Touring vs standard with 17 inch tires? Which is better deal?
Discussion in 'Dealers & Pricing' started by ladele, Mar 24, 2009.
  1. ladele
    ladele New Member
    LA
    Which do you think is the better deal?
    A touring package 6 for $26, 641 plus tax, license and fees
    or
    A standard package 6 with 17 inch wheels for $26, 272 + tax, license and fees
    I had originally wanted a touring so my questions are threefold:
    1. are these 2 comparable for handling?
    2. which is the better deal?
    3. are either of them good deals?
    Thanks!!
  2. dogfriend
    7,512
    1,190
    Carmichael, CA
    For less than $400, I would go with the Touring model. Besides the tire differences, the spring rates are slightly different and the rear spoiler is different on the Touring compared to the standard model.
    I also wonder if the 17 inch wheels would be worse for fuel economy (most people with aftermarket wheels and tires report lower FE).
    FWIW, I have a standard model #6 and the handling is fine for my purposes, but Consumer Reports says that the Touring model is better and the better buy.
  3. Tideland Prius
    16,604
    Depends. I assume you're buying used because the standard model has 15" alloys. The 17s will have greater mpg loss over the 16".
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    Some dealers will install aftermarket wheels and tires because it is an additional profit source for them. It is relatively common in California to see this. I was assuming that they were both new cars since the mileage wasn't given.
  5. ladele
    ladele New Member
    LA
    Yes- they are both new. The 17 inch tires on the standard was just what they happened to have in stock.
    Thanks so much for your advice!
  6. Tideland Prius
    16,604
    Interesting....
  7. priusunlimited
    priusunlimited New Member
    What types of MPG difference do you get between the 15 and 17 inch wheels?
  8. brianw
    brianw Junior Member
    28
    My mothers Prius has 16 inch wheels instead of 15 like mine and she gets about 2mpg less than I do. So, I would guess between 2-4 mpg less for 17 inch wheels. It also depends on the width and compound of the tires.
  9. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I would get the Touring over the Standard with 17" wheels.
    The Touring has 16" wheels with 195/55R16 tires, plus different rear shocks and springs, plus larger front and rear stabilizer bars, plus the larger rear spoiler.
