Should I Keep my 2009 or trade in for 2010?
Discussion in 'Gen 2 Prius Main Forum' started by smartalec89, Mar 29, 2009.
  1. daniel
    14,487
    1,519
    Spokane, WA
    Sounds like you've got your heart set on the upgrade, and you can afford it, but you asked for opinions, so here's mine:
    I looked at the specs and descriptions, and I don't like the 2010 compared to my 2004. Now this is just me, but I prefer a smaller car, not a bigger one. Most of the improvements sound to me more gimmicky than substantial, other than the slight improvement in FE (too little to justify the cost of upgrade for me) and the radar speed control, which I like. But to get that it looks as though you have to take the leather seats, and I hate leather because in summer wearing shorts, I stick to it.
    Note also that the reason it takes so long to get heat out of the heater is that the car is so efficient it does not burn much gas. I get more heat faster out of my Xebra, because it's electric:I can turn on the heat before I even turn on the car, because the heater is wired directly to the battery.
    So my advice is, keep your 2009 until the plug-in comes along. But whatever you do, enjoy!
  2. smartalec89
    smartalec89 The Official Alaskan
    133
    anchorage, alaska
    I like your opinion. You bring up some good points. I am not the biggest fan of leather either but I could live with it for some heated seats.:) The size change though your looking at .6" longer not much difference and width is pretty much the same. As far as heat goes... They may have changed it. They did change a lot over to electric so it could heat up faster. Does anyone know about this?
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Doug at http://priuschat.com/forums/2010-to...ay-post819368.html?highlight=april#post819368 said "Production begins late April, and cars will arrive May or June depending upon where you live."
  4. qbee42
    3,080
  5. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    So many 09's on lots you will take a big hit.
  6. daniel
    14,487
    1,519
    Spokane, WA
    I lived in North Dakota, and my bum never got cold. My hands and feet got frozen, but never my bum. What I wanted was a heated steering wheel. Heated seats would be a negative, IMO.
    It is true that the engine heats up faster in the 2010. They utilize the exhaust for that. Very clever. But you'll never get as much heat, or as fast, as you would with a car that wastes more gas than a Prius burns.
    I used to let the Prius pre-heat when it got colder than 20 below F. in ND. If you use the mechanical key you can lock the car with the engine running and the heat set on high. Yes, that wastes gas, but I was willing to waste 5 minutes of idle-engine gas rather than get in a car at 20 below zero Fahrenheit.
  7. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    "Should I Keep my 2009 or trade in for 2010?"
    Yes.
  8. smartalec89
    133
    anchorage, alaska
    There is only one on the lot currently. I don't think I will lose much maybe $1000 but that's no big deal.
  9. smartalec89
    133
    anchorage, alaska
    First off...Alaska and North Dakota are nothing alike!!! Alaska has way less people and our average temp is close to -20 in the winter. It gets down to about -45 and stays that way for weeks if it wants to. If you let your car idle you get 0mpg. It's been prove countless times on this site you get better mpg by driving your car to warm it up. I am not interested in the heat output but rather the quickness to get the car upto normal operations.
  10. smartalec89
    133
    anchorage, alaska
    Yes???? Which one?
  11. M8s
    M8s Retired and Lovin' It
    614
    113
    33
    Colorado and Arizona
    "If you come to a fork in the road, take it." Yogi Berra
  12. Qlara
    Qlara New Member
    488
    Since you are ready to take a 'loss' in the worst case of trading in, so you've already made up your mind for the upgrade to 2010. Do you still need additional opinions from us to tell you not to?
  13. yardman 49
    yardman 49 Active Member
    606
    77
    Northern Kentucky
    Here's the reasoning of a newbie who loves (and will probably keep) his brand new '09:
    Good points that I like about the 2010 model:
    • I like the potential added rear headroom of the 2010. This would be a real plus in my mind.
    • I like the reported gas mileage improvement. Not huge, but could be substantial with careful driving, due to the new factory operating modes.
    • I like the reported performance increase.
    • I like some of the new amenities
    However:
    • I don't like the look of the new 2010 front end or the rest of the styling as much as my '09. Looks like they're trying to copy Cadillac with the front end rework and sharper lines. The rest of the body seems more like existing cars than the unique look of the current model (not counting the Aztec rear end).
    • I definitely don't like the floating center console. Way too cramped looking. I've never been a fan of the feel of "cockpit" style seating.
