Engine Air Filter
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Russ33, Feb 24, 2009.
  1. Russ33
    Russ33 Older Junior Member
    Long Neck, DE.
    Time to change engine air filter on my '07.
    Has anyone found a different source other than Toyota?
    If not what is the price of filter at Toyota?
    I will change it myself.
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    It's fairly easy to find aftermarket Fram and the like at regular auto parts stores. We've had endless debates about the cost savings vs quality.
    The engine filter doesn't need changing that often, unless you drive on dusty gravel roads. The cabin air filter is another matter altogether
    Some of the Priuschat cheap bastards - like Yours Truly - will get a large HEPA furnace filter from a Big Box store, and cut it to work as a cabin air filter
  3. JimboK
    JimboK One owner, low mileage
    2,817
    190
    49
    Chesterfield, VA
    Dealers will set their own price, though I would guess there is a MSRP. I buy mine from Metro for considerably less than what the local dealer charges.
  4. patsparks
    10,664
    567
    Adelaide South Australia
    Search on line, you can buy cheap genuine parts on line, get a few or get a polen filter and oil filters to save on postage. I now only use genuine Toyota filters.
  5. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    although you should replace the engine air filter every 30,000 miles...
    if your really cheap, and i am really cheap and you do not want to buy the furnace filter for your cabin air filter, you could just remove it and then soak/wash it by hand in soapy water and rinse it, allow it to air dry, and then put it back in your prius. heh
  6. maseace
    maseace Prius enthusiast
    191
    Poulsbo, WA
  7. tochatihu
    tochatihu Senior Member
    9,855
    3,815
    Kunming Yunnan China
    2001 Prius
    There are several interesting alternatives for cabin air filters, but they should not be confused with the engine air. That one should be (at least) designed for the task.
    K&N engine air filters are in use in many Prius (of all model years) but they have some potential drawbacks and best suited for DIYer who attend closely to maintenance matters.
  8. Mr.Vanvandenburg
    1,358
    596
    2020 Prius Prime
    I bought one for my 07 for about $15 online, genuine Denso made Japan. I got free shipping as needed other things. Won't need it for another year or two. I saw also for $11 plus shipping from a dealer in Texas. I need to replace every 3-4 years so $15 isn't too budget breaking an amount. I would stick to this brand as I believe their triple layer claim. Usually I ignore claims but not from this company.
  9. sparkyAZ
    sparkyAZ übergeek
    311
    Mesa, AZ
    Get on the toyota dealer's mailing list - here have parts sales twice per year. They just had their 20% off sale and I picked up engine air filters for $13.60.
  10. jbracefan1977
    jbracefan1977 New Member
    Kansas City
    I have the same K&N also and love it, I could not find a good deal on ebay so I found a discount coupon here: K&N 33-2329, or you can try one of the vendors on the forum here, you can usually find a good deal that way as well. This was very easy to install and I love it. :rockon:
