It should have Rolled.
Discussion in 'Gen 2 Prius Main Forum' started by nickfromny, Mar 18, 2009.
  1. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    2009 touring in cruse at 73mph on highway driven by my 17yr old. She drifted off highway to left and hung a wheel off the concret onto the lower blacktop shoulder. We were passing a tractor trailer. Her rookie reaction was to snap it back onto the highway. She did not touch the brake. Car snaped into a wild ride with 3 different sidways slides down the freeway and shoulders. We ended up off the right shoulder in tall grass. It should have rolled. Car restarted and we drove it home. Had about 40lbs of dirt in under carrige, 2 wheels lost their balance weights, lost right rear mud flap, have some lower right body scrapes with shoulder (yes that is how far tipped over we were). She will be practicing with SCCA driving school shortly. She has now found the brake peddle. :eek:
  2. Doc Willie
    1,717
    144
    Out there, somewhere
    Uhhhh. Stop right there. 8 miles over the speed limit. 17 year old with parent in car.
    What is wrong with this picture?
    Yer lucky to both be alive.
  3. qbee42
    3,079
    I can't add to the Doc's comment except to say Wth?
    My daughter lost control on an uphill patch of ice on a two lane road. She managed to parallel park our van on the opposite side of the road, 180 degrees from the direction we had been traveling. The slide packed so much gravel into the tire bead that I had a flat tire the next day.
    Ah, kids and driving.
  4. PriusForThePeople
    113
    United States
    Wouldn't be so quick to judge. Speed limit on some roads is 70, even 75 in some spots. I know in Florida there are roads that go up to 75. So she could have been driving on 3 over, or even 2 under. We don't know, that information wasn't provided.
    irrational likes this.
  5. nickfromny
    309
    24
    Binghamton, NY
    Doc & Tom
    Rt 88 is newest interstate in USA. It is Wide open and very straight. Traffic is usually rolling in excess of 70mph. Post was to let members know the car was amazing in that it did not roll. Tires were Conti snows inflated to 42f/40r. The high pressure prolably helped keep the car upright. I really did not need a Wth after a near death experience. When was th last time you went 8mph over the speed limit?
  6. PaulHS
    PaulHS Member
    200
    SE PA
    Nick, your points are well taken. You all were extremely fortunate, and it's comforting to think that the Prius had something to do with your safety. By the same token, I think the situation was a learning experience for both father and daughter!
  7. qbee42
    3,079
    About a decade ago, and then I didn't know the speed limit on that road. I realize I am an exception in that I actually follow traffic laws, even the ones I don't like and find inconvenient.
    The Wth wasn't for the speed, it was for allowing a student driver to get into that situation. I don't blame the student, I blame the instructor. There is no reason to risk the life of a student and the lives of other drivers nearby by allowing a student to attempt a maneuver for which he or she isn't ready. The abrupt pull back onto the road clearly demonstrates that the student driver wasn't ready for this sort of driving.
    I understand that the experience was scary, but you have no one to blame but yourself. It's good that the Prius stayed on the ground.
  8. PriusForThePeople
    113
    United States
    It's not like it was a planned practice test for the student driver. They didn't go on the road that day planning on running off the road. If the student driver does not know how to drive on the highway, or heavy traffic road, as I suppose this is, then how will they ever learn?
    The point I'm trying to make here is that it's not like Nick planned this to happen to see what his daughter would do, it was an accident, they happen to everyone. When you say "allowing a student to attempt a maneuver for which he or she isn't ready" NO ONE is ready for their first "think-on-your feet" moment when you're driving, especially a student driver. And yes, perhaps it wasn't handled with the best actions but the important thing is that they're both ok.
    To sum up, I'm glad you're both okay. It's a lesson. Life's all about lessons.
    Moral: She knows what to do next time, hopefully there won't be a next time, but at least she knows how to handle it.
  9. nickfromny
    309
    24
    Binghamton, NY
    Tom,
    She is not a student. She got her license over a year ago. Has driven for many years. Has been exposed to SCCA racing, driving at Watkins Glen, and ice covered roads her whole life. She Ski races at speeds in excess of 70mph. This was a split second reaction that almost killed us. Point is Car preformed better than I expected. There is no blame. So stop throwing salt into this wound.
  10. PriusForThePeople
    113
    United States
    Okay... let's just let by-gones be by-gones. Important thing is you're both okay!!! :)
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Jeez that sounded really frightening. Very lucky! That usually results in a multi multi car wreck down here in the land of I can't drive to good so I keep my left turn signal on all the time and drive really really fast. Do that on I-75 here and you'll get run over by 3 tractor trailers doing 85.
