Clean Plastic Cover over Dash Display
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tom1l21, Apr 17, 2009.
  1. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    Is it easy to remove the clear plastic covering over the dash display? Right where the speedometer is, there seemed to be a bit of moisture that built up underneath the plastic, resulting in a foggy look late at night when the light from the LCD shines through. I was wondering if I would have to take apart the whole dash to do this and if that would be a very time consuming job. Thanks.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    It might be from the mirror rather than the clear plastic. It's easy to smudge the area on the flat part of the dash when cleaning the windshield.
  3. tom1l21
    tom1l21 Member
    268
    East Longmeadow, MA
    What do you exactly mean by this? How would the mirror get smudged if it is enclosed under the flat plastic part?
  4. firepa63
    1,761
    208
    I should have said the lens covering the display projector on the flat portion of the dash.
  5. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
