Loaner Camry Hybrid getting better economy than my Prius
Discussion in 'Gen 2 Prius Main Forum' started by bikersmurf, Mar 27, 2009.
  1. bikersmurf
    bikersmurf Junior Member
    37
    Victoria, BC, Canada
    I think my prius has issues when the loaner Camry I got from the dealer averaged better than I've seen since August. :(
    I Granny drive my prius yet it's economy is mediocre at best (for a Hybrid).
    Does anyone have any ideas why my prius is averaging 6.7 best to 8.1 liters/100k and the loaner Camry I had averaged 6.5/6.6 l/100km?
    The Camry is bigger, heavier, and more powerfull and it seem's to defy logic that it would get even the same MPG. The dealer has gone over the car a second time now and states everything is within spec. They then go on to tell me how the prius is all about emissions not economy so then is the Camry not about emissions?
    Other info:
    2008 Prius 16,500 km (10,000 miles+)
    2008 Camry 20,000 km (12.000 miles +) - Loaded -Rental
    Tires properly inflated
    Have Read everything I can find about hypermileing
    Both cars used for comparable city driving
  2. Tideland Prius
    16,582
    Good question lol. Across Georgia Strait, you can see my lifetime average below. Your best of 6.7 is probably my worst (e.g. in the middle of winter, driving in unplowed residential streets with the heat going).
    How's the oil level? Or the oil itself?
    Were you EVing more in the Prius than in the Camry (because of the screen)??
    Try driving the Prius with the screen off for a tank.
    Your TCH average of 6.5L/100km is about what I got without doing much (i.e. not much P&G)
  3. qbee42
    3,079
    Tideland is speculating that you are trying too hard. This is a common error. Try driving more aggressively. Granny driving will often reduce your mileage if you don't fully understand when to do it and when to not.
  4. bikersmurf
    37
    When I drive the Prius more Aggressively economy is worse. If I ignore the screen It's worse. When I P&G I get it improves to 6.7.
    I drove the Camry the same routes, way, & times of day I drive the Prius.
    Could the Prius engine be carboning up because it is not getting hot enough or?? It dosen't see many highway miles... could this be a part of the problem?
    I have a background in physics, electronics, and I know my way around a mechanics shop. I don't know enough about this car. How could over thinking be doing me in?
  5. bikersmurf
    37
    I should also mention when the Car was NEW I was getting 4.8 to 5.1 after a week or so of driving and for the next 5 months. From about 7000 km on it has gotten worse.
  6. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    How far is your typical trip?
  7. toxicity
    toxicity A/C Hog
    146
    Houston, Texas
    Do you have the heat on all the time? Only put the heat on after driving for five minutes; if tolerable, try going without it.
  8. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    What's that like?
    With "granny" being a 1 and "aggressive" being a 9 on a scale of 1 to 10, try "brisk" instead. That's about 7.5 on the scale. You'll lead the pack, but not by a whole lot. It works out to a 4.93 l/100km (47.7 MPG) lifetime average for me.
    Brisk takes advantage of the umph the electric motor can provide and gets the engine into an efficient RPM quickly.
  9. Tideland Prius
    16,582
    Hmm....
    tyre treads looking ok?
    puncture in the tyre?
    wheel alignment ok? (there are a few issues with that brought up here on PC)
    did you change tyre type?
    winter fuel?
    different oil from the last oil change?
  10. bikersmurf
    37
    No unusual tire wear. Tire pressures above recommended. Drives straight and no unusual tire wear or other signs of alignment problems. Both cars running on the same fuel. Oil changed by the toyota dealer and unless they put in 80w gear lube I just don't see a 25% loss in fuel economy.
    Heat set to 18-20 Celsius in both cars.
    Mostly trips under 15 minutes (its pretty small here).
  11. bikersmurf
    37
    Granny drive not necessarily the right term. I'm not leading the pack like a teenager with a 5 liter mustang but I'm not holding up traffic either. I use apx 1/3 throttle or so, try to pulse and glide and take advantage of grades, and try to avoid sudden stops.
