2009 Service Manuals
Discussion in 'Gen 2 Prius Main Forum' started by Nortnarg, Apr 17, 2009.
  1. Nortnarg
    Nortnarg Prius~To go before
    83
    Blue Springs, Missouri
    Does anyone know what the service manuals cost for a 2009?
    Also does anyone have the manuals for this year?
    Just wondering if it would be useful for me to own these. I am not planning to do much work on my car, but it would be nice to have the info, and understand the components and the procedures involved in doing specific service work.
    I had the manuals on my 1988 Chevy truck which I drove for over 20 years before letting it go to a friend, and replaced it with my new Prius! I did refer to the info on many occasions, and found help in deciding to attempt work my self or to stay far away! Just understanding the systems and how they are designed, is a huge advantage!
    Thanks to anyone who has information to offer on the manuals.:)
  2. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    All your questions are answered at techinfo.toyota.com. Look for the 2006 manual - the car is unchanged between 2006, 2007, 2008 and 2009 model years (minor tweaks to option packages only). The changes from 2004 to 2006 were so minor that the same model code is used - NHW20.
    There are also copies (of dubious legality) online here: 2004, 2006.
  3. Patrick Wong
    18,210
    6,512
    If you wish to develop an understanding of the various Prius systems, then I suggest you subscribe to techinfo.toyota.com and download the New Car Features manual for 2004 and subsequent years. The 2004 NCF will give you a complete 2G "theory of operations", while the updates for subsequent model years provide info on the new tweaks introduced each year.
    If you just obtain and read the repair manuals, they will tell you troubleshooting steps to follow when you have a problem, but you will not necessarily understand why you are doing whatever you were told to do.
    Also I suggest that you review the various Toyota tech training courses, which are available at techinfo or free of charge at Automotive Training and Resource Site
  4. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Hello Patrick:
    Many thanks for the link to the ATRS. These will be really fun to read.
  5. Nortnarg
    83
    Thank you all for the great links and info!
    I will be checking them when I have more time. Looks like good reading! ( I love manuals!! ) :whoo:
  6. ArcticPrius
    ArcticPrius Prius Owner
    61
  7. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    Does the Haynes manual cover the sophisticated brake-by-wire system?
  8. KTPhil
    KTPhil Active Member
    1,379
    22
    The Haynes manual sucks. I have many other Haynes and those are good; this one's an exception.
    Get a Bentley, or download the factory manual from Toyota.
  9. ETP
    2,803
    1,170
    Auburdale FL
    Also factory service manuals on DVD would be my choice.
    PRIUS 2009
    [​IMG][​IMG] PublicationDescriptionPub # Price
    Repair ManualVOL. 1RM10Q0U1$138.95
    Repair ManualVOL. 2RM10Q0U2$115.79
    Repair ManualVOL. 3RM10Q0U3$123.51
    Owners Manual Navigation GuideNHW20 FRM 8/08 OM47615U$15.95
    Owners ManualNHW20 OM47614U$15.95
    Electrical Wiring DiagramNHW20 EM10Q0U$84.21
  10. MadHungarian
    MadHungarian Member
    139
    Atlanta and Miami Beach
    Bentley Prius Manual
    KTPhil is correct--the Bentley Prius Manual is A+++.
    Jayman: You don't specify your specific interest(s); the Bentley manual devotes 62 pages to brakes, suspension, and steering.
  11. ETP
    2,803
    1,170
    Auburdale FL
    links?:d
  12. Patrick Wong
    18,210
    6,512
    techinfo.toyota.com is the official Toyota subscription website.
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    Re: Bentley Prius Manual
    Does the Bentley manual describe how to bleed the brakes on a +2004 Prius? If they suggest "step on the brake pedal and crack open the bleeder valve" then BZZZZZT WRONG
    The only way to properly bleed the brakes on a Prius is to use the dealership scantool to command the solenoid valves to open in proper sequence, and the boost pump to run at the proper time
    For example, my All Data DIY has the same exact instructions for bleeding the brakes as the genuine Toyota shop manual
    http://priuschat.com/forums/attachm...n-bleeding-prius-brake-bleeding-procedure.pdf
    http://priuschat.com/forums/prius-t...em-rear-brakes-no-pressure-when-bleeding.html
  14. MadHungarian
    MadHungarian Member
    139
  15. jayman
    13,439
    641
    Winnipeg Manitoba
    Good to hear. Generic Prius "shop" manuals suggest old-fashioned brake bleeding methods. That is dangerous
