Why there's an on button for cruise control
Discussion in 'Gen 3 Prius Main Forum' started by whoever, May 26, 2009.
  1. whoever
    whoever New Member
    Not particular to 2010 Prius, but why all Toyota cruise control has an On button, then set switch ...
    Why can't the system turn itself on when you set? Are there lots of overhead leaving it on? Thanks.
  2. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Its a safety measure, to make it harder to accidentally turn the system on. Requiring two steps, on then set, reduces the likelihood of that happening.
    I think pretty much all companies work that way...certainly every car I've ever owned requires being turned on.
  3. hschuck
    hschuck Member
    385
    bay city, ca
    By design, to lessen the chance of accidental activation.
  4. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    hmmm, good question.
  5. whoever
    whoever New Member
    Thanks for the quick update. That seems a reasonable explanation, although without an On button, the system should automatically be off when you tap on the brake. So no harm done even if it's on by accident (assuming you do not habitually fumble with the switch).
    So I have to assume there's a lot of overhead turning/maintaining cruise control on?
  6. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    Its as silly as having the lawyer button on the NAV.
  7. qbee42
    3,079
    In the case of the Prius, there is no overhead for cruise control. The Prius has a drive by wire throttle; cruise control is just software in the ECU.
    As the other posters said, the ON button is for safety. It makes it harder to accidentally invoke cruise control, and also makes operation consistent with older cruise control systems that were add ons.
  8. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    It gives the "OFF" button something to do!
  9. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    I think the real issue is that there should be a separate indication for Cruise Control being activated rather than just being on ... to clarify ... when you turn on Cruise (w/o setting it) the "Cruise" light illuminates, but when you actually set the cruise there's not a separate indicator.
    That is where the issue is imho ...
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    well, um actually there is. it will advise if CC is "set" dont know if anything comes on before its activated.
  11. SW03ES
    2,480
    176
    Gaithersburg, MD
    The Gen II car and all other Toyota vehicles I've ever had experience with simply illuminates a "CRUISE" light when the cruise is turned on and has no seperate light for it being set...
  12. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    ...wrongthread...
  13. hntr467
    hntr467 New Member
    22
    Rockford, IL
    :confused: What does State Farm's glass coverage have to do with cruise control? I'm confused!:eek:
  14. Tideland Prius
    16,615
    I think he was reading the other thread where roseyrose (I can't remember the exact screenname) had the front glass deflector of the solar moonroof chipped and cracked.
  15. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    Not in the '09s and prior it doesn't ... you turn on the system and "Cruise" comes on in the digital cluster ... when you hit set on the stalk, nothing changes in the digital cluster ... "Cruise" is still illuminated like prior to setting.
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    ok i will clarify...on the 2010. when you turn CC on, an icon that looks like a gauge comes on. when CC is actually engaged... "set" illuminates
  17. Husker4theSpurs
    656
    128
    Papillion, Nebraska
    Awesome! One more improvement I didn't know about ... thanks for the clarification!
  18. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    Owned Toyotas in past, and on my current Lexus - always been a (small) irritant - having the "cruise" indicator light in the dash come on, but nothing to show when it's set/activated.
    So this is good news (minor, but a nice add by Toyota).
    I assume that the '10 Prius has the typical Toyota stubby cruise stalk on the steering column. Small multifunction lever on the steering column - on/off, set, res, cancel - at the 4 o'clock position under the wiper stalk. Hope so, as I feel the Toyota's cruise lever is the easiest out there - nice feel and easy reach...fingertip away.
  19. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    yes
  20. SW03ES
    2,480
    176
    Gaithersburg, MD
    Cool! I like that better too...
