Engine Starts
Discussion in 'Gen 2 Prius Technical Discussion' started by Crusader Rabbit, Apr 12, 2009.
  1. Crusader Rabbit
    Crusader Rabbit New Member
    Maryland
    On errands which intales going to a location and turning off the car and then going to another stop and turning off the car.
    When I start up the car, no matter if I have stopped it for a few seconds, the motor starts and uses gas each start up. Doing multi errands uses lots of gas. This happens in cold, warm and HOT weather. I was told by a Toyota Mechanic that he "thought" it had to do with engine temperature. The battery is well charged!!
    Any ideas why and any way to get around the motor starting afer each turn off.
    Thanks
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Since Prius places a high priority on emission reduction, the short answer is no.
    Heat is needed for the catalytic-converter to properly cleanse emissions. So it will run the engine to maintain that temperature, even if it means sacrificing some gas to do it.
    Fortunately, other things take place as long as the engine is running. But there is still a penalty for short trips. (Of course, there is a heat requirement for traditional vehicles too... only the effect isn't as pronounced since it's just an RPM difference.)
  3. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Park the car. Turn off headlights. Turn off climate control if vehicle is unoccupied. Lock the door with the key. If the trip is going to be more than 10-15 minutes then turn the car off. You will have to unlock the door with the key AND press the unlock button on the armrest to enable SKS.
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    87
    :welcome: Welcome to PriusChat, Crusader Rabbit!
    One thing you can do to help is to plan your errands and go to the farthest first. This gets everything warm so your new starts will be shorter, but Jim's idea of leaving your car in READY is the only way to avoid the start-up penalty.
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    As said above, the Prius goes through a cycle of "warm the catalytic converter" every time its' started, even if the cat. is warm. If you don't shut it off, it won't go through that cycle.
    Even going through the cycle, it's only running the engine for 20-40 sec. at idle. That doesn't really use that much fuel. Typically Prius burns about 1-3 l/hr at idle. So that translates to about 3-4 cc of fuel per start. You -might- be able to see this on your fuel economy, but I suspect there are larger variables that will swamp it out.
