Got a Question on rear bupper protector
Discussion in 'Newbie Forum' started by boppo, Mar 14, 2009.
  1. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I just picked one up at my local toyota dealer for 23.00, which I figure was a good deal. I would like to know what you guys used to clean the paint before you stick this bad boy on? I have acetone but think that might be too strong, maybe rubbing alcohol.
    Thanks,
    boppo
  2. danl
    danl New Member
    231
    Boston, MA
    I just wiped it down with a wet cloth before sticking it on.
  3. Patrick Wong
    18,200
    6,492
    I suggest that you carefully read the instructions; I ruined the first one that I tried to put on, so then I had to use another (and these cost more than $23 each, at the time.)
  4. Tripod137
    Tripod137 New Member
    145
    Long Island
    I put mine on shortly after I got the car, so all was new/clean. I just used some warm water and a towel. I would suggest to clean the car well (by hand...not a machine car wash) and dry off and apply.
  5. Eyelawdoc
    Eyelawdoc Junior Member
    Palmdale, CA
    Clean the rear bumper with soap and water. Rinse. Dry with a clean, relatively lint free towel. Then clean the area with rubbing alcohol and allow to air dry well before application.
  6. boppo
    boppo Active Member
    799
    139
    Owego, NY
    pat, no instructions, it just came in a toyota bag.
    boppo
  7. boppo
    boppo Active Member
    799
    139
    Owego, NY
    thanks for your reply.
  8. boppo
    boppo Active Member
    799
    139
    Owego, NY
    eyelawdoc, I think I will go with your suggestion as soon as it warms up around here.
    boppo
  9. Mickey9201
    Mickey9201 Junior Member
    25
    Jax, Florida
    Anyone try using claybar to get all the impurities out of the paint first?
  10. patsparks
    10,664
    567
    Adelaide South Australia
    Alcohol. You should always clean with alcohol before applying double sided tape to any surface to remove waxes.
  11. boppo
    boppo Active Member
    799
    139
    Owego, NY
    patsparks, so if I use a little on the bumper and a little for me I should be able to get it on right. :)
  12. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I jsut claybarred the rear bumper area where it was going to be applied. Clay bar removes impurities as well as stripping any wax on the area. Then just applied it. It's been on for 16,000 miles so far. I'm starting to get a bulge across the middle of it so I may remove and reapply 3 strips of double sided tape to replace the original 2 and add one more down the center.
