Theft deterrent system light: always on when ignition is off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by JayGoldstein, Mar 2, 2009.
  1. JayGoldstein
    JayGoldstein Member
    120
    Winnipeg, Manitoba, Canada
    My Prius (w/ roughly 51,000 km) has the Smart Key System (SKS). According to the owners manual (corroborated by my experience), the indicator light for the theft deterrent system should not come on until a) the ignition is turned off and b) the driver's door is opened.
    As of yesterday morning, the indicator light has started to flash as soon as the ignition is turned off (i.e., without the driver's door being opened). The light continues to flash until the ignition is turned on. I noticed that when I exit the car and press the exterior lock button, the indicator light stays on for several seconds, and then resumes flashing.
    Coincidently, when I started the car yesterday morning (when it was about -20C), the high temperature warning light (which has never been on before) came on for a few seconds. I don't recall whether that light went out before or after the ICE started). That light has not come on since.
    I phoned my dealer's service department and was told that the issue with theft deterrent system light is not critical. They'll check it out at the next scheduled service. However, if the temperature warning light should come on again, I should bring the car in right away.
    Any ideas about why the theft deterrent system light now starts to flash as soon as the ignition is turned off?
  2. jdenenberg
    jdenenberg EE Professor
    3,957
    1,955
    Trumbull, CT
    2020 Prius
    LE AWD-e
    The periodic flashing of the "Theft Deterent" icon is normal operation in all Prii.
    JeffD
  3. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I'll snoop around the diagnostic flowcharts and see if I uncover anything
  4. qbee42
    3,081
    This sounds like auto paranoia, where you start noticing things that have been happening all along.
  5. Fraser
    Fraser New Member
    667
    Navarre, Florida
    Not just a Prius thing; our 2002 Taurus did the same thing, and I thought something was bad wrong. Had it checked; mechanic said we needed a new battery. Spent way too much money because we were in a not-at-home situation. Light still pinged when we turned off the engine. Turned out that was normal operation. Our Prius flashes the theft deterrent light when we shut down or even open the door, but I've never watched to see how long it stays active.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    It's not paranoia if your car really IS out to get you!
  7. qbee42
    3,081
    And it could be auto-paranoia if you think you are out to get yourself.
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    Hmmmm that does sound sort of vaguely kinky, in a naughty way ... baaaaaaaaaaa
  9. dogfriend
    7,512
    1,190
    Carmichael, CA
    Another sheep pun thread? Unbaaaaaleveable! :madgrin:
    On topic: I think the flashing is normal.
  10. JayGoldstein
    JayGoldstein Member
    120
    I've owned the Prius for 2.5 years, and I'll swear on a stack of Haynes manuals that until yesterday, the theft deterrent system indicator never came on if the ignition was off and the Smart key was in the car. Similarly, unlocking the door (from the outside) used to turn off the indicator; now the indicator continues to flash until the ignition is on.
    It's not just my imagination that the theft deterrent system is behaving differently than in the past.
  11. jayman
    13,439
    641
    Winnipeg Manitoba
    Jay
    Remember that I'm laughing *with* you, not *at* you, hence trying to make light of the topic. My Prius also behaves the same as yours, it probably has always done so
    "other" jay
  12. qbee42
    3,081
    Mine flashes when I'm in the car with the key fob. It goes out when I start the car.
  13. JayGoldstein
    JayGoldstein Member
    120
    Laugh, and the world laughs with you, question the operation of the theft deterrent system (TDS) indicator, and .......
    Logically, the purpose of the indicator light is show whether or not the TDS is active. If the indicator light flashes even when the car is unlocked (as it nows does), you can get a "false positive" reading (i.e., the TDS appears to be activated when it actually has not been). That seems to defeat the purpose of having an indicator in the first place.
  14. qbee42
    3,081
    The purpose of the indicator is to warn any potential car thieves that they are wasting their time breaking into your Prius. That's all it really does.
  15. JayGoldstein
    JayGoldstein Member
    120
    It seems to me that the TDS indicator should only flash when the car is locked. Suppose a) that you mistakenly think you've locked the car because the indicator is flashing, and b) a potential thief doesn't notice the flashing indicator and tries to open the door. The result is obvious: the thief gets into your car.
  16. jayman
    13,439
    641
    Winnipeg Manitoba
    Good point Jay, but my Prius behaves the same way yours does. I just never paid any attention until you brought it up.
  17. qbee42
    3,081
    That's not what it's for. It's not a car alarm, it's an engine immobilizer. The immobilizer doesn't give a rats nice person about someone breaking into your car, it just keeps them from driving away.
    As for someone mistakenly thinking their car is locked because the light is flashing, that's simply user error.
  18. jayman
    13,439
    641
    Winnipeg Manitoba
    Jay
    If it helps you feel any better, sit in the driver seat and scream the F Bomb at the flashing indicator. It can't hurt, and I swear the vehicle has more respect for you afterwards
    Respect = fear
    the "other" jay
  19. JayGoldstein
    JayGoldstein Member
    120
    Yes, the TDS is not a fulfledged alarm. However, the manual for my 06 states that the TDS is supposed to make the headlights flash and the horn honk if a locked door is opened (or the battery is disconnected) when the SmartKey is not present.
    I can verify from personal experience that if a thief breaks a window and reaches into the car w/o unlocking the door, the TDS ignores the intrusion. :(
  20. qbee42
    3,081
    The TDS and the engine immobilizer are two different systems. The flashing key is for the immobilizer, not the TDS.
    If you want the TDS to work against glass breakage, you have to add an optional sensor.