    I wonder how our cars would do on a roll over. I don't want to find out though. Not so good I bet. Lots of airbags for regular impact but all bets are off when your rolling. Man that would really hurt.
    Your post did make me immed. think of that part in planes-trains-automobiles where they ended up going on the wrong side of the road. Where they look at each other and see skeletons.
    Glad your both ok.
    BTW, down here in Florida off the highways there's lots of swamps and deep drainage ditches. I got me one of those window breaking hammers in the car for just this episode: End up upside down in the water....car dead...windows up..door won't open.....need to break window.
    You never think it can happen to you.
  12. dogfriend
    7,512
    1,190
    Carmichael, CA
    VSC was designed to keep the car pointed forward as best as possible. That is probably what kept you from rolling.
  13. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    it sounds like VSC saved your life.. or the life of your car.. and your wallet
    vehicle skid control watches the direction of the cars rotation according to wheel rotation and re adjusts according to driver input... so if you're trying to turn in gravel at high speeds.. the system wacks out and turns too sharp every time.. making the car skid sidewards most of the time (i've tested this)
    ... it's hard to get a prius to roll... i'll leave it at that.. i would almost go to say it's pretty impossible for what 99% of prius owners will put their car though.
  14. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Whew!!
    From experience, I'll say that you can be told how to react and what to do and you can know what to do. There are very few adults who can get to the point of knowledge without experience. Teenagers simply can't do it. When I was 17 I had a similar incident, though I was driving across a bridge under construction -- no nearby traffic. Leaving the foot off of the brake was the right thing to do -- except that a brief tap may have been enough to disengage cruise control. The typical driver will not allow the car to slow down enough before trying to get back on to the main pavement. I thought I knew how to handle it when I was 17! I ended up doing a 360 spin all within the single-lane construction zone. Just a bit more over correction and I would have gone into the river.
    I am glad you are sharing this so we can learn about the real safety features of the Prius and its VSC. I know you have lost enough sleep, hair and months off of your lifespan, so I won't try to pile on any blame. Still, I would hope most people will not let young drivers get into such situations. Your daughter appears to have had more training and driving experience than most 17-year-olds. Even so, she is a teenager and does not have enough experience to be passing a big rig at such speeds and on cruise control.
    I am VERY glad you both survived this experience with greater knowledge and very little damage to the car -- and no damage or injury elsewhere. Great news!
    OK, I'll confess I'm also an obeyer of laws and I don't speed. I obey the speed limits because of safety, economy and . . . the fact that speed limits are the law.
    OK, OK. Further confession: Yes, I will go over the posted limit if I am going down a hill. I won't use the brake to bleed speed if it happens to take me up to 60 in a 55.
    I feel better now.:focus:
  15. bwilson4web
    16,313
    Just reading it ... Oh my gosh!!!
    When I was 17 years old, a high school junior driving our International Harvester Travellall at ~80 mph (Kansas Turnpike in 1967,) with the family, the right, front tire blew-out. I just pushed in the clutch and continued to steer and let the speed bleed off until I could pull onto the shoulder. Mom was a little anxious and everyone was pretty happy I didn't touch the brakes.
    Since I have four younger brothers, the tire changing exercise was a team effort and accomplished quite quickly. Of course back in those days, even seat belts were optional. How did we ever survive? (Many other drivers didn't!)
  16. timberwolf
    timberwolf New Member
    220
    31
    UK
    Glad you are both safe and well, but the important thing is did anyone video it? :)
    I'm kinda of disappointed to hear that it went into 3 successive sideways slides - is that because the Cruise control was set on? (My Prius is the first car I've owned with Cruise control, so I'm not familar with how they behave).
  17. Wildkow
    Wildkow New Member
    5,270
    37
    36
    Glad to hear you are both OK and I think the SCCA driving school is an excellent idea. Man I wish my parents had sent me to this school.
    Keep the sunnyside up. :D
    Wildkow
  18. nickfromny
    309
    24
    Binghamton, NY
    I did not hear the Beep Beep,Beep.........or hear/feel the brakes fire machine gun style that happens when car sldes on ice. VSC must have cut the power. She snaped it into the 1st slide then overcorrected every time till it came to rest on right of highway in grass. Toyota VSC has save my life several times on black ice on highways in past. Will always buy that option from Toyota if its not included. Car stalled at some time durring the slide(s)
  19. nickfromny
    309
    24
    Binghamton, NY
    Your saying that VSC causes overcorrection in a slide on gravel? Not Good.
  20. dogfriend
    7,512
    1,190
    Carmichael, CA
    See pages 3 and 4 of the attached document for a description of the VSC system.
