real world mileage on the Insight
Discussion in 'Other Cars' started by adric22, Apr 13, 2009.
  1. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    145
    Fort Worth, TX
    Okay, everyone keeps talking about waiting for the real-world figures to come in.. My family took a trip from our home in Fort Worth to Austin this easter weekend. We took the new 2010 Insight, obviously.
    Right before we left, I filled up the tank and set the trip meter. I planned to verify the mileage the old-fashion way and see how it compared with the computer mileage.
    We traveled almost 200 miles to Austin, drove around the city for 2 days, and travelled back to Ft.Worth. My wife did 90% of the driving, and she drove about 70 mph most of the time and was often passing people. She definitely did not featherfoot the car. Although, she did use the cruise a lot on the open highway.
    Now, we stopped in Waco on the way back to refuel. I didn't want to since I was certain the car would make it on the original tank of gas but my wife was feeling uneasy. So the mileage at the fueling station was right at 50.0 mpg on the computer readout. I filled up the tank and it only accepted 7.5 gallons of gas. I divided up the numbers the old fashion way and came up with 49 miles per gallon. So the computer was pretty darned close.. and who knows, there could be a discrepency in the pumps that could cause that.
    Now, honestly, I was surprised. I am used to getting slightly less than whatever the EPA says a car is going to get, doesn't matter what car it is. But the Insight actually does better. In fact, we've consistently gotten 43 to 45 mpg around town, which is also better than the EPA.
    I also noticed that most of the reviews I've seen by car magazines also say that they got a few mpg more than the EPA estimates, which means I'm not alone in this phenomenon.
    So, that being the case, I'd say the Insight would definitely give the prius a run for its money on highway mileage.
  2. Tideland Prius
    16,504
    Sweet!!! Yeah the media got 60mpg driving efficiently so 50mpg driving normally sounds about right. That's why I'm wondering why it's rated so low. Yes I know about the gearing but if they can get 60mpg in the Insight, what about the HCH-II?
    The Prius is topping 70mpg so I expect a normal person to get 50-55mpg on the highway.
  3. ljbad4life
    ljbad4life New Member
    365
    24
    This is the time of year hybrids typically get their best, it gets worse in the summer and they usually plummet in the winter. keep us posted in the other seasons so we can see the changes
  4. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Definitely keep us posted. How many psi do you have in your tires? What is the recommended psi?
  5. adric22
    642
    145
    Fort Worth, TX
    believe it or not, the recommended PSI for the insight is 36 psi. Strange since even the previous generation insight used a much higher psi. I haven't actually checked my tires so they are still at whatever the dealer left them at.
  6. gdog
    gdog New Member
    Was the the insight always driven in normal drive mode?
  7. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    That's higher than Prius. 36 psi both front and rear?
  8. Tideland Prius
    16,504
    The old Insight had 14" tyres and are definitely eco tyres so they are pumped up for best mileage. 36psi is high for 15" tyres but hey, the newer tyres nowadays can take higher psi without compromising too much on grip.
  9. adric22
    642
    145
    Fort Worth, TX
    Am I missing something here? Every non-hybrid car I've ever owned had tires designed to run 36 PSI. That is like the industry norm. My old Insight was something like 70 psi and I seem to recall the Prius was something like 45 psi. I'd have to go look it up to be sure, though.
  10. MSantos
    MSantos EcoAccelerometry
    588
    257
    Canada, Winnipeg
    2024 Prius Prime
    XSE Premium
    The Insight's instrumentation does not appear to suffer from the same underestimation as the HCH-II. I currently have a 2010 HI tester in my hands and in contrast, the HCH-II displayed FE is traditionally lower 1-4% than the calculated (typical trivia stuff).
    In the city, the HI does better than the HCH-II, especially in stop-n-go driving and with the econ button on. It's two stage ICE and lower PCM programming/gearing helps here.
    On the highway, the HCH-II continues to be the FE monster. Its 3 stage ICE and abnormally high PCM/gearing gives it the edge.
    Cheers;
    MSantos
  11. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    Would be nice to keep a spreadsheet of fuel usage and MPG through the seasons...
