Another oil company trick?
Discussion in 'Gen 2 Prius Main Forum' started by calpal, Mar 10, 2009.
  1. calpal
    calpal New Member
    52
    Here in NJ It costs 75 cents to put air in the tires. And that's if you can do all 4 tires in less than 3 minutes. It used to be free. The oil companies know they'll sell more gas if people don't go to the air pump. Gee how clever they are!
    There should be a law that mandates free air at gas stations.
  2. john_dough
    john_dough New Member
    75
    there is----in Russia.
  3. PriusForThePeople
    113
    United States
    Actually, my local Mobil station has free air, and I know there are other places around where you have to pay for the air, but the one I go to is free...
  4. ewhanley
    ewhanley New Member
    247
    Anchorage, AK
    I doubt it is part of any grand conspiracy. I have seen free air and coin operated air at different stations in many towns.
  5. JSH
    JSH Senior Member
    2,605
    140
    PDX
    Air pumps were installed at gas stations for your convenience. Some stations have them some don't. Some stations charge for their use and some don't. If you don't like paying $0.75 for 3 minutes buy an air compressor and air up your tires at home.
  6. qbee42
    3,079
    Go back to paying full service rates for gasoline and maybe the stations will feel they can afford free air. I remember when gas stations would fill your car, check the oil, wash the windows, and give you a free glass when you filled up.
    Market pressures that drive down cost often also drive down service.
  7. taggart
    taggart Member
    249
    I have found that all of the stations I used to go to will turn it on for free if asked, even when the pump requires quarters to turn it on. Just ask.
    I now own a compressor, but realize this may not be practical for everyone.
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    Also, in California. And we aren't all communists yet.
    You often have to ask the station to turn on the compressor for you, but if you are a paying customer, they are required to provide air free of charge. Of course, some stations are able to skirt their responsibility by making sure the air compressor never works. :madgrin:
  9. brick
    brick Active Member
    1,083
    79
    Upstate NY
    We have free air at a few stations. Last I checked the air hoses had been sliced off at each of them.
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The Shell station in Burlington has free air. Buy a compressor, stow it under the deck & plug it in your aux power port whenever you want. Chances are the oil company doesn't own or run the station.
  11. fredthepostman
    422
    boothwyn pa
    This is one of the many reasons that I am waiting for the plug -in Prius.
  12. fuzzy1
    10,599
    A hand-powered bicycle floor pump is cheap. And much more convenient than going to a station to top off the tires.
    I have a 12V electric pump too, but find hand pumping quicker and easier than coiling and repacking the cord of the electric pump.
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    I use a 7 gallon air tank purchased from Wal Mart a few years ago. It was fairly cheap, around $20 or so. Tank has a gauge and hose attached.
    I don't have to add much air to the Prius tires, they hold well.
    But, I can top off the tires at home a number of times before I need to refill it to about 120 psi. There is a 76 station nearby whose air hose is almost always working.
  14. toyota_yota
    toyota_yota New Member
    Conspiracy theorist are we?
    1. Large air compressors cost money.
    2. Running these compressors is not cheap
    3. Giving away goods at a loss is a government job, not private company
    Would you leave your hose out by the road for anyone to wash their car? :p
  15. patsparks
    10,664
    567
    Adelaide South Australia
    You have to pay to breath while you fill up? How odd!
  16. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Do what I did years ago. I purchased a 12V air pump. Got lucky and bought one on sale for $14. I carry it with me wherever I go and use it once a month to top off the tires. It has long since paid for itself.
  17. turnbowm
    turnbowm Junior Member
    So. Calif.
    "A hand-powered bicycle floor pump is cheap. And much more convenient than going to a station to top off the tires."
    I also use a bicycle pump and always check/adjust tire pressure in the morning before the car has been driven.
  18. qbee42
    3,079
    Don't forget to put an in-line nitrogen filter on your bicycle pump, so you can "nitronize" your tires when refilling. :rolleyes:
  19. dogfriend
    7,512
    1,190
    Carmichael, CA
    OMG, thanks for that idea! I'm going to need a source of income when my unemployment benefits run out. I will sell a bicycle pump on Ebay with a filter attached to it to "Nitronize" the tires. My filter will feature the latest nano filtering technology. It will improve the mpg by 10% and HP by 25%. I'll kick you back 1% of the profits for giving me the idea. :madgrin:
  20. Qlara
    Qlara New Member
    488
    Free air pump or not, I don't think this has anything to do with the oil companes.
    It's on discretion of the Gas Station owner to provide free-use or charge of air pump.
    Yea, running these large pumps are not 'free' and they do suck up some kWatts to run. But the conspiracy logic should be reversed: You do sell more gas if providing Free Air-pump, because mostly everyone likes to stop by pumping tires and do fill-ups too, since they're in the gas station already.
