Static shock
Discussion in 'Gen 2 Prius Main Forum' started by Flavin, Mar 29, 2009.
  1. Flavin
    Flavin New Member
    Longmeadow, MA USA
    Hello
    I'll admit this is a bit of a strange post/question .... I bought a 2005 Prius a three months ago and like the vehicle. However, when I get out of the car and touch the door to close it, I sometimes get a static shock similar to when you rub you feet on a shag carpet. Is that 'normal'? Not that its so annoying but is there anything I can do so I dont get the shock ?
  2. richard schumacher
    7,664
    1,046
    United States
    This not unique to Prius.
    Spray antistatic stuff on the seat.
    Grab the door frame as you get out so that you continuously discharge yourself.
    When buying gas, Do Not start the pump and get back into the car.
  3. qbee42
    3,079
    Another option is to let your wife get out first. ;)
  4. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    There are also grounding straps you can buy. They drag on the ground and discharge the static electricity buildup.
  5. qbee42
    3,079
    These help with static build-up from the motion of the car, but not with static from sliding across the seat.
  6. Triparadox
    Triparadox Active Member
    201
    108
    I just experience it lately. Before, I've never experienced this. I don't know why but lately almost everytime I will always get shocked..
