Weird Sound after installing new air cleaner
Discussion in 'Gen 2 Prius Main Forum' started by djasonw, May 2, 2005.
  1. djasonw
    djasonw Active Member
    962
    123
    Coconut Creek, FL
    I was cleaning my car yesterday and decided to check the air filer. It was last changed around 15,000 miles. I now have 27,000 miles and when I checked it, it had some debris in there and it was kinda dirty. Since the filters are so cheap I decided to throw a new one in. This is a GENUINE Toyota filter. While driving to work today I noticed that under heavy throttle, there appeared to be a louder sound than normal. Under light to moderate throttle input the engine sounds the same. I checked when I got to work whether I didn't clamp down the air box on, but it was all snug and the filter can only be installed one way. Anyone have any clues??????
  2. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    Make sure the cover is properly aligned and tight. It sounds like you have an air leak.
  3. randalla
    randalla Member
    370
    Lexington, SC
    I had a similar experience and found that I must not have seated the top plastic housing perfectly into the bottom half. Give it another try and hopefully it go back to sounding normal for you.
  4. djasonw
    962
    123
    Coconut Creek, FL
    Thanks guys!! You were right! I went out and to my car and sure enough the top part was NOT seated properly. All is well now....
