. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Hopefully, they'll let Danny drive versions with both 15 and 17 tires, so he can report on any differences in ride and handling.
  14. reesch
    reesch Junior Member
    Chicago
    Not sure you'll have the opportunity, but if you do, I'd like your impression of the effectiveness of the solar panel in keeping the interior cool while sitting idle for an extended period. Any chance they'll sell a sun roof w/o the solar panel?
    Also, for sure tell us about the advanced technology package. Is it worth the hype?
    I'm assuming both these options will be pretty pricey and would like to know how they perform before choosing one or the other, if either!
    Thanks much
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Try the ECO and PWR modes. Let us know how you like them. Do they make the car feel like completely different cars?
  16. bwilson4web
    16,119
    Plot as many data points as you can for these charts. The first is maximum acceleration:
    And:
    Prior to test, check the oil level and tire pressure.
    During the test, see if you can have a digital video camera focused on:
    • consumption display
    • mph display
    • microphone 'taped' to dash will give rpm 'and your audio notes'
    • try to reset the MPG after setting the cruise control to any given speed (we can use to time-stamped MPG updates to calculate the asymptotic values if we can get say 1 minute at a given speed): target 45, 55, 65, and 75 mph
    • coast down from 50 mph and listen for when ICE stops turning
    • obviously longer tests at a fixed speed on a level route are better than shorter ones BUT we can use camera MPG time-stamps to 'do the math'
    • maximum acceleration test is always useful WITH the consumption and mph concurrently in view
    • see if "forced charge" still works
    If possible, make an MPEG so we can more easily Mac analyze it.
    Thanks,
  17. samiam
    samiam Antipodean Prius Poster
    2,442
    29
    Enn Zed
    The look and feel of the display and controls please Danny
    Are they intuitive and immediately useable when driving?
    Also please note the changed console and new location
    for the shifter (that has been the subject of so much
    hand-wringing here on PC), are any of the changes
    noticably difficult to use or intrusive as you drive?
  18. 06prius
    06prius New Member
    60
    NH
    This does not have to do with a test drive but see if they can give you a date range when we may expect to see them at dealers for purchase.
  19. sshaw10
    sshaw10 Member
    103
    West Los Angeles
    Danny,
    I echo Tripod137. I'm 6'4" and interior size has kept me out of a Prius. I believe the shifter has moved to the center (from hitting my right knee) and there are claims of increased interior room but it may be limited to the back. I would be grateful if you could pin them down on any extra room that may have been created. I need to get a new car in the next couple months and would hold out for a 2010 if there were a couple extra inches. Thanks for making your offer!
  20. alam99
    alam99 Member
    97
    33
    Chicagoland
    How about asking if the typical shortcomings of the 2nd generation are improved in the new model?
    - 12 volt battery drain if the car hasn't been driven for a while,
    - traction control on slippery/icy roads,
    Other readers who own the current generation would know better than I do about existing "issues", but these two stand out in my memory from all the postings I've seen.
    Hope you have a great time!
