Red Triangle and beep for 1 second or less
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by saechaka, Mar 31, 2009.
  1. saechaka
    saechaka Member
    225
    This has happened twice so far. I have about 157,000 miles and have the squeak issue and actuator(?) pump noise issue. I was driving this week downhill and heard a quick beep and the red triangle flashed and then went away. My wife said the same thing happened while she was driving to Portland. Has anyone ever had this happened to them? I'm not willing to pay for diagnostic yet. Lately, my sks has been working intermittently and I think my fob battery is dieing. Can that have anything to do with it? Thx
  2. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Try a place like Autozone or similar that offers free code reading. There may be a code stored
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    If the fob battery is dying, you will hear a long beep when you turn the car off. There will be no dash warning lights. The red triangle is indicative of something else. Only the codes will tell.
  4. brownsnoutuk
    brownsnoutuk Active Member
    185
    119
    Shepherd, TX
    Is it the same beeping as when you open the door with the car in drive? Maybe its a bad contact or >>>???
  5. laskaris007
    laskaris007 New Member
    Very LOW OIL LEVEL !!!!!
    Replace oil level asap, or engine failure will result.
  6. jayman
    13,439
    641
    Winnipeg Manitoba
    So, what did we find out? Problem with a sensor, or critically low oil level??
  7. saechaka
    saechaka Member
    225
    I'll try to make it in to schucks today to see if they can pull the code but it might be as the previous poster mentioned, low engine oil. I was changing it at 5,000 mile intervals until I hit 60,000 miles. At that point, I was changing it every 10,000 miles. When I got the warning, I was at the 7,000 mile point. I've been using Motorcraft 5-20w since 100,000miles and Mobile 1 Synthetic 5-20w prior. I guess now would be a good time for UOA, eh?
  8. jayman
    13,439
    641
    Winnipeg Manitoba
    So you *were* low on oil??
  9. mercuris
    mercuris New Member
    Massachusetts
    Hello. Just wondering if this ended up being the problem or if anyone else has experienced this.
    My 2007 Prius is doing the same thing. It will beep once, the red triangle will light up for a second and the screen will say "Problem" momentarily.. It's happened 3 times, once when I stopped short while turning left, once while turning left tightly into my parking lot, and another time turning left into a gas station. All of which were tight turns.
    Come to think of it it's never happened while turning right (not yet anyway). I'll probably have to go get the codes read at Autozone or something - but while I'm at work I figured I'd get some expert opinions from here. :)
    Thank you
  10. Patrick Wong
    18,210
    6,514
    Does your car have Smart Entry / Smart Start? If so, I suggest that you start by replacing the fob battery.
    I doubt that any trouble codes will exist if you don't see a warning light on at all times.
  11. mercuris
    mercuris New Member
    Massachusetts
    i do have the smart entry / smart start. both of my fobs light up when i hit the buttons (from another forum post here, i thought the red light wouldnt light up when the battery is dying)
  12. kwasmart
    kwasmart cool member
    chiacago
    I had a similar experience w/ my 04 prius at 163k miles and I panicked and went to the dealer and it was a leveling sensor for the headlights. the cost was about 780.00 and i refused to do it as long as the car was driving fine. it ended up self correcting.
    all the best
  13. Patrick Wong
    18,210
    6,514
    Since it only costs ~$5 or less to replace the fob battery, I think you should start with that, to rule out a marginal battery as the cause.
  14. mercuris
    mercuris New Member
    Massachusetts
    I started with that and replaced the batteries just to be sure. I just so happened to go down a winding road and as my car was 'turning left' for quite some time, the beep and red triangle appeared again (this time for longer), followed by the low oil sign.
    Immediately I pulled over and threw some oil in the car to hold it over for a couple days, and I have yet to see the red triangle again (24 hours).
  15. boppo
    boppo Active Member
    799
    139
    Owego, NY
    So does it burn oil/leak oil?
  16. Patrick Wong
    18,210
    6,514
    Thanks for the update. How much oil did you have to add to bring the dipstick back to the full mark?
  17. dandvan
    dandvan Junior Member
    I had this same problem! Couldn't figure it out till I found this thread. When I checked my oil, it was off the dipstick!!! It took 2 full quarts to get it back to the middle of the two dots. I bought a 3rd quart for when I know check my oil EVERY time I fill up as suggested in the manual.
    It's intersting that I was due for service about 1000 miles ago.
    My 2004 has 211,000+ miles on it and is going strong. I just had to replace the 12V mini battery in the back...but that's another story!
  18. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,519
    Santa Fe, NM
    I hate to say it, but anyone who has had this problem, a brief red triangle with the oil light, the damage has quite likely already been done. This situation does seem to happen mostly on a Prius that is two quarts low and going downhill or during hard braking, as the oil pickup is no longer submersed in the small amount of oil sitting in the pan. From here on out, monitor your oil levels very carefully, as the consumption will only get progressively worse.
  19. adam little
    adam little New Member
    Arkansas
    Over 300,000 and mine just did the same thing. 2400 since oil change and it was 2.5 qts low! Glad I found this thread! Guess I'll start checking the oil more often
  20. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Geez people. This is not a LOW OIL Level light! It is a LOW or NO OIL PRESSURE LIGHT.
    The cause of the light to come on, is often due to insufficient oil level or the oil pump failure. Insufficient oil could be due to a leak, or excessive oil being burnt and never replenished. Since most of you never check your oil level, you never notice your car telling you to add more oil before it gets too low.
    Pay me $2000 and I will be happy to drain 3 quarts of oil, out of your oil pan, and let you drive your merry way, to a shortened engine life due to excessive wear, due to insufficient lubrication, due to low oil. $2K+ is what you could expect to pay for a used replacement engine installed.
