fob setting of many alarms...
Discussion in 'Gen 2 Prius Main Forum' started by xsmatt81, Apr 25, 2009.
  1. xsmatt81
    xsmatt81 non-AARP Member
    522
    Vegas
    Its embarrassing. It just chirps as I pass through the detector..it does it at targets, wal greens, and various other stores. Walmart it does not happen for whatever reason.
    the funny thing is I only started noticing this strange phenom the past few months.
    does this happen to anyone else?
    generally the store employee's do nothing because the alarm is not actually set off..just a few beeps as I pass through and strange looks sometimes. It's so bad I actually raise my arm as high as possible now when going through one to try and bypass the beams.
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Pay for your items before you leave the store ... problem solved.
  3. bstanier
    bstanier New Member
    Sedgefield, UK
    Some of the store alarm systems may not be able to distinguish between a simple absorption security tag and the receiver circuitry in the fob. If you get some response but no actual alarm its probably because the system detects the fob but isn't sure its a tag. Complain to the store(s) that they should buy a decent system!
  4. qbee42
    3,074
    Never had this happen. I carry my fob always when away from home, so I know I've gone through many anti-theft systems with it.
  5. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    Never had this happen. But it's their problem...
  6. xsmatt81
    522
    Vegas
    it's not that big of a deal honestly, most of the employee's near the entrance just look over then go about their business. It has happended in several places.
    Walgreens, target, CVS, Lowes. Not that this matters..whomever supplies the scanners is at fault obviously, they are just to sensitive.
    Im not going to complain to management over something trivial. I was just curious if others had experienced this.
    and from doing a quick search(which I should have done first)..there is another thread with a member on here complaining of the same issue.
    Toyota is not the only car maker doing the RF fobs now, so Im sure it's actually quite common with certain detectors.
  7. qbee42
    3,074
    You can always try my approach of peeling off security tags and dropping them into other shoppers' bags. The resulting cacophony of alarms will mask the chirp coming from you. :D
  8. Qlara
    Qlara New Member
    488
    That's strange, I went through the same stores: Walgreens, target, CVS, Lowes with my SKS fob and never had issues....is it just the Vegas thing? :D
  9. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Or, you could be one of those rare human Malfunction Magnets. Try walking through a detector without the fob.
    If the detector still chirps, keep removing your keys, wallet, clothing, etc, until you're bare but still setting off the fob. That would prove my Malfunction Magnet theory
