Adaptive Cruise
Discussion in 'Gen 3 Prius Main Forum' started by Wooski, May 29, 2009.
  1. Wooski
    Wooski New Member
    241
    63
    London, UK
    For those lucky buggers with their US model V's and ATP - have any of you had a chance to play with the Adaptive Cruise? I've seen someone posted a pic and it looked cool.
    Here are my questions - if you would be so kind. (I've not had access to an owner's manual - no doubt the answers to these questions would be in there):
    1. Do you have to set normal cruise first and then select adaptive (i.e. the distance radar) afterwards?
    2. If your speed limit changes (e.g. from say 50mph down to 40mph) do you just click down the speed on the usual cruise stalk? When clicking this down does it go down in steps - e.g. each click is 1mph or is it something like each click is 5mph? (like on BMW's)
    3. How well does it work in practice?
    Thanks!
  2. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    OK. I'll take a shot at your inquiry -- and not just because I posted the pic, but I don't know how many others have had a chance to play with the ACC feature. I had a 360 mile two-day round trip the past two days, so I've been able to try a couple of the ATP features.
    The factory setting defaults to the "farthest away" distance setting, so when you press the ACC button (on the steering wheel) and then engage the cruise control, you are set to go with the longer following distance. You may change the distance among three pre-sets. Truly, the whole process is quite easy. I never really bothered with turning the ACC on or off or setting distances. It was set to go on, and when I turned on the cruise control (per "normal"), it came on and showed (on the MID) the "farthest away" setting had been activated.
    If you wish to adjust your speed, you may push the stalk up or down, depending on whether you want to increase or decrease your set cruising speed. I don't recall the incriments, but I believe it is either one or two MPH per "push" of the stalk.
    If you are asking about speed adjustment due to vehicles in front of you, it is all automatic. If you have set your preferred speed in the cruise control (and the ACC is activated), then the Prius will slow down so as not to get closer than the selected trailing distance (from among the three allowed). If the vehicle changes lanes, exits or speeds up, the Prius will increase speed to the point of attaining the following distance behind another vehicle or reaching your prior-selected cruising speed.
    If works VERY well. It is very easy to use, and I found it very helpful. In fact, it responds very quickly but not in a "panicky" way. I was cruising at the farthest distance behind a truck when a car suddenly cut it between us. The ACC immediately backed off of the accelerator (without applying brakes) and reset the appropriate distance. When the jerk again quickly changed lanes, the ACC accelerator up to the appropriate speed, with distance separation.
    I hope this helps!
    8 people like this.
  3. Wooski
    Wooski New Member
    241
    63
    London, UK
    That's very helpful thanks. I'm glad it just automatically comes on when you select cruise (once you have activated it). It's a feature I'm very interested in. It's normally only an option on pretty high end cars.
  4. Dondoh
    Dondoh Aleatory Specialist
    96
    27
    rural hall, nc
    Is there a "truck drafting" mode?
  5. a priori
    3,083
    408
    Chicagoland (West)
    The funny thing is that I wondered just how close the "closest" mode would be. I didn't adjust it, because I was comfortable at the farther distance. I think I'll try later on, but I don't know how comfortable I'd be with the cruise control on at a close distance.
  6. jprates
    jprates https://ecomove.pt
    387
    42
    Moita, Portugal
    2017 Prius PHV
    But will it apply brakes at all if necessary?
    I mean, if releasing the accelerator is not enough to maintain distance, will the ACC apply brakes to the car?
    TIA
  7. Gakubuchi
    Gakubuchi New Member
    68
    Catalonia
    And, if so, how low will it go? if the car in front is breaking to full stop, will the prius also stop? I guess the answer is no, but just asking...
  8. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Well it does have collision avoidance too, but I don't think I want to test it! :D
  9. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    You can always choose the safest route which is read the user's manual and let us know what's written there... ;)
  10. Tideland Prius
    16,559
    It will apply the brakes but will not bring the Prius to a full stop like the more advanced system on the Lexus (or MB for that matter).
    If braking power is insufficient (i.e. the computer applied the max it is allowed to apply), the car will beep at you and the word "BRAKE!" will appear on the MID.
