tire pressure question, again?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Bob Allen, Apr 11, 2005.
  1. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    Hi: I intended to up my tire pressures to 38 front and 36 rear, but went a bit too far and got 40 in front and 38 in rear. I did notice increased mileage and a firmer ride, but I got worried about having too much pressure. I went out and dropped them back to 38 front and 36 rear.
    My question is whether it is dangerous to carry 40 lbs in front and 39 in rear. The manual states 35 front 33 rear and I think the max is 44 lbs.
    Any comments? Any of you carrying 40 lbs and not worrying about it?
    B
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Bob,
    There was a lot of conversation on this subject over a year ago when I started using 40 front and 38 rear. I quickly got used to the firmer ride and have not experienced the handling or tire wear problems that many have mentioned on this board.
    Johns site mentions running 42/40 as normal with some running 44/42 with no problems.
    To answer your question, NO, there is no danger running 40/38 though it might require some softer pillows in the back seat!
  3. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    IMHO - unless your roads are absolutely smooth - the ride harshness is *not* worth the 2-3 MPG you *might* gain.
    I experimented with both the OEM Goodyear Integrity and the Michelin Harmony replacements, with inflation pressures right up to 44 psi. At city speeds under 80 km/h, there was *no* difference in my MFD or tank average fuel economy.
    At Trans Canada speeds, a couple of times I gained 3 MPG. The "gain" was usually under 2 MPG, with many instances of no gain whatsoever.
    BTW there is no difference in fuel economy between the Integrity and the Harmony, at least none that I could detect.
    With all the potholes and frostheaves around here, I refuse to shake the car to pieces. The ride is *much* more civilized at 35F/33R.
  4. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I run 42/40 as per my prius tech and others recommend here. I notice increased thread life and an increase in mpgs. Lower pressure really causes the tires to wear prematurely. I like a firm ride so i don't really notice a harsh ride and the increased pressure
  5. jamarimutt
    jamarimutt New Member
    985
    I agree with jayman... a couple of mpgs are not worth the harsh ride and the multitude of rattles produced by overinflation; 35/33 is an excellent compromise between economy and quality.
  6. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Here's something I haven't seen an answer for:
    Why exactly two (2) psi difference between the front and rear tires? Why not 40/39 or 36/35? Perhaps 40/37 or 37/34? What's with the 2psi difference?
  7. Frank Hudon
    Frank Hudon Senior Member
    4,147
    <div class='quotetop'>QUOTE(jayman\";p=\"80301)</div>
    Potholes? frost heaves?? please explain.
  8. Frank Hudon
    4,147
    <div class='quotetop'>QUOTE(TonyPSchaefer\";p=\"80365)</div>
    I would hazard a guess as to weight bias towards the front of the car. So extra to carry the heavier load.
  9. seasalsa
    1,278
    Kent, WA
    Toyota specifies a 2 pound differential between front and rear.
  10. jayman
    13,439
    640
    Winnipeg Manitoba
    Frank:
    Grrrrr ... must be nice to live in an area without frost that sinks down almost 6 ft. About the only thing worse would be Permafrost.
    For the benefit of those lucky enough to live in an area where if the temp getting to the freezing point it is a FEMA emergency: a "frost heave" is a nasty ripple effect on pavement caused by the frozen ground "jacking" the pavement up.
    AKA "frost jacking" and can really bugger up pavement and cement. Usually, the frost heaving will create 1-2 inch tall sharp ripples. Hit those babies just right and you either pop a tire or fly off the road. Like Speed Bumps from Hell.
    Jay
  11. jayman
    13,439
    640
    Winnipeg Manitoba
    Tony:
    Beats me. I've tried reversing the bias, having no bias, etc. There was no difference in highway handling that I could detect, even on exit ramps or on ramps.
    Jay
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    im sure it has to do with suspension tuning and the additional front-end weight. on another note, unlike most people, i couldnt detect a noticable difference in ride comfort from 35/33 verses 40/38 (what i ride at normally)
    i have the "disadvantage" *sic* of living in the state capital where roads are generally much better condition than elsewhere so that may contribute to my not noticing the roughness of various road surfaces.
  13. Frank Hudon
    4,147
    don't worry Jay this was a bad year for frost heaves here as well. Lots of broken pavement Cold snap back in January with day time showers made it icy and wrecked a lot of pavement. I also lived in Dawson Creek, start of the Alaska Hiway and I know what 6-8 feet of frost is all about.
  14. MiamiMurphy
    MiamiMurphy New Member
    Miami
    Hi all -
    Stupid question - I really do not check my own tire pressure but 3 weeks ago, Goodyear checked it and said the tires were 35 all around.
    Today, 4/17, I went to an Amocco station and tipped the guy to check the tires - he said it was 30 in the rear and 32 in the front - I had him make it 33 rear and 35 front. However, since the Amocco station is 1/2 a block from the Goodyear tire place - why the difference.
    How can I tell if I over-inflated my tires and why such a difference.
    The outside temperature was the same (almost) both times - around 72 degrees.
    thank you.
    Mary Lou
    Miami
  15. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    difference can be as much as 5 psi just from cold to warm tires. the difference you mention could be simply how warm the tires were. the best time to check your tires is first thing in the morning after the car has sat all night. you want to measure it at the coolest part of the day. so early morning is best. may not be the coolest part of the day, but will be close enough
  16. MiamiMurphy
    Miami
    Thank you. 72 degrees was first thing in the morning and the coolest part of the day here in Miami - probably will not be that cold again until November.
    Hopefully my tires are okay.
    I think I will have to get one of those tire gauge things and measure it myself before driving it.
    BTW - You live in a great place. I am considering a re-location to Portland Oregon.
  17. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Someone posted that their expensive guage was way off compared to a cheapie and the pressure monitor they installed.
    So, I would say that it is possible that either Amocco or goodyear have guages that are reading incorrectly.
  18. Venturer
    Venturer New Member
    79
    Every tire has a specific pressure for the load it is carring. I have always weighed my vehicles to determine what each tire is carring both loaded and empty. I then look at a load chart for the tire and set the pressure for the load it is carring. That along with rotating the tires every 10,000 miles or less will get the maximum mileage and performance from any tire. My 02 Avalanche has 63,000 miles on the OEM Good Year Wrangler ATS tires. The truck weighs 6300#s with me in it. The tires had 16/32" of tread when new and they now have 8/32". The wear has been even all the way around. Most of our vehicles recommended pressures were for maximum load as I think most are. We are rarely at max. load, so my pressures are rarely at the mfg. recommended pressures. I haven't weighed the Prius yet, so I don't know where I'll be, but I'll trust the weight charts to be correct.
    Doug
