Flat spots on all four tires
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by omo, Feb 25, 2009.
  1. omo
    omo New Member
    Virginia
    I am a new owner of a 2005 Prius. When I bought the car, the previous owner said he had just replaced the tires. He said the previous set, which were on the car for about 30k miles, had developed flat spots. Now, the new tires (with only 500 miles on them) also have flat spots. The guy at Firestone says it looks like someone had slammed on the brakes at highway speed and skidded. Although there is no way for me to be sure of how the previous owner drove the car, I am doubtful of this explanation of the flat spots, because aren't anti-lock brakes supposed to prevent that kind of thing? I have done a lot of reading on Priuschat (very helpful site!), and am aware of alignment issues and premature tire wear with Prius. I have also read about brakes occasionally being messed up on a wheel, causing a wheel to drag and thus cause a flat spot. But I've got a flat spot on all 4! Is there another possible issue that could be causing this problem? What should I look for? Or could the Firestone guy be right, and someone locked up the (anti-lock) brakes?
    Thanks for the help!
  2. qbee42
    3,082
    If a wheel drags you don't get a flat spot, you get premature wear. A flat spot, or more correctly a bald spot, comes from locking a wheel. Antilock brakes should minimize the risk of this, but hard braking can be hard on tires.
  3. hobbit
    hobbit Senior Member
    4,089
    470
    Bahstahn
    Some towing numbnuts probably dragged it onto a flatbed at
    one point. Ask about its service history and how it got to the
    shop if not under its own power on any occasion.
    _H*
  4. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    like they said above, the only way to flatspot a tire is to lock it up and skid (the only way for a malfunctioning brake to do that is if it locks up).
    you can, however, cause tires to go out of round if you leave your car sitting still for a long time, but we're talking reallllllly long time. like years.
  5. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    I'm going with hobbit's numbnuts explanation. Er. . . not meaning anything about hobbit, just that I think he is right that this probably happened when the car was dragged onto a flatbed tow truck.
  6. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    It seems doubtful to me that a single 20' drag onto a metal flat-bed truck would cause enough friction to flat-spot all four tires. Maybe a drag down the block would do it, but 20'?
  7. qbee42
    3,082
    I saw two brand new airplane tires flat-spotted from landing with locked brakes. That must of been surprising.
  8. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    No, this story doesn't add up. If the ABS is offline, the dash will light up and that is kind of hard to miss. It's also kind of hard to miss the effects of locked wheels
    Back in the day, I've had to slam the brakes to avoid cars sailing through red lights or stop signs, and a few times for deer. You lock the brakes at highway speeds, there is no f***ing way not to know it
    Plenty of sound effects and special effects, especially once you grind to a stop in a cloud of cooked tire rubber. Yes, locking all four wheels at highway speeds will flat spot them
    But to not notice that you've locked all four wheels? Even assuming - however unlikely the case - that there is no dash warning of inopperative ABS?
    Uh-uh
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    It it was a small plane, say a 150 or 172, that would be a good way to flip it over on landing
  10. qbee42
    3,082
    Cessna 150 with a nervous student pilot. The pilot was pressing hard on both pedals, inadvertently locking the wheel brakes.
    When the plane taxied back to the hanger, it went "whump, whump, whump" as it rolled over the flat spots.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Lucky for the pilot that only the tires got flat spotted. Easy enough to replace tires
  12. richard schumacher
    7,686
    1,068
    United States
    I'm going with the flatbed drag theory. The previous owner ran out of gas or killed the battery twice, had it dragged into a dealer both times, and then got disgusted with the car and sold it. I hope that you had a dealer thoroughly check it out at the last guy's expense before you bought it.
  13. CharlesJ
    CharlesJ Member
    467
    29
    Monterey
    Why would the wheels lock up if you run out of gas? Or a dead battery?
  14. Bill Merchant
    4,096
    87
    Electricity is needed to move the parking pawl out of the way. Every Prius has an immobilizer - no power, you're immobilized. You'll run out of power shortly after running out of gas. Wheels won't turn when the car is dragged (mostly on pavement, not smooth metal) and tire tread wears away.
  15. omo
    omo New Member
    Virginia
    Thanks for all your help, folks. Yes, I did take it to the dealership to have a mechanic look at it before I purchased it. The mechanic said there was a "vibration," and he thought the wheels needed to be balanced. Since the tires were new, he also recommended an alignment. He did not notice the flat spots.
    I still don't understand how the wheels could have locked up with anti-lock brakes. Could someone explain that to me? The ABS light is not on, so the car is giving me no indication that ABS is malfunctioning.
  16. edmcohen
    edmcohen Member
    133
    25
    Newark DE
    All the scenarios to cause this within 500 miles seem too unlikely for words. Even a brutal towing episode would affect two wheels, not four. This looks like a manufacturing/warranty issue to me.
  17. Joe 26
    Joe 26 Member
    242
    42
    Columbus, Ohio
    After owning a towing company for many years, and having to drag a locked up vehicle on a flatbed on several occaisions, I can say for certain that a 20' very low speed drag up a bed will not cause noticeable flat spots.
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    That did not happen.
    Here is how I managed to flat-spot all 4 tires, in the early 80's:
    I was going around 70 mph near St George, Utah, when a guy in the breakdown lane suddenly pulled into traffic. I mashed the brake pedal in the '75 Chevy Monte Carlo I was driving, and all 4 wheels locked up
    Lot's of nice sound effects from all 4 tires grinding into the Interstate. The driver of the other car appeared quite elderly and kept veering back and forth between the shoulder, the left lane, right lane, and back across to the left lane, as if thinking "why are all these cars behind me? Maybe I'll try to steer this way NO this way NO this way..."
    I missed him by a coat of paint and rust, and had nice thump-thumps from underneath.
    If the ABS isn't working, the dashboard lights up. If you had still locked up all 4 Prius wheels, you would have known about it from the sound effects.
    It didn't happen
  19. ksstathead
    ksstathead Active Member
    1,244
    245
    Kansas
    Maybe prior owner got the car in a sideways skid, taking ABS out of the equation.
  20. jayman
    13,439
    641
    Winnipeg Manitoba
    Could be, what was the option package again? Did it have VSC?
