OK! My FIRST real problem with my Prius....
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jamesbalch, Apr 19, 2009.
  1. jamesbalch
    jamesbalch Junior Member
    71
    Northeast
    OK Gang. Here is a weird one.....
    I get into my Prius the other day. It's 0430 in the morning. I have an early show at the airport for a 0700 flight. I push the Power button and back out of the garage into the turn around. Then I pull out, leave the driveway and zoom away.
    I look at the speedometer display to see how fast I am going....and it is dark. In fact the ENTIRE display is dark! :confused: No gas tank display, no mileage, no speedometer....no NOTHIN'! The signals work and display...otherwise.....BLANK.
    So I say to myself...."Must have the dimmer down". So I flip the pot up and down....click it up fullbright....spin it all the way down to the bottom...NO CHANGE! Still blank. :mad:
    So I start thinking...."How much gas do I have in this thing?" Now I remember...I thought to myself on the way home the night before that I had to stop and get gas the next day. So I take stock of the situation....thing is runing like a top...just like always. Nothing bad is happening. So I say to myself "I'll just drive my regular route to work and stop for gas where I usually do. Maybe when I shut down, gas up and turn it back on...all will be well".
    So.....I pull up to the pump and push the power button. NOTHING HAPPENS! :( Thing still keeps running. NOTHING SHUTS OFF. So I push the power button a few more times - NOTHIN'! So I push and HOLD the power button (just like shutting down a computer that has locked up). The thing shuts down - sort of. The engine stops and everything gets quiet - except the radio. It keeps goin'! So, I reach up and push and hold the power button again. After a few seconds, the radio shuts down. Now, EVERYTHING seems fully shut down.
    So now you know what I'm thinkin' I'll bet! Is this thing gonna turn back ON when I hit the power button....or am I stuck here at the pump? So, I figure - screw it....what else can I do? I might as well find out sooner rather than later. I reach up...and hit the power button.
    Friggin' thing turns on just like normal! All displays normal! So, I reach up and shut it off again. Down it goes...shuts off like a champ. Gas up. Turn it on....no problems. Go to work. Get out of work, hold my breath and hit the power button. Thing turns on ...everything normal.
    Been three days now since it has happened. Ran it all those days. Not ONE glitch in it again!!! :D
    Weird!
    Anyone had ANYTHING similar happen??
  2. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    One extremely rare possibility is what is called a Single Event Upset. This is where a cosmic ray or electronic glitch causes the software to go into a strange, one of a kind state that remains until the system is completely powered down. The identifier, lacking a complete memory dump of the software registers and memory, is that it never returns. If this problem appears again, then that is definitely not the cause and more conventional explanations apply (intermittent connector, chaffed or shorting wire, etc.)
    I have definitely seen these in flight control systems where the recording of any unusual software behaviour is completely captured and the event can be traced to what memory or register bit changed. Fortunately, flight control systems have a lot of automatic backup and redundancy to immediately isolate the malfunctioning devices. The Prius is not engineered like this yet, but is engineered so that unsafe conditions cause the system to go into a safe mode.
  3. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Someone else posted here with the exact same scenario. I dont' recall what the problem turned out to be.
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    Its a problem with the Combination Meter. There is a thread on it, plus a blog entry at Luscious Garage.
    http://priuschat.com/forums/prius-main-forum/57445-instrument-panel-problem-video.html
    Luscious Garage | Blog | LG TV - Prius Dead Dashboard
    More threads:
    http://priuschat.com/forums/care-ma...0-no-speedo-odo-wheels-not-turning-mfd-3.html
    http://priuschat.com/forums/prius-main-forum/56597-my-prius-will-not-turn-off.html
  5. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    Cool. Nice to have those that keep up with these things keep me up to speed.
  6. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    So what's the problem? :confused:
    There was one day when I was parked at work and Priapus started making all sorts of crazy sounds as though the auto-theft alarm had gone off but only a little stranger. I had similar difficulty shutting him down and the MFD was showing a display about parking on an incline or something like that. Keep in mind that this was in a perfectly flat parking lot.
    The whole ordeal had me freaked for a few days but anymore it's only when someone posts a story like yours that reminds me, "oh yeah, I had an oddity once..."
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I'm still undecided if it *really* is the combi meter, or a bad connection on one of the four connectors at the combi meter. I posted the connector locations at the thread you mentioned.
    Sometimes a component may look or test "bad," but the problem may actually have been a poor connection on one of the pins of one of the connectors. Just the act of removing all the connectors removes the oxidation, the "bad" combi meter is replaced with a brand new expensive one, and magically the problem is gone
    What if instead, replacing the combi meter is only coincidental and the real issue is a bad connection? Without the use of an appropriate MSO to examine for glitches (Good luck with that for a rare/intermittent problem) on CANBus, you're guessing
    Before I spent the money on a combi meter, I'd pop and reseat all the connectors first
  8. dogfriend
    7,512
    1,190
    Carmichael, CA
    If I was spending the money, I would try your way. If it was under warranty, I would let the dealer deal with it. ;)
  9. jayman
    13,439
    641
    Winnipeg Manitoba
    I'm guessing you're one of the rare but documented humans who are a Malfunction Magnet
    That's the warning for the parking pawl, isn't it? Low 12 vdc voltage?
    Ok, I'll be the first to admit I sometimes will go out with a real Coyote Ugly woman, but lets leave my personal sex life out of this serious discussion.
  10. jayman
    13,439
    641
    Winnipeg Manitoba
    Of course. What is the warranty on a combi meter? 3/36?? A lot of Prius are therefore off warranty for a repair like that
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Whats the history of the 12 aux/boot battery in trunk. How many times have you been jump started?
  12. dogfriend
    7,512
    1,190
    Carmichael, CA
    Is this where the thread jumps the track? :madgrin:
    Yep, at least in the US its 3 / 36 unless you purchased an extended warranty. Apparently, this has happened on a few 07 and 08 cars.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Yep. Baaaaaaaaaaaaaa
    Not 04-06? Wondering then if a manufacturing problem, eg like how the 04-06 MFD's could be repaired with the solder job
  14. dogfriend
    7,512
    1,190
    Carmichael, CA
    I'm hoping Hobbit gets ahold of one of the failed Combo Meters at some point.
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    I would also like to have somebody with a "bad" combi meter just reseat all four connectors. If that clears up the problem .... problem solved.
