After repairs thermometer icon pops up
Discussion in 'Gen 2 Prius Main Forum' started by nhguy78, Feb 26, 2009.
  1. nhguy78
    nhguy78 whirr...........
    51
    Hudson, NH
    I was recently in an accident with my 2009. I got the car back after body work and thermos replacement, etc. The body work was done and thermos replaced but sent to Toyota to bleed the system. I get the car back and it was heating nicely and then later in the day it throws errors and now blows all cold air. Is this a thermos issue do you think or was something left disconnected?
  2. qbee42
    3,081
    It's probably not directly a thermos issue. The thermos simply stores hot coolant for later use. Most likely you have an air bubble in the cooling system, which means it needs to bled again. It's a bit tricky, and sometimes all of the air is not removed on the first try.
  3. nhguy78
    51
    Hudson, NH
    Thank you. I'm waiting for insurance to call back to get it bled again.
