Front end paint chipping- common or unusual so soon?
Discussion in 'Gen 2 Prius Main Forum' started by savannahsixt, Apr 20, 2005.
  1. savannahsixt
    savannahsixt New Member
    savannah, ga
    I have had my Salsa Red pearl for about a month now and while washing it this weekend I noticed I have several small chips in the paint on the front end. This being my first brand new car I am not sure if this is expected or if perhaps there is a defect in the hood paint job? Had I known I would get chips so soon I would have immediately put a bra on this car. i guess I figure if I pay 23 K for a car that the paint should hold up longer than 3-4 weeks before I get my first chip. Just a note I do drive 100 miles a day and often past construction sites. i am very careful not to get behind semis though.
  2. randalla
    randalla Member
    370
    Lexington, SC
    I think you probably answered your own question. You have a long daily commute and are constantly subjecting your car to the small stones/pebbles left on the road.
    There are inherent problems with using those front end bras that you should consider too. The paint on your car is subject to the effects of UV radiation. If you cover up a portion, the UV effects on the paint job will be uneven.
  3. jchu
    jchu New Member
    1,063
    Nampa, ID
    Some of us are looking at bug deflectors as an alternative solution to this problem.
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    im afraid what you have does happen frequently in your situation. i have one chip so far but its just above the left front headlight on the fender. and i heard it when it happened.
    kinda makes me mad because there was a truck hauling sand in front of me so i got 2 lanes over and was at least 10 lengths behind him when i heard the cracking of a rock hitting my car.
  5. savannahsixt
    savannah, ga
    I guess what bugs me is that I have never been directly behind a truck hauling anything and have never once heard anything hit the car like a rock. There are a ton of bugs plastered on the front and i wonder if they are causing chips as well.
    I never thought about the negative effects of a car bra but I think i would rather have that than have chips in the paint. What about clear bras-do they also effect the uv effects on the paint? Ive considered getting this but how do you wax a car with a clear peice of plastic attached to it without getting wax caught on the lip of that plastic?
    Finally, any thought as to how to repair the chips that are already present?
  6. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    I have resigned myself to the fact that in a few years i will have to have the front end and hood repainted. Even our Chevy Venture with bug defelctor still hass a lot of stone chips in it's 145,000 mi. and the hood will have to be repainted soon. At least the Silver on my Prius makes the touch up paint blend in better than the red on our Chevy Venture.
  7. Old n Bold
    Old n Bold New Member
    79
    Bellingham, WA
    Following trucks at a respectful distance helps but trucks going in the opposite direction are a worse threat. I have been driving for 5 years and have had 4 broken windshields in the last 7 years since moving to my present location. My last car had 4 windhelds in 7 yrs and my pickup now has a cracked windshield. All were from trucks going the other direction on a hard surfaced road.
    The place that changed my windshelds said that, in our county, the average life of a windshield is 2 yrs. Most are broken in the winter.
    By the way, I have a bug shield on the PU but it didn't help much.
  8. rookie
    rookie New Member
    61
    Frisco, TX
    There's no real way to avoid it all. All manufacturers use environmentally friendly paints now, it's not as it used to be.
    If your color can be touched-up with the touch-up kit from the dealer, go for that and use some Langka to get rid of the blob once its dry.
  9. jtowndog
    jtowndog New Member
    49
    Lomita, CA
  10. savannahsixt
    savannah, ga
    after seeing that I suppose I should be thankful that all that has hit the front of my car is a few small rocks.
  11. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    i have a front end mask. there are good and bad sides to it. my car's black so there's obviously the fade factor- although i much prefer fade differences to chips since the primer shows very well on black paint.
    the down side i've seen so far is the part of the mask that covers the lip of the hood can collect little sticks and leaves and things. i have started removing that part every time i wash, which is pretty easy. then i wash the cover, air dry it and replace it.
    some people insist on removing the whole thing each time they wash... but the bottom part is a pain to put back on. there aren't many bits of debris that can get underneath that thing anyway, it's on there so tightly.
    just my thoughts on the issue. :) you can see a pic of the front end mask installed on black in my album. good luck!
  12. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(savannahsixt\";p=\"82921)</div>
    Passing traffic often kicks up loose road debris. The noise made by the smaller stones that hit your car is muffled by tire, wind and other traffic sounds.
  13. Sufferin' Prius Envy
    3,998
    I too have chips . . . even on the sides, on and near the back door. :x
    http://www.chipmender.com/
    The same stuff I see on the counter at my dealer. I’m just waiting for the inevitable next few chips so I’m not constantly chasing one-zies and two-zies.
  14. jtowndog
    jtowndog New Member
    49
    Lomita, CA
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy\";p=\"83139)</div>
    The same stuff I see on the counter at my dealer. I’m just waiting for the inevitable next few chips so I’m not constantly chasing one-zies and two-zies.[/b][/quote]
    That looks like it's worth a try. I could never do a decent job with the brush in the bottle types.
  15. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    <div class='quotetop'>QUOTE(savannahsixt\";p=\"82841)</div>
    Rather than a bra, which will inevitably scratch the paint, you might consider a hard plastic rock and bug protector which you can order from Toyota Town in Langley, BC, or elsewhere. Not sure if it's sold in the US. I got one and mounted it (not difficult, but does take some careful centering) and have had great results. It sits on little gummy feet which are affixed to the hood with a kind of removable adhesive so they won't damage the paint. The feet keep the guard off the painted surface, so it won't scratch the paint the way a fabric cover would. The bug/rock guard covers the area between the headlights, just above the grill opening, where most of the gravel, etc will likely hit. It's a dark almost black plastic, so it will fit with any color. There is one in the album section shown on several cars.
    Bob
  16. reesdude
    reesdude New Member
    67
    San Fernando Valley, CA
    I've had my prius go through hail and jumped on by a goat a few times and only left surface stratches. the worse is done by rocks and although I wouldnt get a bra, touch up paint should work well, I dont know if they would have it in salsa red though
  17. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    After reading the many postings here at PC, I have made an almost daily effort to keep the car washed and waxed. I wax the front end and the front of the side mirrors.
    The front bumper and hood both have nicks from stones - hard to avoid even with consistent cleaning, waxing and avoiding hazardous "stony" situations. At some point will have to repaint the front end - bumper and hood. I have a bra on order.
  18. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(reesdude\";p=\"83159)</div>
    They stock every Toyota/Lexus color since the 1997 model year. . . including Salsa Red (or else I would have been mad and not posted their link.)
    They also stock every Honda and Acura colors from 1999 through the current year.
  19. reesdude
    reesdude New Member
    67
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy\";p=\"83202)</div>
    oh I didnt know... maybe if I get enough I can turn my white into seaside or salsa. lol just kidding super white rocks.
  20. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    I noticed a few paint chips on the hood, plus some cuts and one manufacturing-related dimple in the bumper while washing the car last evening. Nothing awful, but now I'll have to wonder what cut into the bumper material like that, when I don't recall hitting anything and the cuts don't look like another car hit me.
    I might get some touchup paint, but past repairs have shown I haven't got the right touch so the job isn't noticeable. Not sure I'll pay someone to do it until it looks necessary...
