April 2005 MPG Averages<img alt="" src="chrome://easygestures/skin/xLink.png" style="border: 0px non
Discussion in 'Gen 2 Prius Fuel Economy' started by Tideland Prius, Apr 2, 2005.
  1. BoBraxton
    BoBraxton New Member
    82
    Fairfax, VA
    Re: April 2005 MPG Averages
    Third day after driving TO work about 17 miles, display is 57.7 mpg, climate control set about 76 degrees always on, morning temperatures in 50's F and afternoon in 80's F
  2. BoBraxton
    82
    Fairfax, VA
    After driving 17 miles TO work fourth day 58.9 mpg (P* power train not yet broken in).
  3. raintree
    raintree New Member
    22
    Richmond, VA
    Second tank of gas this morning, temps in 50s in am and 80s in pm.
    415 miles
    8.537 gal
    48.6 mpg by calculation
    Chicken to let the fuel meter go below one bar, I've read too many posts about running out of gas!
  4. jimofdg
    jimofdg New Member
    533
    DG, IL, US
    Thought I'd refuel just after an oil change and first tire rotation ($55 at Toyota dealer near me).
    Tank Miles: 373.8
    Total Miles: 6040
    Tank MPG: 54.4
    Lifetime MPG: 44.4
    Avg Temp: 60s (but frequently above)
    Price of Tank: $15.73
    Price per Gal: $2.29
    Techs meant well in inflating my tires to the 40/38 I requested, but I guess the tires weren't cool enough. I later measured them at 37.5/35.5 and adjusted the pressure when cold.
    Tire rotation seems to have helped. I had a messy stain on one of the rear wheels and wondered how hard it would be to clean. It wasn't hard, but it *was* somewhat easier to reach once the rear tire became a front tire. My Nav screen is very clean now that I have tried a KlearScreen that I use on my computer and TV screens.
  5. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Almost got my first 500 mile tank. Just filled early due to rain! Filled at
    one bar point, not flashing.
    Tank Miles: 495
    Total Miles: 4534
    Tank MPG: 54.4 calc 53.5 computer
    Lifetime MPG: 42.3
    Avg Temp: 35-40 deg F start of tank then 40-70 deg F end of tank.
    Fill up 8 gal to click. 9.1 total
    Mileage helped this tank by snow tires coming off. Hurt by 5 to 10 mile trips but a lot less now that it is warmer. Still see 20-30 mpg sometimes for first 5 to 10 minutes.
  6. micheal
    micheal I feel pretty, oh so pretty.
    842
    Lubbock, TX
    A good tank for April!
    463.3 miles
    9.542 galls (stop after first click) at $2.089 per gallon
    48.55 calculated
    48.4 MFD
    Avg temp is probably somewhere in the high 60's.
    Hampered as usual by multiple daily trips that are less than 5 minutes in duration, but with longer trips after fill-up MFD says 53.1 after 50 miles or so.
  7. mcsmith
    mcsmith New Member
    SF Bay Area
    A good April tank. Actually a March/April tank; 32 days between refills.
    Last pip blinked at 625
    Tank miles: 654
    Gallons to refill: 10.436
    Avg. mileage (display): 60.9
    Avg. mileage (calculated): 62.67
    Total miles at fillup: 4792
    Lifetime mileage (calculated): 48.58
    The following photo shows the MFD shortly before refilling. I was a little too close for the camera's focal length. :(
    Do the mileage bars seem to be sending a message to OPEC?
  8. Ray Moore
    Ray Moore Active Member
    857
    52
    Yay McSmith!!
  9. micheal
    842
    Lubbock, TX
    <div class='quotetop'>QUOTE(mcsmith\";p=\"83841)</div>
    Great tank! Now I have MPG envy!
  10. Tideland Prius
    16,615
    :crazyeyes:
    :iagree I want that kinda mileage hehe.
    But damn, that's nice! Congrats mcsmith!
  11. sdgeiger
    sdgeiger Junior Member
    97
    Phoenixville, PA
    Mcsmith, do you drive mostly in the city with heavy, slow moving traffic? I live in the suburbs outside of Philly and there is no chance I'd ever get 654 miles on a tank of gas unless I was driving throughout Philly everyday, which is where I get my best gas mileage.
  12. mcsmith
    mcsmith New Member
    SF Bay Area
    My commute is about 14 miles in each direction. Historically, I've taken an interstate (I-280) route; 10 miles freeway/4 miles surface streets. Using this route, I'd been getting tanks in the 48-50 MPG range.
