Prius won't start!!!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by TMahon0691, May 27, 2009.
  1. TMahon0691
    TMahon0691 New Member
    Albuquerque, NM
    My wife & I have a new 08 Prius, bought in July, 08. Twice since we've owned it, first less than a month after purchase and just yesterday, the unit refused to start up. Just sat there in our garage.
    The first time, a couple of hours later, as we were getting ready to call the dealership, it turned over when we asked it to. We drove it into the dealership where they diagnosed it and adjusted some software directions.
    OK
    Yesterday, it died again. We called the dealership and they had it towed in. The technician called me this morning to report that it started up for them just before closing and that they were looking for the reasons why it failed.
    Their diagnostics showed no evident reason for failure, but twice in a year is out of line. Anyone have similar problems????
  2. Rokeby
    Rokeby Member
    3,033
    710
    75
    Ballamer, Merlin
    TMahon0691,
    :welcome: to PriusChat.
    If the car fails to do anything when you attempt to start it, the most
    likely scenario involves some failure involving the 12v battery.
    Since the car eventually starts, the battery itself may be OK.
    So, next in line comes the battery connections. Most likely problems
    here are loose connections at the battery itself. Then comes a possible
    loose or corroded battery grounding wire where it connects to the
    body, under the (removable) floor on the passenger side in the rear
    hatch area.
    Hope this helps.
    BTW, when you took the car in the first time, did the techs/service
    writer mention anything about retrieving any codes?
  3. richard schumacher
    7,666
    1,047
    United States
  4. Mike Dimmick
    Mike Dimmick Active Member
    963
    249
    Reading, UK
    The power source control ECU only looks at the brake light switch, not the stroke sensor or pressure sensors. If you're pressing the pedal moderately hard, the brake light switch should be switching on.
    The OP doesn't say whether the car won't even switch on into ACC, or whether it just won't go READY.
  5. Tweev
    Tweev New Member
    121
    San Diego
    just to make sure, you do have the brake down when trying to start the car, right?
