NO SAMSUNG phones work with Toyotas!!!
Discussion in 'Gen 2 Prius Audio and Electronics' started by kellsworthington, Feb 27, 2006.
  1. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    Re: NO SAMSUNG phones work with Toyotas!!!
    Since you haven't tested every phone Samsung makes that's a pretty bold statement to make.
    I have a Samsung a900m on the Sprint network, and I use it with the Prius bluetooth all the time. It paired very easily. My only complaint is that I couldn't bulk upload all my contacts, it would only upload them one at a time.
  2. snead_c
    snead_c Jam Ma's Car
    667
    58
    Hendersonville
    My Samsung Gleam works. :confused:
  3. thedutchtouch
    thedutchtouch prius is my SUV
    181
    Baltimore MD
    anyone tried a samsung omnia from verizon? i have my eye on it to replace my motorola Q (the original), which works fine with the prius (although battery life stinks w/bluetooth)
  4. gussom1
    gussom1 New Member
    36
    SFV
    My wife has the blackjack II and works fine in 07 and 05, ATT is the carrier
  5. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    except for the battery level and signal strength on mfd, i got my samsung sync to work with my car just fine. the thing i hate about at&t/cingular is that unless you have an iphone or a PDAor a pc card, you won't get any software updates. in the last 9 years or so i have been with cingular i have never gotten any firmware from them. i have had a couple cheesy nokias. one of my nokias would lock up at 12:01am on the dot, if you had any unread text messages in your inbox. i tried calling cingular and nokia about it but i eventually got sick and end up recycling the phones.
    i currently use a lg vu c920. u can get them on amazon for 1 cent on a at&t contract renewal
    still no battery meter or signal strength on mfd
  6. tcooper185
    tcooper185 Member
    122
    Rock Hill, SC
    My Samsung Upstage from Sprint worked great with my 2008 Camry. Granted, not the Prius, but they use the same radio suppliers.
    Just not sure the "Doesn't work with Samsung" statement is totally factual.
  7. Roger..
    Roger.. New Member
    Frederickson, WA
    No problems with my Verizon Samsung Sway (U650). Previously had a 1st Generation Motorola Razr with Verizon.
  8. midimal
    midimal New Member
    Hamburg
    Hi
    Omnia 1 worked very well (over BT) during my test ride.
    Midimal
  9. jaywolf
    jaywolf Member
    107
    Vincennes, IN
    Same here my SCH-i760 connects blue tooth for both phone and MP3. It transferred all my contacts it seconds and I have over 6oo numbers in my phone/PDA. I can voice dial any of the numbers in the car without any problems my car is a 2010 Prius.. Last 3 phones/pda I have had have been Samsung, noe a problem I kept my older on I730 for 4 years.
  10. Ron K
    Ron K Junior Member
    61
    Yorba Linda, California
    Ok, for all you you with a Samsung phone and trying to pair with the Prius.
    I have a new Samsung Sunburst and it wouldn't pair. I tried over and over.
    Then finally got it to work (at least to pair and make a call, I haven't tried transferring phone book entries yet.
    The Geniuses at Toyota left out an instruction. The Field "name" has to have an entry on the car's pairing screen. Once it has an entry, the Sunburst immediately paired.
    Time for a drink!
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    My Samsung SPH-M520 (from Sprint) worked fine w/my Prius until the phone was stolen.
