Help Diagnosing Unintended/Uncommanded Acceleration Issue
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nylion, May 2, 2009.
  1. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    I had an older car with a carburetor. The heat stove pipe rotted/fell off in the dead of winter. I noticed it was running a bit rougher than usual, but blamed it on the cold weather
    Light turned green, stepped on the gas, all was well. Lights ahead turned red, I lifted my right foot, car kept going. Shifted the auto to N and the engine really raced, so shut the motor off. Pulled over, took the air cleaner off, and the throttle lever was STIFF.
    Left it alone a few minutes, and the residual engine heat was enough to melt the ice. Went on my merry way
    One thing to keep in mind is that most new vehicles now have electric throttle control, there is no longer any direct connection between the accelerator pedal and the engine. If there is a common defect, say a vulnerability to EMI, we'd be hearing about it by now
    Even HD trucks have had electronic throttle control for awhile now. Eg the Detroit Diesel 60 with DDEC IV has had electronic throttle since around 1997. I'm not aware of any semi trucks accelerating out of control but there have been complaints of the pedal going dead and leaving the truck stranded on the side of the road
    Toyota has obvously had an issue with floor mats, hence a TSB regarding same. Even with my FJ, the book warns that if the floor mats become unsecured and end up *under* the gas pedal, you could have unintended acceleration or no control over vehicle speed
  2. Ct. Ken V
    Ct. Ken V Active Member
    535
    57
    Bolton,CT
    all,
    One last consideration for nylion is that it is an '06 with 33,000 miles on it, so he's nearing the end of his bumper-to-bumper factory warranty (I'm guessing only a few months left---he joined in June 2006 & he said he joined before he bought his car). I don't think it's clear if he took the car to the dealer after any of the previous un-intended acceleration incidents (but I would certainly hope that a person experiencing such a serious situation would not just let it go un-checked by the dealer), so there may or may not be any previous record (except for today's dealer visit) for Toyota to consider in the future if this isn't cured for good today & re-surfaces in the future after his warranty is definitely done (usually Toyota has been pretty good about covering a repair that is done after warranty expiration if there have been reports/complaints in the dealer records even if the condition wasn't able to be duplicated to be diagnosed & therefore not repaired at the time of the earlier "in warranty" occurances).
    I'm not sure if any of his incidents would throw any codes (although a brake failure one was discussed by one of the responding posters), so the tracking down of the cause(s) of his incidents & the replacement of parts and/or repair could get pretty expensive on nylion's dime after the warranty runs out. Therefore I think it's imperative that his car spend some "quality time" with his dealer if he hasn't been in after the previous incidents (or at least reported them) so they can find a cure before his warranty runs out. And hopefully he may have bought the official Toyota extended warranty which will not only give him longer coverage for the dealer to do more checks (& pay for any work if this condition continues to occur after the factory warranty ends---he still has time to buy that from Troy/Warranty Shack right here on PriusChat for a great, unbeatable price), but it would also provide a free rental car while his is being kept (if longer than 24 hours) unless he has a good dealer who would provide one free out of the goodness of his heart anyways (yeah, not likely). I hope everything turns out successfully.
    Ken (in Bolton,Ct)
  3. richard schumacher
    7,664
    1,046
    United States
    Yes, this sounds like it might be a real instance. nylion, if it happens again without a mat installed, please get it to a dealer within a day to see what trouble codes were created. Good luck!
  4. hill
    8,894
    After hearing about 4 ... maybe 5 instances of this ... who knows ... it's not impossible I suppose. I'm sure corporate Toyota is looking into it ... even though we're talking 5 out of a million cars produced. Stats say that's virtually nil. Is it possible the victims were off in la la land? (who among us hasn't been on the phone, only to realize we've driven for miles w/out realizing it). Is it possible some of 'em stomped on the brake instead of the gas? Maybe 1/2 of 'em? When you're talking a million cars ... billions of miles/hours ... stranger things have happened.
  5. nylion
    nylion New Member
    167
    61
    Seattle WA
    I took delivery 7/31/2006. So I have some time left. I also have Geico's mechanical repair insurance which is good for 7 years or 100,000 miles. Repair costs aren't a problem. My local Toyota dealer also provides free loaner cars (nice new cars!) so I am coverred there too.
    I thought it was me, not the car, on previous times this happened. I couldn't believe a car could do that on its own. Oh, my dealer checked my mats this morning when I dropped the car off and agreed the mat could not cause the problem.
    I will keep everyone posted. I am not optimistic that the dealer will find the issue.
  6. Ogo
    Ogo Prius Owner since 2008
    220
    44
    Ilirska Bistrica, Slovenia
    What I noticed on my Prius (2008) is, that under certain conditions, electric motor boost can quickly "kick in", which results in unintended sudden increase in acceleration. But it was completely controllable. The same millisecond I removed my leg from accelerator pedal, it ceased to accelerate. And of course this was noticeable under low speeds, around 10 to 15 miles per hour, when I was driving on extreme uphill and ICE torque was low (spinning around 2100 rpm).
