Prius smartkey question
Discussion in 'Gen 2 Prius Technical Discussion' started by benjasik, Feb 25, 2009.
  1. benjasik
    benjasik Junior Member
    san francisco, ca
    2015 Prius v wagon
    I have a 2008 prius and lost a key. I bought a used smartkey on ebay (silver back) and took it to a shop to get it reprogrammed, but only the immobilizer ended up working. Neither the remote nor the smartkey worked. They tried a few times to reprogram it with no luck
    Is there anything different about programming a 2008 prius vs the 2004-2007?
    How could I troubleshoot what's wrong with a smartkey? Has anyone taken one apart?
    Thanks in advance!
  2. qbee42
    3,075
    It's a used key. Only the immobilizer will work. The other parts can't be set back to synchronize with the car, as the ECU expects a new key fob.
  3. benjasik
    san francisco, ca
    2015 Prius v wagon
    Is there any way to reset a used key? So what you're saying is once a key has been programmed there's no way to reprogram it?
  4. RobH
    RobH Senior Member
    2,369
    980
    70
    Sunnyvale, California
    Actually, it's the car that is programmed to recognize the keyfob. The black logo keyfob has a counter in it that increments by one each time a key is pressed. Apparently it is only possible to program the car to add a keyfob that has been used some small number of times. The silver logo keyfob uses a different encryption chip, but it behaves in much the same way.
    If you're really interested, go the Microchip website and download the data sheet for a HCS362 encryption chip. It is used in the black logo keyfob. Note particularly the section on "limited seed" mode. It limits transmission of the seed value to a counter value of 127 or less. I don't know if Toyota uses this mode, but it would account for the observed behavior.
  5. qbee42
    3,075
    Exactly. As posted above, the car is programmed to accept the fob, not the other way around. For security reasons, you cannot add a fob that has been used for more than a small number of cycles.
    Microchip makes the guts for these things. Their web site is a good source of technical information if you want gory details.
  6. spitinuri
    spitinuri Member
    317
  7. qbee42
    3,075