  11. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Boy, this crowd really has high expectations! Here's all the basic info from the manual:
    1. It is turned on, set, resumed, etc. just like every other Toyota cruise control, using the same basic cruise control stalk. It defaults to using the adaptive speed control, but you can force it to use constant speed control by pressing the stalk away from you for 1 second. Once you set in either mode, you have to turn cruise off and on to change back to either set speed or variable speed. The only other difference is that you have an extra button on the steering wheel that you can press to cycle through the following vehicle to vehicle distances: long=160ft(50m); medium=130ft(40m); short=100ft(30m). It defaults back to long every time the car is turned off. Looks like the display will show 1, 2 or 3 bars between vehicles to indicate what mode you are in.
    2. As expected, it will decelerate if it detects a slower car. If a greater reduction is needed, it will apply the brakes. A warning tone sounds "when the system cannot decelerate sufficiently to keep your vehicle from closing in on the vehicle ahead". A later paragraph, describing "Approach Warning" says "the display will flash and a buzzer will sound". There are several possible display warnings and corrections: Clean Radar Sensor; Cruise Control Not Available (try turning your wipers off or to slow or intermittent); BRAKE! (indicates high risk of collision or that collision avoidance is working); a diamond with ! in the middle (high risk of collision); and a flashing Cruise symbol (2 cars with bars between them - indicates vehicles are approaching each other and you should slow down).
    3. Adaptive cruise shuts down if (i) speed below 25 mph (40km/h), (ii) VSC comes on, (iii) wipers operating at high speed, or (iv) sensor not working. Constant speed cruise shuts down if speed drops below 25 mph (40km/h) or by more than 10 mph (1km/h) below preset speed, or if VSC comes on.
    There are the usual warnings that it may or may not work, should not be used in heavy traffic or bad weather, and you better pay attention, etc., etc. :doh::doh::doh:
    5 people like this.
  12. XMAN LIVE
    XMAN LIVE "Just have Fun!"
    271
    49
    Cypress TX
    Feedback on this topic is great! Keep up the good work. I have not heard much about how gas mileage is affected when driving with adaptive cruise control on. I would guess you still put the car in ECO mode. Has any buddy been daring enough to put the adaptive cruise control in short mode and draft a truck. With distance being 100 ft, I would think that you would pick up MPG by doing so. Not that I would do this kind of thing….all the time. :eek:
  13. Tideland Prius
    16,559
    So if I'm reading this correctly, the button on the steering wheel is only for adjusting the distance, yes?
    Also, if I push the CC stalk away from me to engage constant speed CC, does it default back to adaptive CC when I start it up again? That's what you mean by "it defaults to adaptive speed control" right?
  14. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    yes and yes
  15. hybridtwins
    hybridtwins Member
    202
    Van Nuys, CA
    2002 Prius
    >Clean Radar Sensor; Cruise Control Not Available (try turning on your wipers)
    Does this mean that the radar sensor is somewhere behind the windshield, perhaps in the 'nacelle' with the cluster of controls at the front edge of the cabin roof?
  16. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    My bad, not enough coffee this morning. The actual corrective action is to turn wipers off or down to the slow or intermittent speed. System won't operate with wipers on high speed. I've corrected the original post.
    It's my understanding the radar is located directly behind the Toyota emblem, so that would be what you would clean. The LKA camera is behind the rear view mirror, looking out through the windshield, but I don't think that affects the cruise control.
  17. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    Radar sensor is under the hood, directly behind the plastic badge.
  18. Tideland Prius
    16,559
    It's behind the front emblem and much improved. If you see the old vehicles with radar cruise, they have a rectangular clear plastic piece in front of the emblem which looks unsightly.
    Thanks!!
  19. jprates
    387
    42
    Moita, Portugal
    2017 Prius PHV
    Whoa! I'm pleased to say that you went way past my expectactions, THANK YOU VERY VERY MUCH for such a premium detailed explanation! :first:
  20. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    Tried again today on a heavy traffic freeway. Worked just fine. Sped up or slowed down, depending on what was in front of me. When you turn it on, the MID shows outline of the rear of a car, with 1, 2, or 3 bars on top, depending on what following distance you choose (the bars represent the road). If a car is within the 120 foot range of the radar, another car outline appears on top of the bars. If the car moves to another lane, the car on top disappears.
