Scmutz On Dashboard Display
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by emeticmedic, Mar 2, 2009.
  1. emeticmedic
    emeticmedic New Member
    Rochester, NY
    I just picked up this Prius the other day and had it taken somewhere to be cleaned inside and out. I noticed that the dashboard display window looked somewhat smudged, so I cleaned it with a little Windex. That part seems clean now, though it sounds that perhaps Windex is not the thing to use because it could fog the plastic.
    Looking at it now, it appears that there is actually some residue behind the plastic, inside on the display itself. It's hard to tell, but I'm wondering if that can be cleaned up. Do I have to take it to a dealer for that? I'm not even sure how that part would get dirty.
  2. Patrick Wong
    18,210
    6,514
    Have you noticed that the dashboard display is really reflected; and that the projection window is visible if you stand outside the car by the driver's door and look down at the dashboard?
    Perhaps if you clean that window, then the display will look OK again.
  3. dogfriend
    7,512
    1,190
    Carmichael, CA
  4. emeticmedic
    Rochester, NY
    I just noticed that last night while walking around the front of the vehicle. I've only had it a few days and there is so much to figure out. Thanks for the tip. That should probably take care of it.
  5. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    CAUTION: The MFD is dim (and a bit cloudy) when COLD (as is the case the last few days here). Don't let that "issue" send you down the wrong path. :)
  6. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    Scmutz is spelled "Schmutz". :)
  7. EJFB1029
    EJFB1029 New Member
    4,726
    206
    Corpus Christi, Republic of Texas
    Actually I think its SMUDGE. LOL
  8. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    Actually Scmutz is spelled Scmutz. Schmutz is spelled Schmutz. :)
  9. beamman
    beamman New Member
    Palos Verdes, CA
    I noticed this on the used Prius I just bought about a week ago. Would cleaning these lenses and windows with one of those wipes they have for flat screen TVs be a good solution?
  10. beamman
    beamman New Member
    Palos Verdes, CA
    Actually, went ahead and tried LCD display wipes (which I got from some sale bin at my local Fry's Electornics a little while ago), and seemed to work nicely.
  11. tasker109
    tasker109 New Member
    147
    Illinois
    Schmutz (also shmuts, (shmŭtz or shmootz) is a [ame="http://en.wikipedia.org/wiki/Yiddish"]Yiddish[/ame] word of direct [ame="http://en.wikipedia.org/wiki/Germany"]German[/ame] derivation. It can be a noun, a verb, or an adjective.
    As in the original German, its use in Yiddish as a noun can designate a range of types of unpleasant substances from any kind of soil such as mud or dust to thick or ground-in dirt such as soot or grass stains. More strongly, and less accurately, it's used to indicate a particularly foul or repulsive matter such as animal waste, or poop, or the fuzzy stuff found growing in the jar way at the back of the fridge. A Jewish comic once raised schmutz to the exalted status of “dirt that moves.”
