MFD fades to very dim during day with headlights on
Discussion in 'Gen 2 Prius Main Forum' started by mboneill, Feb 26, 2009.
  1. mboneill
    mboneill New Member
    Over the last 2 weeks I've noticed my MFD has gone to a very dim display when the headlights are on during the daytime (cloudy and snowing). Today the display appeared to be almost off. To my knowledge I have not chaged any settings to cause this. I have the control wheel at the dimmest position, which is where it has been for 2 years.
    The very dim is not there at first but fades in after a while (20-30sec). When I turn off the headlights sometimes I get the original brightness but others it is still dim. If the brightness returns to the original and the headlights are switched on the MFD again fades .I've checked other posts and the manual but can't determine the root cause.
  2. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    You say you've checked the dimmer knob on the left side of the wheel?
    Make sure it is rolled all the way up, it should have a little resistance when you try and put it in or take it out of its brightest setting. If this isn't it, I have nooo clue. Sorry.
  3. Neicy
    Neicy Member
    834
    Wakefield, MA.
    Have you adjusted the brightness in the settings on the MFD itself? I have changed mine when it is very bright to a brighter setting, and lowered it at night when driving in a very dark area. Sorry, but off hand I can't remember how I got there, but I think it was the "settings" button. (Or info). There is a separate adjustment for day and night. This should be in your manual though I thought.
  4. qbee42
    3,081
    Roll the dimmer all the way up to its BRIGHTEST position, not the dimmest position. It will click into place, and cause the MFD to return to daylight mode.
    Alternately, you can select Daylight Mode from the MFD soft button.
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Yeah, what they said....saves me the trouble of typing it out!!!
    You'll figure it out. Good Luck
  6. Oddest_raindrop
    Oddest_raindrop New Member
    75
    wisconsin
    If you press the display button there is a soft key on the screen for daymode or night mode. Night mode dims the display with the dimmer when ever the lights are on. This is either the headlights or running lights. day mode leaves the display bright no matter how the headlights are.