    Probably some fine-tuning to be done in software somewhere not to scare the driver out with extreme electric motor torque.
    Ogo
  7. FL_Prius_Driver
    FL_Prius_Driver Senior Member
    4,319
    1,527
    Tampa Bay
    I
    The problem described sounds like it could be caused by any mechanism that does not let the accelerator return completely to idle position. Is there anything described that is inconsistent with this?
  8. nylion
    nylion New Member
    167
    61
    Seattle WA
    Yes. The car was stopped and the ICE was off. Reducing brake pressure caused the ICE to rev and the car to try to surge forward.
  9. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
    I had that too until I dropped it when I renewed my Geico insurance policy this past February.
    What do you think or know about it?
    I'm thinking of adding it back in when the Prius' basic 3 years/36,000 miles warranty expires next February.
  10. nylion
    nylion New Member
    167
    61
    Seattle WA
    UPDATE
    The dealer was unable to reproduce the problem and therefore took no remedial action. Not a surprise, but a concern to me. This appears to be what happens every time someone has this problem. I can't blame the dealer. The Prius has no codes that would help diagnose this issue.
    I get the feeling that the dealer and Toyota won't even look into this until the problem occurs during the service. Since it is so rare, only 2 or 3 times in 33,000 miles, ,the odds the problem would be observed by the service staff is near 0.
    As Bob pointed out, this leaves me in a very uncomfortable position. I need to keep driving the car. I know the problem is real. The good news is that it happens very infrequently. The bad news is that if/when it happens next, I could be hurt or hurt someone else.
    I found an article that talks about some others who claim to have this problem. It is in the Seattle Weekly Seattle News - The Flip Side of the Perfect Prius - page 1.
    I can't vouch for any of those stories, just mine. I don't want to stop trusting my car.
    Bob
  11. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi dogfriend,
    Good Idea. The partially open throttle would result in a rapid vehicle accelleration after lifting the brake pedal, as the engine would get turned on at that point, and the fuel control would feed the appropriate fuel to match the intake air mass, which would be excessive.
    NYLion,
    As a shot-gun repair approach, have that the throttle body inspected, cleaned, and the mass sensor cleaned, and also have the engine air filter replaced. Have you ever had the engine air filter replaced? This should be under $150 for this service.
    Is that mat out from under the driver's feet yet ???
  12. FL_Prius_Driver
    4,319
    1,527
    Tampa Bay
    I
    I remember someone reporting something strange happening when their brake light switch had one pole fail. It had some strange effect on cruise control (e.g. cruise control would not turn off or something like that.) Does anyone recall that problem and its effect? From your description, it really sounds like something intermittent mechanically whether it is a switch or throttle, etc. The ECU gets lots of different signals and you could be one of the few cases where the ECU is getting conflicting signals from a hung switch or accelerator hall sensor not fully returning. Read Mike Dimmick's post closely.
    It's really outside the dealers expertise to be knowledgeable on every permutation of failure (there are probably over 10,000) so making a real detailed record to send to Toyota USA or even Toyota Japan would actually be a more effective course of action than expecting a dealer to divine an answer with no DTC's. Your offer to instrument the car would certainly identify you as an reasonable driver wanting to resolve a unique problem. The dealers are definitely not set up to do that and have few options other than to admit their limitations.
  13. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Ok.
    You live in a world where calling a person a troll is not a personal attack???
  14. Tideland Prius
    16,598
    That's why I said make a video of it. You said the car was stopped with the ICE off on page 5. So that means you're in a safe position. You can video tape it revving while your foot's still on the brake pedal.
  15. richard schumacher
    7,664
    1,046
    United States
    nylion, after re-reading the thread I want to be very clear on something: was the car accelerating (that is, moving and increasing speed)? Or was the engine revving up without accelerating the car?
  16. nylion
    nylion New Member
    167
    61
    Seattle WA
    I don't keep my camcorder in my car (obvious reasons) and I doubt I would have recording on my mind when it occurs. For the record, the dealer did not doubt me. This isn't a case of people (except for some "interesting" characters here) believing me. It is more a classic debugging problem; you can't fix something if you can't reproduce the error.
    I am in the software industry. I am painfully aware of how difficult it is to catch edge cases (which my problem surely is). The only way I know to catch these elusive bugs is to record all events and when the edge case finally happens, there is a record of what caused it.
    None of the standard codes that the car stores would help here. My dealer confirmed that. Bear in mind that Toyota only saves codes for what it *knows* are problem conditions. To debug this acceleration problem, an event log would be required that stores all events. Usually this is done by recording a fairly short time period, then rewriting.
