My prius is a gas guzzler?
Discussion in 'Gen 2 Prius Fuel Economy' started by anthofang, Apr 9, 2009.
  1. anthofang
    anthofang New Member
    56
    Los Angeles
    So the situtation is that i have owned an 09 prius for about 1 week and a half. When i left the dealership, the gas tank was full. Now at a week and a half later i m down to 4 bars. This seems odd considering my consumption tracks my average mpg at 45 mpg so it shouldnt be going down that fast? What is going on? Have a been duped?
  2. fuzzy1
    10,515
    I have yet to own any car where the gas gauge was sufficiently linear to accurately estimate fuel usage, without the knowledge gained from actually refilling it.
    Your Prius will be even worse. The tank bladder introduces considerable variability, and will require more refills before you get a feel for the pattern.
    -- Dean, not yet a Prius owner.
  3. nooaah
    nooaah New Member
    380
    Philadelphia
    You could have driven 275 miles in a week and a half. The time doesn't tell us anything. How many miles have you driven and was the tank definitely full when you got it?
  4. anthofang
    56
    Los Angeles
    yes the tank was definitely full and as of now i believe its a little over 200 miles i have driven.
  5. Kds45
    Kds45 New Member
    South Bend, IN
    I've been driving an '08 for over a year now. The gauge is not the best judge of mileage. I've had a couple of times I thought things were way off, but when I filled up and calculated, I always run very close to what the on-board calculator shows. I'm at 52.5 now that it's warmed up. I was down in the mid 40's during the cold weather. Just drove to Florida and back and got 53 for the trip. Relax and enjoy the ride.
  6. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    How do you know it was full? If you didn't see the dealership top it off, you can't be sure. It's not unheard of for newly purchased cars to be driven off the lot with less than a full tank. The gauge will indicate full even if it's not quite there; the first pip on the fuel gauge could take anywhere from 50 to 200 miles to disappear.
    Meanwhile, just be patient and trust the display. Some of us have tracked the difference between displayed and actual fuel economy over many tanks, and the difference is within 2-3%.
  7. bwilson4web
    16,249
    Fill up the tank and you'll have a measure of the amount of fuel burned. Then compare the pump calculated value to the display. But save the data somewhere.
    There is considerable variability in fill-up values for partial tanks. But I was able to use this data to tweak and tune different aspects of my 2003 Prius. Having a mileage record is the first step to figuring out how well the car is performing as well as learning how to optimize performance. This first set were recorded in a spreadsheet and plotted to give:
    The dealer I bought the car from had put in the extra oil. Two months after buying the car, the temperature dropped.
    One caution, unexpected running out of gas can happen when the gas gauge (often called 'guess gauge') gets near the bottom. I've gone as little as 25 miles and as far as 130 miles with the bottom pip flashing. The average has been closer to 65-75 miles. In my case, running out of gas has been planned so I carried a 1 gal. spare can.
    Running out of gas lets the car continue on battery at a slow speed but I've only used the limited battery capacity to find a safe place to park and add my spare gas. There have been reports of folks going a mile but this is really pushing it. Repeated attempts to start the engine after running out of gas can set a code that has to be cleared by towing the car to a dealer ... not a good thing.
    GOOD LUCK!
  8. Bob64
    Bob64 Sapphire of the Blue Sky
    1,540
    93
    Virginia
    Unless you KNOW you put X gallons in the tank, you don't know how full it is.
  9. qbee42
    3,079
    I would unload that gas guzzler as fast as you can. I'll give you 10K for it, which isn't bad considering that your Prius is defective.
  10. thelankyyankee
    thelankyyankee New Member
    Massachusetts
    I am in almost exactly the same situation right now (just bought an 09, first tank is going much faster than expected, etc.) but I am comforting myself with the advice given here. All of it seems sensible. I think the last post about how far you might be able to drive on the last bar is really important. If I could go 80 miles on the last bar, all my concerns are gone; if only 20, different story, but I'll have no idea until I see how much goes in the tank and even then, who knows if the dealer topped off as I would? That first bar went fast!
    I'll report back, but this is a helpful thread.
  11. qbee42
    3,079
    Don't chance it on the last pip. If you are down to one pip, you should have already refueled. The built-in inaccuracies of the gas gauge mean you should never push it at the bottom of the tank.
    Rest assured that the mileage shown on the MFD is very accurate. Depending on tires, most posters find it is somewhere between dead on and 2% optimistic.
  12. anthofang
    56
    Los Angeles
    eh..i think i will pass because people are probably right. I didn't actually see how much gas was put into my prius when i bought it. So after refueling a few times, i will probably get better indication of how defected my prius may be. Thanks everyone!
  13. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I bought a used 2006 and the tank said it was full but I put 5.06 gallons in it and have driven 420 miles and it is on the 1/2 make. the fool gauge is not that good of a indicator of what it says and what it has. I would love to get 420 miles on the second 1/2 but I know it will never happen.
  14. qbee42
    3,079
    Five gallons fill at half full is pretty normal.
  15. boppo
    boppo Active Member
    799
    139
    Owego, NY
    No, it said it was full and I still put 5 gallons in it.
  16. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    You know, my first tank dropped pretty quick. Dropped to 3 bars with about 270 miles. Filling it up took about 7.5 gallons. The second tank got close to 400 miles before it hit three bars.
    Don't freak out on your first tank. You won't know what your fuel economy really is until you run a few tanks. I use mymilemarker.com to track my usage.
  17. qbee42
    3,079
    Gotcha. I misread your post.
  18. boppo
    boppo Active Member
    799
    139
    Owego, NY
  19. elcorazon
    elcorazon New Member
    74
    chicagoland
    You people are all crazy. I have a 2007 and routinely have half a tank at 200 miles, sometimes sooner. I rarely can hit 400 miles in a tank.
    This is all normal. Plus, first tank is likely messed up due to new vehicle - more playing - unusual stopping, driving and generally not knowing exactly how full it was.
    whole thread is silly from the OP on down.
  20. F8L
    19,011
    4,083
    Grass Valley, CA.
    Did anyone remember to tell the OP that he doesn't "really" have an 11.9ga tank?