    For this tank, I experimented with using an alternate route, replacing I-280 with El Camino Real. (For those not familiar with the area, El Camino is a six-lane state highway that's heavily populated with commercial development. Speed limits range between 35-40 MPH along the segment that I travel.) This new route takes about an extra 7 minutes, each way.
    The lights are fairly well timed, but could be better (listening CalTrans?). I can sometimes go a couple of miles between red lights. Once the engine comes up to temperature, I can feather the car frequently and maintain a speed near the speed limit. Coasting goes a long way. It's not uncommon for me to average 75 MPG for the 15 minutes or so that I'm on El Camino Real.
    It's also amusing to repeatedly see the same cars for miles at a time as they race down the road only to get to a red light, and wait while I catch up to them. :) Too bad there isn't a MPG display on the rear bumper for others to see. ;)
  13. sdgeiger
    97
    Phoenixville, PA
    So I'm guessing that you don't experience many hills either, do you?
    In my area near Philadelphia, I travel 5 minutes climbing a hill, which kills the MPG. Once I level off, there are more hills to climb.
    I'm going to see if there are some back roads that I can travel that aren't as hilly.
  14. mcsmith
    mcsmith New Member
    SF Bay Area
    The net change in elevation is about +100 feet (work higher than home). The highway route has more changes in elevation (maybe up to 500 feet at the highest). The route taken on the last tank is almost perfectly flat, except for the last 1/4 mile (the office building is on a hill side).
  15. sdgeiger
    97
    Phoenixville, PA
    <div class='quotetop'>QUOTE(mcsmith\";p=\"84036)</div>
    That makes sense, based on your MPG results. Mostly flat roadways in heavy traffic seem to be the best. I'm fairly certain if I lived and worked in Philadelphia that I'd get similar results are you did.
    I'm convinced that the suburbs is the worst for fuel conservation.
  16. Che
    Che New Member
    44
    Raleigh, NC
    Ummm, my wifes 04 average is currently about 53. Oddly enough after about 15,000 miles and a year of ownership we have averaged spot on 52-53 year round.
    After about a month of ownership on my 05 I have averaged 53 just like my wife's car. We both have similar defensive, patient driving habits so I guess this is normal.
    We live and drive in the humid southeast and a years driving of the car has resulted in the following max fuel economy habits:
    thermostat settings:
    summer 76
    winter 68
    long slow braking
    accelarate and or coast on any downhill if possible and vice versa
    dont roll down the windows at higher speeds
    48 mph is the best speed and anything over 66 and the MPGs plummet.
    some of these I suppose are blatantly obvious and others have to be used in moderation or you really start pissing off other drivers. But if you always go the speed limit or slightly slower and stay in the right lane on the interstate you hardly ever have to come off of cruise control!
  17. Edgar1955
    Edgar1955 Junior Member
    Middletown, CT
    I purchased a new 2005 Prius the last week of March and I'm loving the fuel economy economy. I already made the mistake of running out of gas trying to get 500 miles on a tank fill only to have the bladder explained to me. Here are my results for that week;
    Tank Miles: 477 miles
    Tank Fill: 9.30 gals.
    MPG: 51.3
    Lifetime MPG: 49.4
    Lifetime Miles: 813
    Avg. Temp. 49.7 deg. F
    This was for April 1st thru April 15th in Connecticut. I've got a nice 20 mile drive to work that allows the car to warmup. The only reason I don't get 50 mpg consistently is due to the short trips around home and on the weekend when the car doesn't have the time to warmup properly.
  18. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    I let my husband take the car for a day. The MFD average went from 47 (short commute, still not too bad) down to 43.
    I haven't been able to get it back to over 44 with my short trips every day, I was just managing to keep it at 47 before he took it. :(
  19. jimvitz
    jimvitz Junior Member
    94
    Oak Park, IL
    Tank Miles: 475
    Total Miles: 16542
    Tank MPG: 59.2
    Lifetime MPG: 54.2
    Avg Temp: 50's
    Price of Tank: $19.03
    Price per Gal: $2.39
    When the warm weather returns for good, the coveted 60 mpg mark should be attainable!
  20. Rollerblade
    Rollerblade New Member
    26
    Tillsonburg, Ontario
    Will the computer readout show lifetime driving average? Now have driven 2,600K. If so, how do I access this info? The MPG (litres per 100K) resets at each fill.
