Location of Transaxle fill plug?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GaryG, Feb 28, 2009.
  1. GaryG
    GaryG Junior Member
    Benicia, Ca
    I'm an idiot. Can't find it. Anyone have a picture or able to describe the location? Its a 2006. Any help is appreciated.
  2. Patrick Wong
    18,210
    6,517
    Hi Gary,
    Raise up the front of the car and support with jackstands. Look at the side of the transaxle facing the radiator, probably halfway up the side of the case. You'll see a hex head fill plug, needing a 24 mm (or 15/16") socket to remove.
    Make sure that you can loosen the fill plug before you drain the transaxle fluid. The drain plug requires a 10 mm hex key socket to remove. Do not remove the inverter coolant drain plug (which requires the 24 mm socket) by accident.
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
  4. GaryG
    GaryG Junior Member
    Benicia, Ca
    Thanks guys, much appreciated.
  5. tochatihu
    tochatihu Senior Member
    9,957
    3,845
    Kunming Yunnan China
    2001 Prius
    For others who stop my the other drain bolt w/o a red arrow (between and towards the left side of the photo) is where the electrical system coolant is drained. If you open that something red or pink will come out but it's not quite the same.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    That would be bad. You would have no choice but to scream many bad words.
  7. jayman
    13,439
    641
    Winnipeg Manitoba
  8. tochatihu
    9,957
    3,845
    2001 Prius
    With the shroud off (and a funnel and a foot of tubing), it is very easy to do the transaxle thing. Even DIY-ers who think they can only change cabin filters and engine oil ought to be thinking about this.
  9. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    A bit more than a foot of tubing if you're going to be sure of
    getting from above the engine/inverter to the front-side fill
    hole, but yeah, it's not that difficult. I made it seem a lot
    harder by going for the top plug when I went at my first try.
    'Bout time to do it again, in fact... if it ever stops snowing...
    _H*
  10. Patrick Wong
    18,210
    6,517
    As a "belt & suspenders" kind of guy, I'd suggest three feet of length from funnel top to the end of the tubing.
  11. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I'd also strongly recommend getting the correct tools for the plugs -- a 24mm socket for the fill plug, and a 10mm hex bit for the drain plug. It makes it much easier, and makes it unlikely you'll damage the plugs.
  12. tochatihu
    9,957
    3,845
    2001 Prius
    I bought 3 ft of tubing but cut it down to 1 (or maybe just a bit longer) to do the job. I can find out the length actually used, but it's not here. It's in New Mexico.
  13. Paul R. Haller
    285
    43
    Walnut Creek
