Mystery Mod from previous owner.
Discussion in 'Gen 2 Prius Accessories & Modifications' started by darkdragon1976, May 24, 2009.
  1. darkdragon1976
    darkdragon1976 New Member
    Las Vegas, Nevada
    I'm new round here. Just got my 2007 Prius Pkg 6 Touring.
    I just received my new-to-me Prius yesterday. Everything is in working order as far as I can tell. There is this strange thing on the dash though and the dealer (Carmax) couldn't shed any light on it. My husband thought the great folks here at priuschat would be able to solve the mystery or at least help.
    I'm including a couple photos of the item. It is on the dash right by the window of the pasenger side. There is cord of some sort come out the back (front?) of the device (you can see it in the window reflection). It is only about an inch square and 3/4 inch tall for the upper portion, the base seems to be about 2" on each side.
    from outside
  2. TonyPSchaefer
    14,816
    2,500
    66
    Far-North Chicagoland
    Please post a picture as seen through the windshield.
    I'm at a loss as to what it can be.
  3. darkdragon1976
    Las Vegas, Nevada
    Just did, probably as you were typing that.
  4. TonyPSchaefer
    14,816
    2,500
    66
    Yeah. Thanks.
    Didn't help me, though. I'm hoping someone else has a clue.
  5. brick
    brick Active Member
    1,083
    79
    Upstate NY
    That's an XM antenna. I have one just like it stuck to my roof! (Because I put it there.)
  6. DianneWhitmire
    DianneWhitmire High PRIUStess
    4,062
    1,123
    64
    Laguna Niguel, CA
    That's for your XM audio -- so your car has XM.
  7. darkdragon1976
    Las Vegas, Nevada
    Oh cool. Thanks guys!
  8. exbauer
    exbauer Active Member
    1,188
    102
    Washington
    i think they changed over to putting the antenna on the inside of the car. but, yes you do have XM.
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Could be the GPS antenna to connect to a PC.
  10. Shin Chan
    Shin Chan Junior Member
    56
    Sacrameto, California
    That is an XM-Radio antenna sitting on top of a waffer thin slice of metal that has double sided tape to fix it to your dash. If you push the SAT/AM on your radio you should get XM-radio (unless the subscription has ended or never was activated).
    My parents have their XM antenna mounted like you do, while I have mine near the FM/AM antenna. The antenna mounted on the dash means no one can screw with it, but I feel the reception is a little more finiky compared to the rear mount.
    If you find that the XM subscription has ended or never was activated, and you want to activate it you need the XM radio ID#.
    Go to the link below and follow the instructions
    Enter the 8-digit XM Radio ID exactly as it appears on the back of the XM Radio or tune your radio to Channel 0.
    https://xmro-secure.xmradio.com/listenercare/login2.xm
  11. thomatt12
    thomatt12 New Member
    61
    I have a question though. If it is a radio antenna then why is it installed inside the car and on the dashboard?
    __________________
    Mazda Accessories
  12. DianneWhitmire
    4,062
    1,123
    64
    Laguna Niguel, CA
    Because it's what takes the signal from XM or Sirius.
    It's valuable. If stolen, it would cost hundreds to replace -- that's why it's there on the dash. Inside, there it can be locked up!
  13. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Hundreds of dollars?!? You could probably get a new antenna for $10 on ebay, $20 or so new at the retailer. Heck, the entire XM radio that I'm currently using only cost $50. Getting the integrated system could conceivably cost a couple hundred but that's about the most expensive option that an average reasonable person (if there is such an animal) would consider. And it still uses an inexpensive antenna like the one pictured.
  14. PriusLewis
    PriusLewis Management Scientist
    1,002
    84
    Denver Metro
  15. gdbelden
    gdbelden Gator Hator
    66
    70
    Virginia
  16. HybridHewitt
    HybridHewitt New Member
    Mine looks like that and I bought my right off the truck so might have been that way from the factory like mine was.
  17. hill
    8,757
