front-end damage
Discussion in 'Generation 1 Prius Discussion' started by b2kon, May 18, 2009.
  1. b2kon
    b2kon New Member
    2001 Prius
    My daughter bumped into an SUV and hit the trailer hitch right in the center of the hood. It bent the big aluminum I-beam and hit the radiator. the radiator had a leak. otherwise, i did not see any other damage. The air bags did not deploy. But the car would not start. It just gives this ERROR thing. I tried disconnecting the battery to try and reset the computer but I still get the ERROR when I turn on the ignition.
    I am still deliberating on whether to bring it to the Toyota dealer for estimates or just sell it "as is". Any ideas on what the damage could be?
    Thanks to all!
    P.S. I am in northern CA, east bay area, Concord. Any suggestions on other shops that work on Prius'es?
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    Well, if you have AAA Platinum service, that will get you 100 miles of free towing, flatbedding to the shop of your choice. A radiator can be replaced, the hood, and the strut can be fixed..Maybe 3k? first cost guess.
    The error code probably is a "Engine Coolant Low" warning, just a guess there!
    Do you really want to get rid of the old girl??? What woud you get to replace her?
    A 2010 model perhaps. Maybe fix it up, trade it in on a newer one.
    I woud not be putting a bullet in her block, before checking with the Doc!
  3. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    Theres no engine coolant low code, the problem lies somewhere else, do you have picture of the damage? I suggest you triple check the mass airflow sensors and air intake system, check for codes, get a OBD 2 reader ( 01-03 prius is OBD )
  4. Patrick Wong
    18,200
    6,474
  5. b2kon
    b2kon New Member
    2001 Prius
    Here's a picture of the damage.
    How do I attach pictures? I did the attach using a URL but this is what happened.
    Here's the URL instead.
    http://cl4sale01.multiply.com/photos/album/5/prius