    I know the trips I take will not yield maximum numbers, however, I have no intention of driving twice as far to get slightly better numbers because it will cost more in the end.
    I try to pick routes with fewer stops and steady traffic flow.
    It still doesn't make sense that a bigger hybrid car would get better economy. V=ma and if "m" is larger then more "a" is needed to reach "v".
  12. bikersmurf
    37
    I'll try more brisk and see if that helps. Maybe it's caborning up and needs to be driven more like a 70's Hondamatic... they didn't run wort a darn if you didn't make them sing.
  13. Tideland Prius
    16,582
    Hmm... ok now you've stumped me lol.
  14. richard schumacher
    7,664
    1,046
    United States
  15. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    Ya know what? These people have the same problem and don't even realize it.
    Look at the MPGs....They're doing many many short trips. It's a runabout for a University.
  16. Rokeby
    Rokeby Member
    3,033
    709
    75
    Ballamer, Merlin
    As to why FE has dropped over time, I would also look at the air
    cleaner, MAF sensor (underneath the air filter). Don't remember if
    you good folks in Canada have rear drum or disc brakes. If the
    former, a shoe could be dragging a little.
    Sounds like the HSD; engine, catalytic converter, and HV battery are
    not getting fully warmed up during the short trips. As a result, the car
    is not operating in its most efficient mode.
    Using the heat in the first 5 min. or so makes a bad thing, the
    low MPGs during the initial warm up period, even worse.
    Getting to S4 requires getting up to 35 MPH. So, an otherwise
    good route with speeds at or below 30 MPH could also be contributing.
    Using either the front or rear defroster prevents the ICE shutting down
    when at a stop before the HSD, etc is fully warmed up.
    You might consider using an electric block heater to start the day with
    higher ICE coolant temps.
  17. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    You can join my 35-40MPG club, you seem to qualify.
    FWIW, I recently moved and my commute is longer. For the winter, I used an internal 20$ electric heater. Plugged to a timer, on 1h before I leave. Some winter days it got to -20c!
    Time savings, not having to remove snow/ice, priceless !
    So for the first 5 minutes or so, I would drive with no heat at all to the cabin, allowing for the motor to warm up. Windows being all hot & such, no problem until the highway speeds, where I would turn on the defrost, but not too much.
    So for winter driving, I was getting 6.5l /100km. That's with wet pavement, winter tires, etc. So it's quite good.
    Now that the weather is nicer, I did a Reset. I'm getting in the 5.5l range, but I still have the winter tires to change.
    So before, my daily commute was about 4km, and always got in the sixes.
    Now, my commute is 20km, in ideal conditions, I've gotten 3.8l on a tank with no weekend driving.
    Just remember, you're still polluting 1/6 that of a Honda Accord !
    (driving those same KM's)
  18. fuzzy1
    10,533
    Cold winter weather and winter fuel will both contribute to poor fuel economy. Around Seattle, my lousy winter (non-hybrid) economy started recovering about two weeks ago, but is still nowhere near summer levels. Does your pattern fit the seasons? Maybe not, as August is much too early for this to start.
  19. bredekamp
    bredekamp Member
    569
    I was wondering, does the Prius engine also have one of these mechanical thermostats that would pop open and close or is it all electronic? My E46 BMW was always running too cool, because the thermostat snapped its' plastic retaining clip. [BMW used plastic in that car in places where metal should have been used instead].Replaced it and the temperature needle went back to the middle. It's never cold enough here for an always open thermostat to be a problem, but a friend of mine said it's bad for the engine and the CAT won't work properly. You'll just use more fuel.
  20. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    It's a mechanical thermostat. It nominally opens at 82°C, but a range of 80°C to 84°C is permitted. Picture:
    Picture from Autohaus Arizona.
    The Prius generally has electrics/electronics rather than complicated mechanics, but simple mechanical devices in preference to complex electronics. The indicator flasher makes its 'tick' noise mechanically, which is why the relay is in the junction box by the driver's knee; the timing relies on the lamp's electrical resistance, so resistances (or a new relay) are required if replacing the lamps with LEDs. Relatively primitive, but reliable.