    • I don't like the look of the new display. Too busy up top. I'd rather have the MFD on the 2009. More geeky, but I like it. However, I understand that to increase their market share into the non-hybrid market, Toyota will need to have more appeal to the "masses". That's probably some of the reason for the "geek reduction" cosmetics changes.
    • I want to wait until Toyota can incorporate Lithium polymer or other battery technology that could store a greater amount of regenerated energy. Just because it may be able to be incorporated into an existing 2010 "in the future" doesn't mean it will be a direct drop in, despite what may be claimed now. My Prius is family car, not a hobby for me. (Although it certainly is addictive).
    • I work in a very technical industry. I only like beta testing when I get paid to do it. I may beta test software on my own time occassionally, but that is minor compared to the hassles of beta testing "major" hardware that I would own and have to live with.
    • I have no interest in a plug-in at this time. But that could change depending on the features that are brought to the table in future models.
    When I bought my Prius a couple of weeks ago, I knew the 2010 was coming out. Granted, I didn't know as much about it as I know now that I've joined PC. But even if I had, I still would have most likely bought the '09. I figure that the discounts that Toyota is giving now, even though small compared to those for some of the American cars, will probably mean that I got a better deal than waiting for a new model with potentially higher pricing.
    Once all the courageous early adopters have done the beta testing, I may jump in down the road. There's an old saying, "The enemy you know is better than the one you don't". At least G2 is a known entity.
    And I may even wait until the new battery technology has come out and been fully proven.
    Anyway, that's my 2 cents and the reasons that I see myself staying with the 2009 right now.
    3 people like this.
  14. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I just sold my '04, almost 190,000 km on it but I thought with the age and km's, time to consider something newer. It will soon start a new life as a taxi. Given the recent slump in Prius sales, I'd be perfectly happy with an '09, especially if I can get a good deal
  15. yardman 49
    606
    77
    Northern Kentucky
    Since I posted this a few days ago, I've looked at more photos of the 2010, and compared them to my new 2009.
    I've come to the conclusion that another aspect of the 2010 redesign that I don't really like is related to the roof line change, in conjunction with the redesign of the rear running lights/stoplights. The combination of these changes seem to make the car look "shorter" overall. Kind of "stubby" looking in the back. Definitely not as graceful as the 2009.
    So after looking at my new 2009, and comparing it to the 2010 photos, I think that the 2009 is better looking. But that's just my personal taste.
  16. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    See to me its the exact opposite, "graceful" is never a word I would use to describe the G2 Prius. Its top heavy looking with little wheels to me, nothing smooth or graceful about it IMHO. The 2010 however I think is much lower looking, more stable looking, and more "graceful".
    You've got to see the car in person...
    Anyways should you upgrade from a 2009 to a 2010, normally I would say absolutely not because the depreciation hit is just too enormous to be worth it. However, if what you say about the market is true in Alaska where you would take a small hit of only a couple grand then why not.
    I think you are wrong though, it just doesn't make sense. Lets say the 2010 Prius is similar in price to the 2009 (which I think it will be), if you were buying a Prius and you could buy a 2010 for $1,000 more than a 2009...which would you buy? Plus you have to trade the car in unless you want to sell it yourself and even if the dealer could sell it for $1,000 less than its new price, they have to have some profit so they aren't going to give you anywhere near that on a trade.
    I think you will be dissapointed with what this will cost you, I bet it will cost you $5k-7k at least to make this swap.
  17. Spidey126
    Spidey126 New Member
    Philadelphia, PA
    given the new prices, whats your outlook on this?
  18. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Here's a thought ....
    I looked into trade in when mine was about 3 months old ....
    The sales manager said the trade in negotiation would start at about $15k ...
    to which I started laughing in one of those 'you've got to be kidding voices'.
    $15 ... k .... for a car I am paying over $30k for ....
    Ah, no, my 09 is a keeper. can't be throwing money away like that. I chose it, that's it.
  19. smartalec89
    133
    anchorage, alaska
    Well the pricing is nice but, I think I will be keeping my 2009. I was told trade in value for my car today would be 18,500. This is ok but not great. I also just invested $430 on a Yakima rack so I am kinda stuck with it. I plan to install a hitch as well. I really have learned to love my silver bullet lately.
  20. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    There's your mistake. Dealers will never give you a great deal on a trade in. They'll give you a low trade in value then turn around and sell your call for a couple thousand more.
    If you want more $ for you car, sell it via private party but maybe it's best to do it pronto before 2010s hit dealers and more incentives & discounts get applied to remaining 09s.
