'09 Package 7 - SEVERE Radio Volume Issue
Discussion in 'Gen 2 Prius Audio and Electronics' started by gobanzaii, Dec 24, 2008.
  1. gobanzaii
    gobanzaii New Member
    Minneapolis, MN USA
    I have an '09 package 7 and have had NO issues with it since the day I picked it up this fall....until this week.
    Over the past 4 days I have had 5 instances when driving and listening to the radio the volume instantaneously jumps to the highest level. Not only does it blow out my eardrums but is scared the crap out of me so badly the first time it happened I almost lost control of the vehicle (with the kids in the car)
    I am not talking about a slow roll up to the highest level...i am talking about listening to low-volume radio and getting blown out.
    Has this happened to anyone else? Self-fix issue? Dealer service issue?
    Thanks!!
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It's under warranty ... take it back to the dealer.
  3. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    There's nothing you can do to fix it -- the dealer will have to swap out the radio.
  4. ArcticPrius
    ArcticPrius Prius Owner
    61
    I have never heard of anything above Package #6 for the 2009 model year.
    Can somebody maybe inform me of what is above package #6 for 2009?
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Package 7 includes machine gun, ejector seat, and can spray oil.
  6. Gilbert
    Gilbert Member
    255
    Good luck with dealer, ive taken my car to the dealer to check several things and they can never find anything wrong.
  7. PeakOilGarage
    PeakOilGarage Nothing less than 99.9
    334
    Pacific Northwest
  8. geogin
    geogin New Member
    slc, ut
    This happened to me several times but the dealer wouldn't do anything about it because they couldn't replicate the problem, but finally I got it into the dealer while it was doing its mind blowing noise and they replaced the radio. Two weeks later it's doing it again. I don't know what they'll try next. My friend rented a Prius and the audio had the same problem so it's not a unique problem, but what fixes it?
  9. geogin
    geogin New Member
    slc, ut
    I had the same thing happen to me several times but the dealer wouldn't do anything about it because they couldn't replicate the problem, but finally I got it into them while it was doing its mind blowing noise and they replaced the radio. Two weeks later it's doing it again. My friend rented a Prius and the audio did the same thing so it's not a unique problem, but what fixes it?
  10. Patrick Wong
    18,200
    6,500
    There are only two possibilities: either the radio control unit mounted in the instrument panel, or the JBL amplifier mounted under the front passenger seat. If the radio control unit was replaced but the problem remains, then the JBL amplifier is the likely suspect.
  11. cwy
    cwy Junior Member
    Tustin, CA
    My fellow coworker ('06 JBL system) has been suffering from the exact same issue. She hasn't seen the dealer since it's well outside the factory warranty period. At least I can report back to her that her Prius is not the only one to suffer from this problem.
    Hopefully someone out there figures out the correct fix soon.
  12. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    I'm occasionally seeing a problem where the volume control does nothing, or just toggles between two levels (15-14-15-14-15-14) as it's being turned one direction. The steering wheel controls work fine when it's doing that.
    I dread trying to reproduce it for the dealer though, since it's intermittent.
  13. geogin
    geogin New Member
    slc, ut
    They replaced the amplifier under the front passenger seat and I've gone 200 miles(much longer than I've ever gone) with no problems so I'm hopeful the problem is fixed.
  14. mythlady
    mythlady New Member
    Capitola, CA
    I've had this problem since my '06 was new. It never happens when I take it to the dealer, just on my close-to-two-hour commute, when it goes up and down and up and down until I have to turn the radio off. Gaakh.