    I am certainly willing to have the instrumentation on my car. I just have no connections to the people who would understand what is required and have access to the data recorder needed. If I had an onboard recorder, I could manually stop it when an incident occurs (thus preventing the data from being overwritten).
    FYI, the reason I posted this all here, other than the fact that I have been a member for a while, is that I hope someone from Toyota US, or someone who knows someone, would point them at this problem. If nothing else, my car definately exhibits this behavior. I am not adverse to helping Toyota solve the problem.
  17. nylion
    nylion New Member
    167
    61
    Seattle WA
    The car was stopped at a traffic light. The ICE was either off or idling. When the light turned green, and the instant I reduced pressure on the brake pedal, the ICE revved and the car surged forward as though I had floored the accelerator. Pressing back down on the brake stopped the car. Reducing pressure made it surge again. I repeated this 4 or 5 times. At no time was my foot or anything else even near the accelerator.
  18. bwilson4web
    16,326
    You've given us a lot to think about and I'm glad you understand the problem intermittent ("edge") problems. Most of all, I appreciate a commitment to chasing this to ground ... even if unexpected.
    In the NHW11, the hybrid vehicle ECU commands a power level to the engine ECU that handles the throttle and other engine systems. So again, we're back to the common element, the hybrid vehicle ECU. Hummm.
    Now I've only seen one NHW20 accelerator but I remember the pedal is mounted on a "U" channel but I don't remember if it is closed on the bottom. Perhaps some of the other NHW20 owners can confirm this? I'm posting about the lever the pedal is mounted on. In contrast, the NHW11 pedal is mounted on a solid rod.
    I don't like to suggest an untestable hypothesis but I would probably look very closely at the surface of the mat under the accelerator. In particular, I would bend it back just to see if there is any evidence of a crack or slot ... But again, I've only seen an NHW20 accelerator assembly once and only briefly.
    A wild thought, would you consider putting a layer of aluminum foil on the upper right part of the mat, possibly held with duct tape, just under the accelerator? The goal is to see any pedal impression in the foil. This provides empirical evidence of whether or not the accelerator pedal was reaching the mat ... without drawing any conclusion. This is just a passive approach to help eliminate one hypothesis. In the case of the NHW11, the pedal assembly has a mechanical stop so the pedal arm can never reach the floor with any appreciable force. But there is not a whole lot of space between the pedal and the carpet.
    The bad news is I have always found that without some corrective action, even 'shotgunning', intermittent problems will come back. The good news is this thread is beginning to address things to check. I'm sending a note to the moderators suggesting this thread might do with a more helpful subject line, "Diagnosing Unexpected Acceleration," which reflects the current tone.
    One other thought, there is a separate communication network that goes from the hybrid vehicle ECU to the engine ECU. I don't know enough about the protocol (aka., is there a CRC?) but if there were a 'noisy' connector (the bane of my existence,) reseating the hybrid vehicle ECU and engine ECU connectors would make a lot of sense.
    Have you gotten a vehicle repair manual? Avoid the Chiltons sold at the car repair places ... I got one and it was nearly useless. There are reports of a better one Bentleys(?) that may have more details.
    A better answer may be to check Ebay for 2004-2009 repair manuals, $100-300, (unless you prefer electronic manuals.) They are a valuable roadmap to understanding your car's systems.
    For grins some day, try the "forced charge:"
    • Hold brake, hard
    • Floor accelerator
    • Watch battery SOC - this is an under documented procedure that I too was skeptical about. The engine will run putting a charge on the battery, typically 5-10 minutes, until it reaches 80%. Then the engine will shutoff. I don't recommend it as a regular practice but knowing about it and a short test, say 1-2 minutes, is enough to 'take the newness off'.
    There is an instrument called a Scangauge that I understand has the ability to send a stream of observations to a laptop. I have something similar for my older NHW11 Prius. This might be an approach for instrumenting your car and keeping a record of what happened. I'm planning to take one of my older laptops and making it into a permanent data recorder but that is something for another thread, another day.
    I'll continue to poll this thread from time to time. However, it is perfectly OK to send a "PM" or "email" about any new posting to the thread after a couple of days or weeks. Please try to share the technical details with the community in this thread, there are some pretty clever folks here and I'm a strong believer in team efforts.
    Can you tell me about the weather when these incidents have happened? In particular, was there a pattern of unusual dryness that might support a static electricity discharge through the accelerator assembly?
    If anyone has an photos or detailed sketch of the accelerator assembly, I would be very interested. I've got some experience with the NHW11 version and I'm interested in the mechanical area that is blocked from ordinary view.
    Unless the problem is diagnosed and corrected, I'm sure it will come back. All we can do is be a useful sounding board and offer our best expertise.
  19. pnerd
    pnerd Junior Member
    30
    I came across that article a few days ago, while googling info on the '10 prius.
    It scared me.
  20. pnerd
    pnerd Junior Member
    30
    Any typo in the red-highlighted region above? do you mean the brake pedal?
