Why Doesn't the New Insight Get Better MPG than the Civic Hybrid?
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by ggood, Mar 23, 2009.
  1. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
  2. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I fully expect real-world situation driving to easily beat the EPA numbers in that vehicle. Some reviewers have easily beat it in test drives.
    (I just hope I can beat the EPA rating on my new 09 Prius!)
  3. penquin230
    penquin230 "Golden Hawk"
    85
    Atlanta, Ga.
    In the ECON mode and a light foot Insight should easily get in the 60's.
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    I hope they tested and compared against the Civic Hybrid all year round (including the winter).
    It will be interesting to find out what portion of the EPA 2008 test that is keeping the Insight's MPG low.
  5. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The current EPA test includes two extremes in the same number, which will never happen at the same time; therefore any driver with a modicum of efficient driving is likely to be able to beat the EPA test on any car, at least at some points during the year.
    Specifically, the City test includes both driving at very low temperatures (20°F/-6.7°C), and driving with A/C on with high ambient temperatures (95°F/35°C). In spring and autumn, with medium ambient temperatures and A/C off, you should be able to beat the test.
    Of course, no-one's driving matches the EPA test cycles. They're really for comparison with other vehicles only, but even then they can be skewed by the characteristics of the vehicle. The 2G Prius does noticeably better on the EU's 'extra-urban' test relative to diesel vehicles, which are better in real sustained high-speed driving. The supposed improvement in real-world highway driving of the 2010 car may not be picked up by these tests.
  6. Tideland Prius
    16,542
    Well the Insight is sportier to drive and even then, real world numbers have been pegged at 60mpg so it is possible to hit that mark.
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Very good point. The only mechanical aspect that comes to mind is gearing set for 'performance' rather than fuel economy, but not knowing details it is only a guess. And one I find it hard to believe Honda would fall for.
  8. Trollbait
    12,496
    In one article I came across, it was mentioned that a higher gearing was used in the Insight to keep its performance up with the Civic do to its lower output engine.
    Honda does fall for the performance gearing. The Fit manual is rated lower than the auto.
  9. hill
    8,786
    It IS strange, that using the Prius (looking) body on the new insight (and thus lowering the drag) didn't make much of a dif.
  10. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    time will tell, time will tell. its interesting that the EPA figures are significantly lower than the 2010 Pri...makes the 2010 more and more attractive. faster, bigger, more efficient...just better in every way except price. hopefully the early buyer discount, poor exchange rates, etc. will help get a better deal...
    AND,
    gas does not spike for next 3 months!!
  11. Trollbait
    12,496
    Wasn't poor exchange rates Honda's reason for the higher price on the Insight?
  12. fuzzy1
    10,393
    There was considerable cursing on cleanmpg about the MT Fit's gearing being quite short, seriously hampering its fuel economy. It seems that the AT is geared taller, and there were hints that the AT used in paddle-shift MT mode has much better potential.
