Radio problem
Discussion in 'Gen 2 Prius Audio and Electronics' started by Porky Pine, May 6, 2005.
  1. Porky Pine
    Porky Pine New Member
    86
    Newtown, Ct
    I was wondering if anyone else had this problem. Lately, whenever I listen to the radio, the radio keeps shifting it's freq's on me. I'll have it tuned to 1190AM and it will intermittently either:
    1) change the freq to 1180, and then, after a couple of secs, go back to 1190.
    2) change the freq to 1200, and then it might shift back down to 1190 but usually stays at 1200 until I set it again to 1190.
    This problem also occures in FM.
    I was just wondering if I was the only one with this problem.
  2. rick57
    rick57 Member
    572
    Circleville, Ohio
    Hmm,never heard of that here, :roll: . Maybe something you are doing? Maybe check that the tuning dial is not stuck in the detent postion?
  3. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    That's really odd.
    I agree with Rick except that if a button depression were causing the change, there would be a beep. Most likely. Because the car wouldn't know if the button were depressed intentinoally or not.
    But since it happen on AM and FM, you should really have it looked at.
  4. seeh2o
    seeh2o Prius OG
    447
    City of Angels
    <div class='quotetop'>QUOTE(Porky Pine\";p=\"87682)</div>
    You know, now that you mention it I remember that happening to me once while driving through the desert to Las Vegas. I can't remember if it happened on AM or PM, but it did happen. I thought I was losing my mind. It only happened on that trip, never again. I guess I chalked it up to that and forgot about it until now! Weird.
  5. TUK
    TUK New Member
    San Jose, Ca
    I had that happen to me as well. Drove me nuts for a couple of days. Finally figured out that the channel knob as causing it. I turned it to a new position and have not had the problem since.
  6. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    It happened to me with volume. I believe the knob was the problem. Played with it a bit, problem has never shown up again.
